Random Power Shutdowns
  • old_wrinkly
    • Sep 2006
    • 22
    Hi, I found my way to the forum via a link from another forum thread about bad capacitors.
    I have a system based around an ASUS A8N-SLI which was bought last November. In April this year the mothebroard was replaced as the PCI slots had failed.
    In late June I powered up as normal one morning but within a few minutes there was a power shutdown. I tried this three times before eventually getting the system to run. I left the system running during the day and at first all seemed OK but during the afternoon the system shut down again without warning. At first I thought this might have been due to mains power problems as a couple of items, such as my bedside alarm clock, needed the time reset but others such as the electric cooker were OK. I ran the system again for a couple of hours and it seemed OK so assumed I had found the problem. I do incidentally have a mains surge protection device
    The following morning I powered up as normal and for about six hours the system ran as normal but then the shutdown again without warning (just like a power cut). I tried again and for 20 minutes it ran but then the same problem happened. On the next start up XP reported various files as corrupt and recommended I run CHKDSK. I tried this twice but each time the system got so far with CHKDSK and then shut down.
    I contacted the supplier who said "If this is a hardware issue, it is most likley to be one of three things. Either the PSU unit, the memory or the hard drive.
    Try running a memory test using the link below. Let the memory test run for a good few hours over and over again.
    If there is faulty memory it will show the errors, if it a faulty PSU it's likley to restart as it has been doing. If it is a hard drive issue this shouldn't in theory show up.
    Your drive is probably a maxtor in which case you can go to maxtors website and download testing tools".
    I did as they suggested but no fault was reported.
    The random shutdowns continued over the next few weeks as I attempted to try and identify the problem. Sometimes it would run for hours, other times only a few minues. At one stage it failed three times during POST.
    On 12 July I emailed the supplier and told them I had tested, with a meter, all the connectors/leads from the PSU. Initially with no load and then progressively adding devices until a full load. All the readings show the PSU working within it's stated parameters.
    I had also run the system with ALL DRIVES except the floppy removed (used Windows ME boot floppy) and still suffered power shutdowns. In addition, I installed Windows on an old IDE drive and run the system with just this and the floppy connected and still had shutdowns thus proving it was not drive related. I had also checked within Windows and confirmed that the CPU is not spiking and confirmed the BIOS settings are correct.
    Finaly on 18 July they agreed to rma the system back. On 24 July I received the following email from tech support.
    With regards to your PC, I attached a maxtor IDE hard drive and loaded windows XP and have been running various tests over the last 4-5days since i recieved the PC. I've been running sisoft sandra and windows memory tester and our own burn-in-tester. It has not failed any of these tests so i can only assume the faults you have been having are down to some other device/software that you are using.
    At this point we would be looking to charge given the amount of time that has been spent on your PC.
    To cover Labour and the postage costs we will have to charge £50(GBP).
    Given all the info I had supllied to them about what I had tried I was amazed that they only seemed to have done a superficial check (don't even know if they ran the system 24/7)and had not tested any of the components or swapped bits around to see if something failed. I emailed them to say I didn't agree with their finding however, they refused to budge and in the end I agreed, under duress, to pay the cost and get the system back rather than run up daily charges. I had also told them I'd built three systems of my own, carried out several upgrads etc. so I had some experience of fault tracing.
    On it's return I gradually rebuilt the system and software and initially it seemed OK and I wondered if the transport had moved something. Finally I decided to give it a real go and run it 24/7 whilst file downloading. For just under eight days it was OK and then shutdown. Since then it has randomly shutdown three times with the gap varying from a couple of hours to over 36 hours. At the moment it has been running for just over 54 hours and I'm going to leave it until it fails. I'm also running my wife's PC in parallel to see if that is affected when it shutsdown, just in case it's a mains power issue although I think this is highly unlikely.
    The interesting thing is that at the moment when I restart after a shutdown Windows starts as normal so it looks as if it isn't seeing it as a false shutdown or questionning the free space data written during normal shutdown.
    I've even begun to wonder if the power button of the case is somehow forcing a shutdown.
    If I am to have any chance of sending the system back again I will have to identify exactly what is causing the shutdowns and be able to prove my theory.
    I could try another PSU, which would be the most obvious thing, but as I haven't got a suitable spare I would have to buy one and I'm loathe to do that just on a whim.
