HP, Sony: HP Laptop Design Presents No Battery Problems
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    By Edward F. Moltzen
    Courtesy of CRN
    (10/03/2006 0:18 PM EDT)
    Hewlett-Packard's system design and configuration prevents HP notebooks using Sony batteries from experiencing the same risks and hazards that other major laptop makers have, HP and Sony said Tuesday.
    The Palo Alto, Calif.-based computer maker and Tokyo-based electronics giant said in a joint statement that they have reviewed the use of Sony batteries in HP systems and found no risk of overheating.
    "HP and Sony have studied and agreed that there are currently no safety issues with regard to HP battery packs using 2.4Ah or 2.6Ah Sony cells, although no battery is immune to failure or overheating," the companies said in a joint press release. "As a result, HP determined that it is not necessary for HP to join the global battery replacement program that Sony has announced to address end-user concern related to recent overheating incidents."
    PeteS in CA
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • mkdj
    by mkdj
    Mark and model: ASUS X571
    Tests already made:
    - I have removed...
    07-14-2025, 09:16 AM
    Sony VAIO VPCEB4M1E/WI Notebook E Specification for Upgrade or Repair
    This specification for the Sony VAIO VPCEB4M1E/WI Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEB4M1E/WI boardview and VPCEB4M1E/WI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
    09-06-2024, 05:27 AM
  • techfreak9356
    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
    by techfreak9356
    09-14-2023, 11:10 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
