oh shit my linux box has a rootkit!
  • ivtec
    • Dec 2008
    • 1967
    Re: oh shit my linux box has a rootkit!
    every time i get some error on my ubuntu12.04 just get the cd or stick and reinstall again it's much easier than dealing with the problem that is on my end of thinking, i have my important stuff in an out extra hard drive and some times i download to it as important files come in and that's it,no worry about it.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      i don't, usually. it lasted long enough to get my home dir(s) and then quit. it sucks
      Follow the white rabbit.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        UPDATE: the HDD that it got copied too is acting up as well, but not in the same way the sata link becomes so slow that a hard reset is sent to the disk, what this means i don't know but running tests on the disk show its fine.
        UPDATE2: the 12v rail was not providing enough power because of a large cooling fan. unpluged the new drives are fine pluged in the drives error out. why?
        • luke10050
          • Mar 2013
          • 209
          i know nothing but could be ripple or interferance? hdd's dont exactly have filter caps
            If a fan was putting your power supply out of regulation, the power supply is probably not going to last long.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4950
              • New Zealand
              #26
              Maybe the fan is faulty?
              -David VanHorn
              • Yatti420
                • Mar 2008
                • 130
                Get rid of the psu / fan.. Spinrite (if you own it) or try Hiren's 15.2 I think it has a new program (not sure on liscensing) for hdd testing/sector recovery.. Similiar to spinrite..
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  What kind of PSU?
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    #29
                    ^ delta 250w recapped with rubycons and doesn't have the double diode treatment.
                    • luke10050
                      • Mar 2013
                      • 209
                      that doesnt sound too bad... i run one of those with a Q6600 and a 9600GT... seems to work fine
                      one of the dell OEM ones right?
                      Edit: Sorry mines a Lite-On
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        #31
                        ^ power spec OEM, in a power spec B613
                        EDIT: 12v rail sits at 11.74v 5v rail ant 5.04v is that bad?
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Nope it's totally fine 11.5 would worry me.
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            What are you using to measure those voltages with?
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              #34
                              cen-tech digital multimeter, battery voltage @ 8.97v(new battery) tested on a precision bench PSU set to 12.46v, the meter reads 12.45v so the meters in good nic.
                              • Sparkey55
                                • Jan 2010
                                • 1523
                                cen-tech digital multimeter battery voltage @ 8.97v(new battery)
                                Good. Glad to see someone else not trust motherboard monitoring of volts. Sometimes the built-in compensation networks of those things screw up.
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  #36
                                  actually my mobos volt monitor is pretty good it reported 12.77
                                  • luke10050
                                    • Mar 2013
                                    • 209
                                    only ONE volt off haha!
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      #38
                                      que?
                                      • luke10050
                                        • Mar 2013
                                        • 209
                                        well your meter got 11.74, your motherboard got 12.77 or was that a typo
                                        • goontron
                                          5000!
                                          • Dec 2011
                                          • 4108
                                          • US
                                          #40
                                          typo, sorry 11.77v from mobo