    I don't think my mobo suffers from bad capacitors although I haven't gone over it with a fine toothcomb.
    It is very much a longshot as I think I've covered virtually all of the obvious things but if anyone can offer any help on how I can identify the problem I would be most grateful.
    ASUS-A8N-SLI Rev.1.02
    BIOS:Phoenix Technologies, LTD BIOS Revision 1014
    650W QTEC 14103 Triple Fan PSU
    AMD Athlon Dual 3800+
    2GB DDR PC 3200 RAM
    256MB RADEON x700 tV/dvi PCI-Express
    1 x Maxtor 6Y160M0 SATA 160GB drive
    1 x Maxtor 6Y200M0 SATA 200GB drive
    1 x Maxtor 6Y200PO IDE 200GB drive
    Western Digital WD2000JB IDE 200GB
    Maxtor Pioneer DVD-RW DVR-111D
    Samtron 19" TFT Monitor
    XP Pro SP2
    Outpost Firewall
    NOD32 Anti-Virus
    Age is a high price to pay for maturity
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Random Power Shutdowns
    To begin with, the Qtec is IMHO crap at it's best, at least their earlier build are similar to some realy ugly Deer brands wich are famouse to be hardware killers and do not have adequate power. Considering the price tag of 35€ for an 550w tripple fan unit i think it is BS. So i support your decision, to spend some money on something more beafier like FSP, Seasonic or equvalent brands (personally do highly recommend the Seasonic s12 series and Amacrox Frei Erth, but today i can`t give a real suggestion other than a new and imediately recaped one).
    Before you want to spend money, i would use a HDD chek utility, to make shure your hdds are fine. I know sutch problems, sutch rare failures are hardly to track down in an economical ammount of time......this is always the problem with todays systems. And this is one of the reasons i build my systems by my own. If something is bad i buy a replacement, for 50 bucks you can get easily a decent Seasonic s12 PSU.
    But hey i realize, that you have 4 HDD`s in your box. I think this is probably to mutch for an 650w PSU wich cost`s abouth 38€. Hell i don`t belive that this psu can give more than may be 350w, and probably close to nothing on the 12v rail. If possible disconect some HDD`s to reduce power consumption, if this cures the problem you have probably crappy PSU.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      i agree on the psu. lets see what happens after you replace that
      if you are having dodgy power then best to get a quality UPS also. i would recommend an APC smart ups. i dont know what kind of surge protector you have but i would not call anything less than an APC Line-R a decent surge protector. anyway i dont think that is the problem but it would be good to protect your nice system
      • pentium
        • Mar 2006
        • 2778
        do you have an APC?
        I had that peoblem whenever I switched something with a high load on or off.
        It turned out that one of the dip switches on the rear of the unit had been changed and the small voltage fluxuation of even the furnace coming on was enough to trip the unit into battery mode. The thing was that at the time the battery was not installed.
        Find Nedry!
        Check the Vending machines!!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          yeah i have 8 including the ones at work various types (the rest are MGE and Patriot, also 2 Line-R.
          i prefer the smart ups like these ones
          http://www.techmati.com/reviews/SUA1000RMI2U/index.htm
          i dont have problem except for the line-r which i had to change a dipswitch at the back, they were mostly unneccessarily trimming the voltage down and making a loud buzzing when they did which is not ok for residential.
          • arneson
            • Sep 2005
            • 1267
            In addition to all of the power considerations is the temperature factor.
            How warm is the air coming out the back when she fails?
            What are the readings on the board monitor software for fan rpm and temps? or voltages if it reads them?
            When a tech checks your board only I assume it's on a bench, when you test it I assume it's in a case, big difference.
            Jim
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              even if voltages are ok the psu could be quite noisy due to bad caps.pop the lid and have a look.
              • old_wrinkly
                • Sep 2006
                • 22
                Thanks for the replies.
                gonzo0815
                See my original post.
                I had also run the system with ALL DRIVES except the floppy removed (used Windows ME boot floppy).....
                So although I have a number of drives and this could be pushing the PSU that doesn't seem to be the actual cause. Replacing the PSU might still be a good idea of course as this doesn't rule out the possibility that the PSU fails every so often.
