two of the same mobos, one runs hotter than the other. why?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    i have two of the same mobos (maximus 2 formula) and the nb and sb on one runs much hotter 40°C vs 60°C than the other. the cpu, ram, video card and psu are kept the same. it is NOT overclocked.
    i cannot figure out why two of the same boards can run at such a vast difference in temperatures. what could be the possible list of explanations? could it be bad caps, bad mosfets, faulty thermal sensor giving wrong readings perhaps? what else?
  • mariushm
    • May 2011
    • 3799
    Re: two of the same mobos, one runs hotter than the other. why?
    Measure the temps directly on the heatsinks with an ifrared thermometer or some probe. Don't rely on software sensors.
    But keep in mind if you use an infrared thermometer that shiny surfaces can mess up the measurement.
    Could be imperfect contact between the chips and the heatsinks, maybe not enough pressure, or too much thermal paste.
    Maybe you have one board with different settings (cool'n'quiet or equivalent on one, Maybe you have the overclocking features enabled but not used on one, which may raise the voltages just a bit.
    Maybe the fans on a system are more dusty and the cables are poorly layed out blocking airflow, so the heatsinks on one don't get to cool down as much as the other...
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      What about the case, fans, and airflow?
      This temperature difference is easily felt by the hand or fingers. You can always do a quick-'n-dirty temperature check...
      Typical IR thermometers won't read right- has to do with "emissivity."
      http://www.reliableplant.com/Read/14...ctual-ir-temps
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • mariushm
        • May 2011
        • 3799
        It will read close enough if you put some black tape on the heatsink to prevent the issues pointed in the article
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          Do you have the same bios on both boards ?
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Thanks, I forgot about that.
            But how do you cut little pieces of tape for all those little heatsink fins?
            EOL it...
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              same cpu cooler with same orientation?
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3264
                • Singapore
                i'm trying both boards on an open air test bench. both are clean and dust free. clocks and voltages are all left at stock. sensor voltage readings both read the same for both boards. just the nb and sb temp readings are vastly different.
                i have flashed the same latest bios 2302 for both boards. i have also thoroughly checked the bios settings both are using the same bios settings. as im keeping one as a spare so they have to have the same bios settings or the os might not boot if the bios settings are different heh~
                also using same cpu cooler on both boards same orientation. using stock intel cooler atm.
                as for temp measurement, i have a scythe IR thermometer that can either be usb powered or powered using a cr2032 battery but i have no idea how good or accurate that scythe IR thermometer is. any1 here got one of those b4 heh?
                i think i might try reapplying thermal grease and reseating the asus stack cool 2 heatsink system as i read around somewhere and saw some ppl complained that the asus stack cool heatsink warps the board and might cause the heatsink to no longer make good contact with the chipsets.
                • G0RIT
                  Reebok one GT40s treadmill lift motor runs at switch on
                  by G0RIT
                  Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
                  06-23-2022, 05:57 PM
                • tyl85
                  Imac A1418 late 2013 21.5" fan runs at max speed
                  by tyl85
                  Hi, i have this iMac issue
                  I've checked temperature by using macfans with no results
                  techtool pro shows me AMBIENT AIR TEMP FAULT
                  i'm going crazy, the mac runs very slowly
                  where i can find this sensor on motherboard?
                  thanks in advance
                  12-03-2024, 01:09 AM
                • DrDos
                  Unit runs but no speaker output kenwood KR-6030
                  by DrDos
                  I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                  09-14-2025, 09:57 PM
                • madan1
                  555 based power supply getting too hot
                  by madan1
                  Good day.
                  I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                  The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                  After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                  When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                  06-23-2025, 04:38 PM
                • larrysito111
                  dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                  by larrysito111
                  got here a liquid damaged alienware
                  the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                  so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                  so with the usb-c external monitor is getting to bios and OS
                  otherwise not
                  so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                  but still not the internal monitor
                  (tested 3V and 5V going to the...
                  06-12-2025, 04:16 PM
