The error message means that your CPU does not support PAE extensions
  • ivtec
    • Dec 2008
    • 1967
    Hi guys: i found these articules about (PAE) i thought to post these and start a threath about old PC or Laptops that people encounter problem with the install of Distros that seem to have enough resouses but can't install certain distros.
    http://askubuntu.com/questions/18200...rsion-on-an-ib
    So post your Disto Info; and the Distro that you can't install Linux OPS
    Sony vaio VGN A195EP PENTHIUM (M) 1.50MHZ CPU, 1GBRAM,60GB HARD DRIVE.
    So far can't install ;MINT14,LUBUNTU,UBUNTU,Kubuntu.
    So far only CAN install ;Debian 7. Wheezy, Xubuntu these 2 are the ones i tried.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: The error message means that your CPU does not support PAE extensions
    so instead of releasing a non-pae iso, they force people to a net install.
    Sucks for people without highspeed.
    I have a love/hate relationship when it comes to ubuntu. The package support and rolling updates I <3, but ubuntu's stability and crappy unity interface not so much.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      That's ubuntu for ya...
      Even with that, they still prop themselves up as being so superior to XP/wintel.
      Ever since 'buntu "sold out," they've only been whoring themselves...
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • everell
        • Jan 2009
        • 1514
        I had pretty good luck with Ubuntu until the last two releases. I am using an Intel D865 board with 2 gig of memory. Using the on board video. Both Ubuntu 12.10 and 13.04 load great, but when I log in, all I get is the desktop background - no menu bar and no launcher. I have found several posts giving the "workaround" but so far none have worked. I also found a post that said that the Intel chipsets 845, 865, and 895 will not work. So I put a video card in the AGP slot and it still doesn't work. I can load and use Ubuntu 12.04 with no problem, but have not figured out a solution for using the 865 board.
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • Time2Retire
          • Aug 2012
          • 256
          There is a link on the page you linked to that gives solutions.
          http://www.webupd8.org/2012/05/how-t...n-non-pae.html
          It seems Xubuntu & Lubuntu have non-PAE kernels. And, someone has made a non-PAE version of Ubuntu 12.04:
          https://bugs.launchpad.net/ubuntu/+s...47/comments/84
          EDIT:
          Here's another How-To:
          http://www.webupd8.org/2012/11/how-t...n-non-pae.html
          It didn't take much digging to find this info.
          • Time2Retire
            • Aug 2012
            • 256
            Originally posted by everell
            ...So I put a video card in the AGP slot and it still doesn't work...
            If this is a nVidia card, you have to edit the xorg.conf file:
            https://http.download.nvidia.com/XFr...ppendix-f.html
            When configuring Linux video, the MythTV wiki has a lot of info:
            http://www.mythtv.org/wiki/XvMC#Configuring_xorg.conf
            Also, make sure the BIOS is set to use the AGP card instead of the internal video chip.
            EDIT:
            I don't find an AGPGART module on my system, so I don't believe it is included in Linux anymore.
            • japlytic
              DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
              by japlytic
              In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
              Tried (only with keyboard/mouse connected):
              • BIOS + database update
              • Using latest Windows 11 image built with official image creation tool
              • Previous setup version for Windows 11 installer
              • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
              • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
              • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
              06-19-2025, 04:59 PM
            • TrumanHW
              MacOS: R|W Programmers like CH341x BINs..?
              by TrumanHW
              For years I tried figuring out how to R|W BINs from my CH341x programmer.
              From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
              I'd expect many here figured it out (easily), but in case not ...
              It's one of the few forms of "how-to" remuneration I can GIVE BACK.
              This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
              This may be the easiest means to copy-paste:
              Code:
              SERIAL -to- USB - CH341 ROM (MacOS):
              Install xcode:				xcode-select --install
              Relocate
              04-08-2022, 02:33 PM
            • 24gsm
              MacBook Pro A1708 install macos fail
              by 24gsm
              hi to all
              i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
              after enter to recovery and format hdd 1to .
              after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
              can help please
              Serial Number: FVFXP0U0HV2J
              Config Code: HV2J
              Find My Mac: OFF
              04-16-2025, 03:57 AM
            • duwane
              A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
              by duwane
              Hi All.
              Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
              The issue:
              Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
              10-26-2022, 07:02 AM
            • sajidmirza
              A1990 cant install OS after SSD nand repalced
              by sajidmirza
              Got A1990 with ssd nand ic shorted.Repalced all the nand ic from same donor board.Restored in apple configurator successfuly and booted to recovery.Its high siera recovery.But when i try to insatll OS from internet recovery it gives error "Recovery server could not be contacted".tried at different places thinking of low internet but still getting same error.Tried date adjustment from terminal also.
              i have heard that we cant install OS from high siera recovery at the moment.Is it true.If yes how to update recovery to latest one.tried to restore several times from...
              07-06-2023, 07:53 AM