                Acording to Qtec Support the PSU has the following outputs:
                Output current +5V [A] 45 A voltage +/- 5%
                Output current +12V [A] 25 A voltage +/- 5%
                Output current -5V [A] 1 A voltage +/- 10%
                Output current -12V [A] 1 A voltage +/- 10%
                Output current +3.3V [A] 30 A voltage +/- 5%
                Output current +5V STB [A] 3 A (max 2,5A); voltage +/- 5%
                Maximal total power for 3.3 and 5 combined [Watt] 325 Watt (max 235
                Watt)
                As I understand it from reading various threads/articles the voltages on the PSU leads should be within +/- 2% of desired, better yet 1%. If any voltage is off by more than 2%, then the mobo cannot properly supply the CPU and chipsets with desired voltage or current, and the system goes into a kind of "stroke" and shuts down or hangs. There is one critical lead on the power plug.. the PSGOOD lead. That is a +5 volt signal to the sensor chipset, which enables the mobo to become active after the PSU stabilizes its load. If the signal is too low, the mobo will not function, or may shut down prematurely. The current on this lead is very light, and if the mobo has an excessive load on that lead that will cause shutdown.
                Did have a friend check the PSU with a meter and couldn't find anything but that was without any load and just a snatch reading.
                arneson
                Don't know how warm the air is coming out the back but it failed when I had the side cover off so again don't think that is the cause. As for the other items you mention I have now installed ASUS Probe to check what's happening (never bothered before) and set the History to record. Currently all is OK but will be interesting to see what the History shows.
                Don't know if the supplier tested the system on the bench or not, they wouldn't tell me.
                willawake & pentium
                The anti-surge protection I have is one I acquired whilst working for BT(British Telecommunications) about 12 years ago. When new this would have been of very high quality. As both my Desktop PCs are powered from the same 8 way extension lead and protected by the same UPS/APC I am running my wife's PC in parallel just to see what happens with that when/if my PC shutsdown.
                Not sure where everyone is based so terminology could be different between us. What for example is an APC. I understand UPS as uninterruptible power supply (don't have) and think APC is a trade name???
                On the subject of a replacement PSU. I am prepared to get another one but I'm a bit dubious about spending too much money at this stage just to see what happens.
                Looking at a couple of online sites here in the UK the Seasonic s12 600W Silent ATX 2.0 would cost between £89 GBP-(€131) and £105GBP-(€155) which is quite a bit more than I would like to pay at the moment, so I'd like to look for a more wallet friendly PSU that would do the same job. I'm not incidentally a gamer so my demands are quite basic. Do I need 650W or would 600W be sufficient if it's a good PSU.
                Out of interest just had Blue Screen Of Death on system with Machine_Check_Exception but system carried on running. No abnomalties I could see on the ASUS Probe measurements.
                2GB DDR PC 3200 RAM
                XP Pro SP2
                Outpost Firewall
                NOD32 Anti-Virus
                • davmax
                  • Dec 2005
                  • 899
                  Your system exhibits the charcteristics of capacitor failure, however other components do cause the same type of problem.
                  Are you able to borrow a PSU? Is it possible to swap out the one in your wife's system for a test?
                  160Gb WD SATAII Server grade
                  Nvidia 8500GT 256Mb
                  Samsung 18x DVD writer
                  33 way card reader
                  Windows XP Pro SP3
                  17" Benq FP737s LCD monitor
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Why do you looking into a 600w PSu? Your system isn`t drawing perhaps not a single what beyond the may be 200 to 300w if i be generouse. So buy a decent quality brabded PSu wich can deliver the wattage printed on it i think you should be ok with anything beyond 350w. So my suggestion would be a Seasonic S12 380w. This would eb far enough. And theis should be availiable for abouth 50€. An Amacrox Free Earth 420 would be sufficient too. The problem with this Qtec is not that the 600w isn`t sufficient wattage for your system, rather than this Qtec probably can`t deliver ynthing near this wattage at the 12v rails, wich are the most important ones for your system.
                    I counted your system for an gnenrouse 23A load on the 12v line. Now this Qtec is rated @25A on 12v, but the most power of it is quoted at the 5v rail. In other words your system can only draw as little as 300w from 12v line from this Qtec pupy. And this only, if their ratings are honest ratings wich i have seriousely doubths.
