EISA backwards compatible?
  • pentium
    • Mar 2006
    • 2778
    I finally am kissing goodby to my 98 server and saying hello to a new dual-pentium pro AST server with 256 mb ram, windows 2000 server, a nice PCI adaptec scsi card and no on-board IDE support. The only thing I am concerned of is the use of EISA sockets with ISA cards. My ditto dash card is needed for my tape drive yet it needs an ISA port and the same goes for another controller card. I am looking around and I get mixed results:
    -ISA cards will not work in EISA slots.
    -ISA cards will work in EISA slots.
    You guys have been around longer than me, what is the truth?
    Find Nedry!
    Check the Vending machines!!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: EISA backwards compatible?
    You have 3 different selections of ISA slots, one is a short black one, which is an 8-bit ISA (most common in 286's, 386's, and early 486's), and the longer black one, which is a 16-bit ISA (common in 486's all the way through P3 and K7 PC's), and then the EISA which is a 16-bit ISA with a goofy looking PCI looking slot behind it, which used a long-ass boat ore looking card, which were commonly found in servers that had proprietary SCSI add-ons, or RAID controllers. A 16-bit card should work in that if memory serves me right.
    A 16-bit card won't work in an 8-bit slot, but an 8-bit card will work in a 16-bit slot.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Yup, it should work. Its like 16 bit and 32 bit Microchannel, one is longer than the other, but short card works in long slots. PCI is the same, 66 just has a little extra slot at the end.
      • pentium
        • Mar 2006
        • 2778
        ummmm...
        I know the differences between 8 and 16-bit ISA Topcat. I was just asking if a standard 16-bit ISA card would fit into the 32-bit EISA socket.
        Here is a pic of the board I got, minus the cpu and memory riser
        The three slots in question are on the left of the board.
        EDIT: Note what kind of caps are being used. These ones look much nicer than cans.
        Find Nedry!
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Oopsie, I confused EISA with something else, my bad. No, a 16-bit card won't fit in that.
          Team : 49813
          Join in!!
          Team Stats
          • pentium
            • Mar 2006
            • 2778
            It won't?
            *sigh*
            Find Nedry!
            • Rainbow
              • Aug 2005
              • 1375
              ISA cards should fit and work in EISA slots.
              • Spacedye69
                • Nov 2005
                • 698
                • US
                link SUPERSET of 16bit ISA, EXTENDS to 32bit
                • pentium
                  • Mar 2006
                  • 2778
                  Thanks man!
                  When doubt, use wikipedia.
                  Find Nedry!
                  • gg1978
                    • Dec 2004
                    • 431
                    Yup, you can use ISA cards in EISA slots.. The EISA slots have a "lower" section where the actual eisa signals are.. An EISA card has an extra "tongue" of connectors below the regular ISA ones.. It's keyed to allow ISA cards only to slot into the connector far enough to connect to the ISA part. If it went any further in, you'd probably short the EISA bus as the EISA section uses finer pitch for connections.. . Now how well resource management on an EISA bus works differently than ISA, not sure whether the same procedure applies.. My only EISA system is long retired.. *Compaq Pentium 60 Desktop*
                    On a side note, you do realize that motherboard isn't ATX??? It almost looks like it, but the screw holes appear to be in the wrong places..
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      some(most) eisa boards need a utility to register the cards.
                      hope those sm lytics arent bad.that would be very time consuming to recap!
                      • pentium
                        • Mar 2006
                        • 2778
                        The board's in pretty good shape. In fact it was never put into service. I understand it's not atx but I can live with AT for a while longer however I am worried about that secon set of power sockets. What do they exactly do? I really don't think I will even be using EISA anyways. My scsi card and network card are both PCI and PCI is far faster then EISA.
                        For a case fit...I might be chopping up a full-height case.
                        Find Nedry!
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          I didn't know that about EISA either. I think I've only seen maybe one or two of them.... Sure didn't look like a 16-bit ISA would fit that goofy looking slot...
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Rainbow
                            • Aug 2005
                            • 1375
                            I also have one board with EISA slots - it's Intel dual socket 7 server board. It works but all external connectors (including keyboard) should be on a daughter board which I don't have. The card's connector looks like SIMM slot (pinout is described in board manual) - so I'm thinking about modifying a SIMM module - removing the chips, drilling the holes that connect pins on both sides and soldering 4 wires to a glued 4-pin block. Then a keyboard connector could be attached there.
                            • pentium
                              • Mar 2006
                              • 2778
                              Some daughterboards are just badly designed.
                              Who made the board.
                              Find Nedry!
                              • omega
                                Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                by omega
                                Hello all,
                                as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                02-09-2024, 03:34 PM
                              • harp
                                Comparing FreeNAS, FTP server, SMB server, multimedia server...
                                by harp
                                I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                                I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                                Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                                What is general difference between this products, and what be most useful...
                                01-04-2024, 02:44 PM
                              • NotEnough
                                Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                by NotEnough
                                I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                What I've Tried So Far:
                                • Reseated the cables.
                                • Reinstalled AWCC and AlienFX services.
                                • Attempted BIOS downgrade but no improvement.
                                • Inspected ribbon cables for damage.
                                • Explored the possibility of BIOS or
                                10-19-2024, 01:34 AM
                              • Fireballcz
                                Windows 2016 server L2TP/IPsec VPN - two subnets
                                by Fireballcz
                                Hello, please how to properly configure VPN in this environment?
                                I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                                Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                                2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                                I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                                I have no problems with VPN connection...
                                07-29-2022, 03:20 AM
                              • frans00000001
                                Supermicro Server mainbaord x10dri-ln4+ schematic
                                by frans00000001
                                Good day
                                I am looking for a mainboard schematic for a Supermicro Server mainbaord x10dri-ln4+ as the track broke off on the BIOS chip and I want to repair to use the server again. If possible can someone assist to get this schematic?
                                08-06-2025, 05:36 AM
