Bad manufacturing?
  • Elysarian
    • Mar 2013
    • 200
    Bad manufacturing?
    Whatever you do, don't buy an XFX Radeon graphics card (at least not the R7950 DD 3GB flavour) - mine died in spectacular fashion last night after 2 months of service...
    I have hardly been stressing the damn thing (work away a lot and the PC is at my mum's so doesn't get used when I'm at home) and while playing a quick game of Bioshock Infinite last night the following chain of events occurred:
    1. I heard a clicking sound from inside the PC.
    2. Clicking progressed to a grinding within seconds
    3. PC went off (panic time!) - this happened before I could do my usual "reach around the back and hit the power switch" method of saving myself from expensive hardware failures
    4. I opened up the case to investigate
    5. The offending graphics card was so hot I couldn't actually touch it and was ticking (sound of something contracting as it cooled)
    6. waited until the card was cool enough to pull out and found that one of the fans had shattered
    7. temp installed an old PCI-E R370 card I had laying around to make sure nothing else was fried
    8. PC booted up fine
    Upshot is I'm now running with my old Geforce GTX460 until I hear back from Scan on an RMA - hoping they can swap the POS card for a better (non-XFX) one now...
    A cursory googling leads me to believe this is not an isolated incident with this particular card - looking at other people's experiences it would appear that the cooler has a nasty tendency to warp (which in my case I can only surmise caused the fan to hit the shroud and disintegrate).
    PC won't POST with the card in there so I would assume that something is shorted out (caps all look good but I haven't bothered investigating any further as it's under warranty).
    All PSU voltages are within spec so I know it has to be the card itself (and it's rock-solid stable again now with the geforce in there).
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Re: Bad manufacturing?
    Had a similar issue with two xfx 6870, the fan was rubbing against the shroud. Had to take it apart and sand down the shroud to free up some space.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I try to stay away from XFX... I've had my HIS 7950 3GB for 9 months now almost running 24/7 the entire time and playing lots of games, haven't had any issues. At least you can still return yours.
      • cheapie
        null
        • Jul 2010
        • 849
        I have an ASUS RHD 6570, and it seems to be working fine although the fan has gotten very noisy.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          I had two XFX GTX 285 black editions (superclocked) running in SLI for years, till I burnt one up with a bad PSU, now I only have one, still working great
          • Christos Tsiligiannis
            Marian Trace Alpha sound card repair help
            by Christos Tsiligiannis
            Hello to the forum.
            My name is Christos, I am new to the forum here and i am posting from Greece.
            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
            So i tried asking for a schematic from the company and they would not give me one. Instead they...
            11-18-2024, 05:26 AM
          • Kemer
            Graphics Card mounting frame
            by Kemer
            Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
            As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
            I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
            What worries me right now is the possibility that...
            09-14-2024, 08:57 AM
            HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
            This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
            09-06-2024, 08:30 AM
          • benwaterson
            Gigabyte Aorus 1080ti - card not initialising
            by benwaterson
            Hi there.
            Have searched various forums but haven't come across the exact issue I am having.
            Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
            I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
            Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
            02-05-2022, 11:42 AM
            Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
            The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
            The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
            10-23-2024, 03:26 AM