                    Now immagin if they have used to small and bad branded caps and it should be obviousely where most probably the problems is.
                    Anyway, you have no other posibilities than changing component by component. And i would start fore shure at the PSU.
                    • old_wrinkly
                      • Sep 2006
                      • 22
                      davmax
                      Are you talking about capacitor failure on the motherboard or within the PSU.
                      If I have to check the motheboard I will have to wait until it switches off and then hope that my eyes can detect anything amiss. Not s easy to see small components as you get older!!
                      I did consider trying the PSU from my wife's PC but didn't think it would be up to the job. Details are:
                      ATLAS FP-300WE(P4)
                      +3.3V 20A
                      +5V 30A
                      +12V 16A
                      -5V 0.5A
                      -12V 0.8A
                      +5VSB 2A
                      3.3V&5V Total 150W
                      I put this in the system when I built it with an Athlon XP 1800+ (1.55GHz) & Soltek SL-75DRV5 motherboard in July 2002.
                      gonzo0815
                      You certainly know your stuff as far as PSU's are concerned. I have to confess it's not something I have ever got to grips with.
                      I've looked on eBay (UK) for the Seasonic SLI 430W PSU and that retails at around £50(GBP)-73€ and the 380W at £46(GBP)-68€. plus delivery. I live in a rural area so don't have any local stores apart from one and I don't know what PSU they would sell but I have emailed them.
                      Looking through various forums I see that Allied, Antec, Enermax, Silent, Zalman, Vantec, and In-Win are names that come up quite often as good PSUs. Don't know how they compare one to another in quality and price. Haven't so so far found a UK site that lists the Amacrox Free Earth 420 you mention.
                      One slight problem is that the warranty expires on 10 November so if I am going to bounce the unit back I have to be sure of the problem before then.
                      The alternative is to discount the warranty and change component by component until the problem disappears and hope it doesn't get to expensive.
                      PS Have changed a couple of things in my signature but nothing that would affect the power load.
                      2GB DDR PC 3200 RAM
                      XP Pro SP2
                      Outpost Firewall
                      NOD32 Anti-Virus
                      • old_wrinkly
                        • Sep 2006
                        • 22
                        Just a quick update to say the local firm have replied and suggested the antec smartpower 400W PSU that retails for £39(GBP)-€58 including VAT. Any thoughts?
                        They also charge £35(GBP)-€52 including VAT for fault diagnosis.
                        Could be worth speculating if they can give it a good check over, especially if they find the fault.
                        2GB DDR PC 3200 RAM
                        XP Pro SP2
                        Outpost Firewall
                        NOD32 Anti-Virus
                        • gonzo0815
                          • Feb 2006
                          • 1600
                          Well, this Antec is not nbad at the begining and it is well build &desinged. But theyr decided fore some reason to use the crapiest capbrands possible, wich will cause a relatievely fast going down of this units. I know, that many people still recommend Antec, but i would certainely do not. Do a search on this forum to get thepicture. But ok, for a year it should work.
                          Well those Seasonic are pretty expensive in UK.......may be you can get some FSP (Fortron ) ones, i think 350 to 420w should be ok, but make shure it is a ATX 2:0 surply with decent 12v juice, e.g. more than 24A (FSP`s Amps are honest amps ).
                          • davmax
                            • Dec 2005
                            • 899
                            The first suspect would be power supply caps, next would be motherboard. Hence the suggestion to tried another power supply without spending money to see if the problem goes away. If it does not then look elsewhere.
                            Yes the wife's power supply is a little light. Not worth the risk for you.
                            I not sure whether you want to bother with the following. I bought a lower cost power supply, opened it up and replaced the caps for good quality ones. See my signature for 500W Delux.
                            I do not have any problems with this unit it is well made. However cannot find any offered on eBay.
                            Couple of ebay examples:
                            http://cgi.ebay.com.au/New-Hytec-ATX...QQcmdZViewItem
                            http://cgi.ebay.com.au/NEW-EZCOOL-50...QQcmdZViewItem
                            the 120mm fan types are nice and quite.
                            The Delux group produce a huge range of products. Link to their site and the power supply I am using, they have other models: http://delux.manufacturer.globalsour...GetProduct.htm
                            regards
                            Nvidia 8500GT 256Mb
                            33 way card reader
                            Windows XP Pro SP3
                            • old_wrinkly
                              • Sep 2006
                              • 22
                              Thanks for the update.
