Ratdude's Main rig V3.5
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #41
    Re: Ratdude's Main rig V3.5
    KZG's aside I think this is a software issue, do you have the latest BIOS?
    I would try XP 32bit, 64bit, Win7 32bit, 64bit
    In no particular order.
    Also keep in mind several Windows OS have had issues during installation with more than 2/4GB of RAM, so might be useful to remove all sticks bar one during install and let it do all Windows updates then put them back in.
    Also in systems like these the mapping of memory above 4GB is very important, there I can't help you with what is correct but trial and error usually solves it, or post what options you have and then I can give some recommendations.
    What it basically comes down to is KISS, i.e. remove/disable anything the system does not need to POST, then try install, if it works enable/reinstall things one by one
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      There was an Xp x64 install on the RAID array which immediately BSOD'd... however, I don't know if it was working previosly or not as V3 wasn't stable.
      The win 7 disc BSODed within seconds of a DVD boot attempt. BIOS would boot the disc, then a sec or two later, BSOD and hard reboot. Like something major was up. A RAM mapping issue would make sense but if it was working on 8gb ok, then I don't get why 16GB wouldn't. I may do a CMOS reset and start from scratch.
      sigpic
      (Insert witty quote here)
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I saw this in the Board's manual:
        There are three power connectors on your Thunder K8WE.
        The Thunder K8WE requires an EPS12V/SSI EEB 3.51 (24 pin + 8 pin) power
        supply to boot. TYAN recommends using a split plane power supply because of
        the amount of power the S2895 requires.
        You also have an option of using an SSI v3.51 workstation power supply. This
        is recommended when running both PCI Express slots
        Does that still apply if the GPU's have direct PSU connections?
        sigpic
        • gg1978
          • Dec 2004
          • 431
          i had a typo in the post about how i was running that board.. I had a PCIe 9400GT in the top PCIe slot, so that definately should work OK.. when you put two cards in SLI, i'm not sure if the PC will show a POST display on the second card..
          I was running 8 pin CPU power and the 24 pin ATX connector, as the acbel 550W PSU had both of those.. I don't recall any other connectors on the motherboard itself though
          • gg1978
            • Dec 2004
            • 431
            as for your existing Win XP 64 bit install, that would probably BSOD no matter what, as you would probably have the wrong chipset drivers loaded, as i assume the last motherboard to boot that OS had a different chipset.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Very true.
              sigpic
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                #47
                if I remember off the top of my head, in MT86+ you hit C and then...2? I think
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Did you install sli bridge? If so remove it maybe it will work then?
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Reseat the RAM. And your may need a VDIMM bump.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • mariushm
                      • May 2011
                      • 3799
                      #50
                      Windows xp 64bit is basically using the Windows 2003 kernel, so anything validated/certified for Windows 2003 64bit should run on Windows XP 64bit as well.
                      But I don't understand why you'd HAVE to use Windows XP... I basically had Windows 2000 on my home computer, then skipped straight to Windows 2003 Standard Edition and now I'm using Windows 7.
                      Up until a couple of weeks ago, I still had a dedicated server in a datacenter with windows 2003 web 64bit and it was working fine.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Tried it already, no dice.
                        sigpic
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          I still think the 3.3V rail on the PSU might be getting overloaded, those old high voltage ECC sticks use a lot of power, especially in memtest
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            I think I found the issue, kinda. It will run with 4gb or 8gb of ram, but with 16gb it doesn't get far. Memtesting all 16gb while I'm at work for an hour, I'll see what happens when I get back
                            As for the 3.3v issue- any psu suggestions?
                            sigpic
                            • mariushm
                              • May 2011
                              • 3799
                              #54
                              You could just open the power supply and measure the current taken out of 3.3v ...
                              If there's an inductor for the 3.3v rail (pi filter at the output) just desolder one of its legs and put the multimeter in series with the inductor.
                              With such a motherboard, I kinda doubt they're using 3.3v to power the ram - it makes more sense to just use 12v for everything, for better efficiency.
                              • thesloc
                                Banned
                                • Dec 2011
                                • 587
                                #55
                                You're probably running an outdated bios if that much ram isn't supported, if at all.
                                Or check the configurations.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  It has the latest BIOS, 1.06, 11/'08
                                  Memtest failed like crazy around 42%... just a constant string of failed addresses when I got back from work.
                                  So yeah, the RAM is hosed, at least one module.
                                  Also, one of the HDD's died today. it was the one with 26 Bad sectors (or so it was the last time I checked). Won't show up at BIOS. tried different controller ports, the onboard SATA, and different power connections and SATA cables. Dead as a doornail.
                                  Not sure if I'll replace the dead drive or stick with the 3 and call it good. As for the RAM, I'll see if I still have an ebay seller warranty on it. edit- no such luck. Looks Like I'm stuck at 8GB unless I justify $$$ for another 8gb. I may have mishandled a couple modules when I was seeing if a board could do ECC, so this one is on me. I hope 8GB is enough.
                                  Any feedback on whether to replace what died or to do without?
                                  sigpic
                                  • mariushm
                                    • May 2011
                                    • 3799
                                    #57
                                    Get some isopropyl alcohol, dab an plain unscented paper handkerchief in it and rub the memory module contacts to clean them.
                                    Get a piece of A4 paper, bend it two or three times then drag it between the pins in the memory slots to rub away some oxides. Inspect the modules to make sure each pin is in the proper position and can flex a bit when you insert the ram, to make good contact.
                                    If you have time, test each module one at a time to see which one fails... well, one on each cpu.
                                    • thesloc
                                      Banned
                                      • Dec 2011
                                      • 587
                                      #58
                                      I have a couple of ECC modules, I can send them to you if you want since I'm pretty sure I'm not making much of use of them.
                                      I *think* have them around somewhere, they're 2gb sticks, I think.
                                      • thesloc
                                        Banned
                                        • Dec 2011
                                        • 587
                                        #59
                                        Wait, mine is DDR2 PC2-3200 (IBM)
                                        There's 2 2GB sticks, for a total of 4GBs.
                                        Your machine uses ancient DDR, no?
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          It uses PC3200 ECC DDR1. I know, old and freaky, but it works and is low cost.
                                          sigpic
                                          • Dobrowol
                                            Dell Latitude 3520 help with bios build/repair
                                            by Dobrowol
                                            Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                            Steps i done and results:
                                            I exported a clean bios from update file via pfs extract.
                                            1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                            Result: Dead
                                            2. Build clean bios with no changes in ME, new PMC, PCH
                                            Result: Dead
                                            3. Build old bios with clean ME, new PMC, PCH
                                            Result: The same
                                            09-22-2023, 02:43 AM
                                            ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                            This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                            09-12-2024, 03:28 PM
                                          • iotaa
                                            How to build this little device please for my campervan security
                                            by iotaa
                                            You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                            I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                            For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                            The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                            This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                            09-18-2022, 09:52 PM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            by sam_sam_sam
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
