More is bigger; mine is bigger than yours!
  • Elitist
    • Apr 2006
    • 159
    Couldn't find an item about the record for most bad caps on one board? If there is one, please moderate by a merger.
    Soltek SL-75KAV has 14 bulging, leaky GSC caps.
    Is this a record?!
    How did it get this bad?
    Mostly they die when one goes bad.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: More is bigger; mine is bigger than yours!
    Abit KT7-RAID
    30 caps 1000uF and up, every single one had vented. That's my personal record for single board with most bad caps in it.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Elitist
      • Apr 2006
      • 159
      Truly amazing!
      What make(s)?
      Of course, being Abit, they are one of the few companies to accept responsibility and make reparation?
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        My worst is here-
        https://www.badcaps.net/forum/showthread.php?t=1583
        Ludicrous gibs!
        • Elitist
          • Apr 2006
          • 159
          From your pictures, dood, I could only count 14, maybe 15, bad units. TC's board is far worse.
          The trick with MOSFET removal (and stubborn caps) is to pre-warm the entire board area with an electric hot air paint stripper and use a low wattage (more controllable) iron to administer the coupe de grace. Works every time for me. I use the same brutal technique to strip and recycle mem chips from dud video cards - apply the heat gun from the reverse side, really let it rip whilst applying gentle leverage with a screwdriver to the chip (is a screwdriver the most valuable tool ever devised?). Solder (60/40) melts ~182C, silicon ~1420C, although eutectics at the junctions may be affected above ~500C? I look at it this way - at worst, the entire unit is either going into the bin or to China for clandestined stripping, so what's to lose?! Since the industry achieved all-ss, you'd be amazed at the thermal punishment most stuff can tolerate, unlike a quick burst of static [so always work without your shoes and socks, preferable standing on a flagstone floor].
          Further, on MOSFETs - try to find the datasheet from the Web. Some are difficult to source, some proprietary types (eg in washing machines!) impossible. Often, it is possible to find an entirely satisfactory equivalent with almost the same or better characteristics, sometimes cheaper, even. Indeed, I find I have such a vast store of stuff stripped from a range of dead hardware that I can sometimes source one from my personal stock!
          • Elitist
            • Apr 2006
            • 159
            One final note: not sure I'd spend any time or lolly on a Slot1 board! Plenty of SktA boards around needing recapping going for the asking, and many of these will do 2GHz, or at least, clocked, into the 'XP' 2000+ range, whatever that means.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              There were more than 14 failed caps. I didn't get any pics of the caps between the PCI slots and around the bottom corner of the board. The only reason I recapped this board was because it was for a customer that needed data off of a RAID array that he had running on this system.
              And, you were just looking for our worst, so that's what I gave you! I wasn't competing with Topcat for overall worst...
              Ludicrous gibs!
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                i strip many boards before i toss them.
                some parts are a pain in the ass to source and stupid minimum quantity of thousands often apply.
                as for the slot 1 comment..you would be shocked to see what gets sent to me for repair.
                i dont argue.fix it and get paid.
                much of the really old stuff is proprietary and irreplaceable though.
                • Elitist
                  • Apr 2006
                  • 159
                  Not much shocks me any longer! Seen any thermionic valves recently?!
                  The good thing about customers still using old kit is that they probably still have W9x running. Frankly, I turn down anything associated with the NT series and NTFS unless they just want an Fdisk and new install. Life is just too short, esp. when you don't have that nice DOS underlay to access everything. Amazes me that so many will settle for Redmond cr*p. Must run into the billions by now?
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    Yup. I get socket 7 stuff all the time. I fix it and get paid. It's the client's business what they do with them. In cases where its proprietary, they're grateful that their hardware could even be fixed, it cost them a few bucks, but saved them thousands more!
                    Team : 49813
                    Join in!!
                    Team Stats
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i own about 50 thousand of them!
                      i have several large "boatanchor" recievers and a few round screen color tv set that work perfectly.
                      and even a fisher 400 as an amp on this pc.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        ...looks at 4 servo products cnc consoles stacked up here awaiting rebuild....
                        • Elitist
                          • Apr 2006
                          • 159
                          Try this one:
                          www.theinquirer.net/default.aspx?article=35537
                          for all valve fans.
                          Incidentally, there aint no such thing as a 'vacuum tube' - they are partially evacuated and injected with various partial pressures of inert gases (a lot, in the case of gd varieties), getter, etc. BEFORE they are finally sealed.
                          • Davi.p
                            HP Laptop not charging..
                            by Davi.p
                            Hi, exactly on the August 2023 i saw a YT video from "electronic repair school" channel, where it says a technique how to recover dead batteries not charging, probably them has been left uncharged for too long and became "locked" by internal circuitry to avoid wrong chargement by laptop, i'm still wondering why every cellular phone also the oldest and cheaper has a built in slow charge modality to avoid danger on li-ion cells, and on laptop i' ve never heard of that option, only stupid lock modes so those are ready for the trash bin, this maybe due to bigger size / more danger,...
                            10-03-2025, 05:15 AM
                          • mecha1166
                            Tascam CC-222MKIV Need PLAY / RECORD button assy on CD side.
                            by mecha1166
                            Hi. A customer brought in a Tascam CC-222MKIV. Play/Record buttons on CD are broken. I am looking for a mechanical parts breakdown so I can get the part number for this key assy. I found the schematic online, and I can tell you the schematic locations for those switches themselves. There is a plastic assembly with buttons that each have shafts to poke the surface switches on the circuit board right behind the faceplate. That is what I need. Thanks!
                            07-25-2024, 01:49 PM
                          • Proxy64
                            Looking for Acer Predator 17 G9-793 (N15P4) schematic
                            by Proxy64
                            Hi, I am looking for schematics for an Acer Predator 17 G9-793-73A6?
                            I can not read the last digit, maybe 6.
                            In another topic I found a boardview that seems to match mine: Acer Predator 17 G9-793 - Pegatron MU5DC CH7DC BoardView
                            But in the same topic schematics don't match (both board view & mine) : Acer Predator 17 G9-793 - Pegatron MU5DC CH7DC REV 2.0
                            On this mainboard, the GPU is dead (shorted), but I am trying to have it booting without the GPU Nvidia, to disconnect GPU I have desolder 3 coils powering the GPU, and one bigger in upstream these 3.
                            Now it begin...
                            06-05-2025, 09:30 PM
                          • envym
                            MacBook Pro 2018 with Activation Lock
                            by envym
                            Hi everyone!
                            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                            06-27-2025, 08:54 AM
                          • Chrissygizmo
                            Can i use backlights from a diffrent model tv to work mine ?
                            by Chrissygizmo
                            Hi all , bit of a strange one for yous here lol , ive got a samsung ue49ru7300k , backlights need replaced , however ive got some backlights from another samsung tv , i will post photos of them .. the connectors are the same & everything so im guessing they could work...
                            11-07-2024, 03:16 AM
