Screen inverters
  • spleenharvester
    • Mar 2010
    • 903
    Screen inverters
    Can old ones cause screens to be dim/slightly washed out?
    I thought the screen in my L300 was poor quality, has poor viewing contrast and really not very bright. Tried in another L300 and it's nice and vibrant.
    Could a worn out inverter do this?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 903
    Re: Screen inverters
    Bump
    • cashkennedy
      • Aug 2011
      • 668
      Inverter just powers the backlight, so could make it dim, but if you mean washed out as in "lacking contrast" then no it cant cause that. but if you mean having too much contrast / too dark, then yes it could cause that.
      If you swaped the screens for testing, why not swap the inverter?
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
