Planned power outage - how should I prepare?
  • Tom41
    • Oct 2005
    • 336
    • England
    The electric company in my area are replacing some equipment in the local substation, and as such will need to cut power to my neighborhood for a whole day.
    I've heard a lot about power surges caused by turning electricity off and on, especially when it's done for a whole subnet from the substation. How should I go about shutting everything down and disconnecting?
    What I plan to do is shut down all computers, servers and electronic equipment as far as is possible, then trip the MCBs at my fuse box for everything except the lighting circuit (so I can see when power goes off and on). Is that enough to isolate my equipment from any potential surges, or should I try to unplug everything as well?
    Any electronically-minded people here have suggestions?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Planned power outage - how should I prepare?
    I've always just shut everything down and unplugged... Of course, I have a smaller number of machines than it sounds you do.
    Ludicrous gibs!
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      we have occasional power outages here in the summer. what can happen on occasion is the power comes back with a surge.
      the only equipment i would worry about are computers (if they are not protected by quality ups) but most importantly devices with poor power supplies such as dvd/cd players especially newer ones. (i had a surge once after a short power cut and it damaged nothing but two identical denon dvd players)
      anyway if you want to be absolutely sure then just unplug anything nice you like to keep
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Unplugged being the key word. I'd have all unplugged until they're finished. I've seen power companies fry way too many people's and business's electronics. Boo-boo's happen, and they wont pay for their screw ups.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • japlytic
          • Oct 2005
          • 2086
          I have thoughts of using a car engine (the Buick 3800, my favourite engine used in the Holden VN Commodore) from a wrecking yard and turning it into a 150kW (estimated) electricity generator (with some other parts), enough to power a large supermarket!
          This system would use an inverter at the high voltage output connected to the generator output to produce clean and regulated AC power.
          The Chevy 6L V8 from the new VE Commodore would be too hot to handle right now...
          • gonzo0815
            • Feb 2006
            • 1600
            If you have some things, you normaly won`t unplug for a few years, keep some replacement caps handy. Especially some DSL modems don`t restart, if the gone caps are cold. This was for me the only bad experience after an sheduled power outage of 4 h. This was the one of three power outages i can remember. But from the latest problems in EU, i think this good power reliability woud be the next sacrifice to the shareholder value.
            • Tom41
              • Oct 2005
              • 336
              • England
              The outage has been and gone - it was nearly all day, 8:45am to 4pm! After putting the MCBs back on, all I had to do was reset the clocks and boot up the servers again. Nothing seems to have been damaged, thankfully.
              Actually, maybe it's not all good - my phone line has been dead since the electricity came back on yesterday. No power to any of the phones plugged into any of the sockets. If you call the number (from a cellphone etc.) it sounds as if it's ringing, but the phones don't ring - and if you pick it up nothing happens.
              I'm on cable so still get Internet and TV, but I wonder if all the road-digging works (for the new electric wires) damaged the phone network? Perhaps an MCB tripped inside the network distribution box when the power was turned off and on?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                i would have made sure my genset had a full fuel tank and enough to run it a while..wait i already have that!
                tests honda genset...yep starts with the bump of the key!
                • sew333
                  Restore on AC power - question. Power outage and pc not booted again. But in power co
                  by sew333
                  Hi my pc: 10850K stock 4800mhz
                  2x16 GB DDR4 GSKILL 3000mhz XMP
                  Seasonic Tx-850 Ultra Titanium
                  Gigabyte Rtx 3090 Gaming ( 2x8pin,2 separate pcie cables )
                  Asus Z490 Maximus
                  1 TB SSD
                  Hi . I have an question. 5 days ago i had momentary power outage for brief moment. When power back pc not booted itself. I just presset reset button to turn on pc.
                  In bios i have option RESTORE ON AC POWER - ON.
                  But when i cut power by pressing off BUTTON on power cord for second and then turning on pc booting itself...
                  01-05-2022, 08:13 PM
                • KYBOSH
                  Leviton SmartlockPro Programmable Electronic Timer Switch With Astronomical Clock Wont Keep Time After Power Outage
                  by KYBOSH
                  Model number VPT24-16Z.
                  https://leviton.com/products/vpt24-16z
                  I have 3 of these in my home for over 10 years now and Im planning on replacing them as I lean towards a Philips Hue home setup.
                  They are great units but they lost the ability to keep/store the time and settings after power outages and brown outs.
                  I knew it was a battery in there somewhere but never got around to looking into it.
                  Well an opportunity came for me to remove this from its home in my wall so I disassembled it to see what was going on.
                  I found a 3.6V LIR1632 battery spot...
                  07-31-2024, 09:37 PM
                • sew333
                  IIAMA refresh 144HZ -soon after power outage booted with lower value
                  by sew333
                  Hello.
                  My pc:
                  *Asus Z170-P with 6700K cpu
                  *Corsair 750 RM
                  *Gtx 1080 Ti Founder Edition
                  *Monitor Red Eagle IIyama 24' 1080p 144hz plugged by display port cable to GFX.
                  Few days ago i get power outage.
                  Pc was running in fire strike benchmark.
                  At the same time my mother was powering on electric oven in kitchen.
                  And then power went out in house.
                  Then she go to shop and buy new fuse.
                  Later a friend replaced fuse and power back on in house.
                  When power back. I booted pc...
                  11-22-2017, 05:07 AM
                • Green Probe
                  Recapping a Denon AVR X6400h SMPS
                  by Green Probe
                  (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                  Disclaimer: I'm an amateur hobbyist and will get things wrong.
                  Always use caution when working around mains power and high voltage capacitors!
                  Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                  SYMPTOMS:
                  -No display...
                  07-18-2025, 03:36 PM
                • traxformania
                  TONGFANG "GM7TG7P" Bios Password Problem?
                  by traxformania
                  I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                  But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                  I'm trying to reset my bios without success.
                  I tried :
                  -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                  11-15-2023, 07:32 AM
