ADSLoPSTN question
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    ADSLoPSTN question
    I have both ADSLoPSTN at home and in the office. I have not setup a VPN connection between them for security reasons. So i use pcanywhere to dial in to my computer and occasionally retrieve a file for someone. (its not very often).
    the dial in is done from and to the pstn part of the adsl line. However the speed is not the same as before the installation of adsl.
    I am wondering if the dial up connection is restricted in speed once adsl is installed?
    any ideas?
  • arneson
    • Sep 2005
    • 1267
    Re: ADSLoPSTN question
    Are you Filtered?
    My fax still works on a dsl line, probable only 9600 baud tho.
    It makes sense that something would have to slow down.
    Jim
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      yes i am filtered
      but i need 33.6 not 9.6
      • arneson
        • Sep 2005
        • 1267
        I'm not that up on this but tell me if it makes sense?
        Both my phone lines are Dslamed at the switching station not far from here.
        I'm only using one pf the dsl lines with a modem, router, voip and all my stuff.
        The other line has some phones and answering stuff.
        Even though it's a dsl line, it has no modem, and when I use it as a dialup it will connect at a normal speed, looked like low 40's but I wasn't paying much attention.
        I'll try it out again to be more sure.
        Jim
        • arneson
          • Sep 2005
          • 1267
          I just shut off the dsl modem and tried to connect to that line with an old 56 flex modem.
          I got nothing, not even a dial attempt. switched over to the unused dsl line and connected imediately at 49333.
          It could be that the second node has not been configured yet by the phone company.
          I have been told recently that my fax was shooting blanks also, kind of interesting.
          I was blasted totally out of the water just a couple weeks ago and everything had to be rewired and replaced so I'm just now recovering from that. Found another thing blown out just the other day.
          I will conclude that my particular modem would Not connect to the active DSL line at all.
          Jim
          • RolandVossen
            Kenwood Chef KVC50 / KVL60 / KVC5000 / KVL6000 / KVL6030 / KVL6050 kitchen machine repair
            by RolandVossen
            I am attempting to repair a KVC50 kitchen machine. Problem is that speeds 1..5 on the speed dial do not work at all (motor is not engaged). The 'reverse' and 'slow' settings on the same dial however work properly. I removed the dial, its PCB components seems to be basic: a potentiometer, a microswitch, a couple of LEDs and a couple of SMD diodes or transistors. The dial has three cables with three connectors that hook up to the motor controller PCB. One connector (3 pins) for speed, one connector (5 pins) for the LEDs, and one connector (2 pins) for a safety switch that is...
            03-16-2024, 03:55 AM
          • budwich
            Lithium 12v tool battery charger... no negative connection?
            by budwich
            I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
            03-18-2025, 09:12 AM
          • Demetrio87
            Legion t 5 front audio panel connection problem
            by Demetrio87
            Hi everyone, I hope someone can help me solve my problem, I have the case of a legion t5 where I have installed an asus tuf gamig a520m-plus motherboard, the audio connection cable on the case is an F_audio connector with 14 PIN , on my new motherboard the connector is a 10-pin AAFP, I saw that there are adapters on sale but at the moment I have no way of having them available in a short time, I made several attempts and managed to listen from the front headphones, only that there are some problems, the headphones are only detected if the microphone is connected, I definitely got confused with...
            12-08-2023, 12:06 PM
          • Nikan.e
            Inno 3d RTX2070 not detected - no I²C connection
            by Nikan.e
            Greetings and Salutations!
            I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
            The faulty DrMOS was removed, and the burned PCB area was milled away.
            All voltages are now good, but the GPU is not being detected.
            I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
            I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
            I thought these pins were used for communication during startup?!?
            On all...
            03-30-2025, 07:21 AM
          • spleenharvester
            Synology MR2200ac mesh router, UART connection - login details?
            by spleenharvester
            This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
            I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
            Code:
            sudo minicom --baudrate 115200 --device /dev/ttyS0
            09-02-2024, 01:19 PM