                              You anticipated a question going through my mind as to what the logical order would be for changing things out. Was trying to get my head around how far I would be prepared to go, money wise, before I give it up as a lost cause and either live with it or dump it and start over again.
                              It really is strange, or at least to me, that it can run for days at a time, well at the moment at least, then suddenly fail, or is this what would be expected with bad caps in the PSU or motherboard?
                              What's the chances that the CPU could be faulty?
                              Don't think I want to go through the changing caps process, not very good with the soldering iron.
                              Been following through gonzo0815 posts. He/She is in germany and it seems not all the PSUs mentioned are easily available in the UK and where they are the price seems higher.
                              See you are in Australia so possibly the same problem would exist. Did take a look at the Delux Group site you linked to and tried a search on eBay(UK) and Google but didn't come up with any retailers.
                              Did find the following site for sale of FSP units :FSP PSU For Sale
                              These look a reasonable price but not sure which one would be best but probably the CA-004-SK, CA-003-SK or CA-005-SK would fit my budget as a first step.
                              2GB DDR PC 3200 RAM
                              XP Pro SP2
                              Outpost Firewall
                              NOD32 Anti-Virus
                              • davmax
                                • Dec 2005
                                • 899
                                Yes caps can cause intermittent failure. However other components can also. It is a process of elimination. Hence an effort to spend a minimum by using borrowed parts swapping. It does seem that you should get a better power supply anyhow.
                                Looking at the link you supplied The Seasonic CA-003 will meet you need also the AKASA CA-014.
                                Once you have swapped the power supply you will be able to eliminate that source. The problem should not be the CPU. Unless the max temperature is being exceeded. Have you checked the system and CPU temperatures? If you have not installed temperature monitoring software you can still find out. Typically a modern computer bios will display temperatures. Restart the computer and press Reset (F2 on some motherboards) to enter the bios. Go to the Health section (the usual name) and check the temperatures. The CPU temperature should not exceed 70C. If it does the problem will be incorrect installation of the heatsink/fan assembly.
                                Nvidia 8500GT 256Mb
                                33 way card reader
                                Windows XP Pro SP3
                                • gonzo0815
                                  • Feb 2006
                                  • 1600
                                  I have found this unit at ovc: Seasonic S12 430W Silent ATX2.0 Power Supply (CA-000-SS) if this one fits your budget take it. Those FSP units are very decent too. But from those i would certainely go for an 80%+ efficiency ( e.g. the Green power or the Bluestorm). This gives benefits in several areas: less heat, less noise, lower power consumption.
                                  Both brands are IMHO top notch ones and should last the statd MTBF time. And you have than ruled one possibly source of failure out of your rig fore several years.
                                  But as mentioned before, chek your temps (e.g. with speedfan, MBM etc.) prior to this. Use some torture tools to stress this rig, e.g. Prime 95, 3D mark03 in looping mode. If you are using Prime95, do a custom torture test, gie it abouth 1800mb of your ram or even more. This will make your system starting to use swap memory on hdd exzesively. And this can rule out many failures, you usually won`t catch with ther tools. And with 2gb of ram, there it is possible, that a failure will only occure if you are using the whole ram. And with 2gb this certainely won`t occure that mutch.
                                  • davmax
                                    • Dec 2005
                                    • 899
                                    I have just seen Gonzo's reply and wondered why he got a different result. When If irst tried your link it took me to the home page. Now it takes me to sparkle Blue Storm etc. They look a good price. You may prefer to go to the Blue Storm CA-005 CK to give the higher power.
                                    Nvidia 8500GT 256Mb
                                    33 way card reader
                                    Windows XP Pro SP3
                                    • tazwegion
                                      • Jun 2006
                                      • 444
                                      When you performed this load test, was the CPU running @ 100%? doing so gives the best indication of voltage supply variance IMHO
                                      4 HDD's amongst other components would add to case ambient temperature, exactly where you source the air supposedly to cool your CPU (unless you have blowholes/intake pipes etc.), I agree with davmax relating to temperature checking (especially @ 100% CPU load)
                                      Viva LA Retro!
                                      • Newbie2
                                        • Sep 2005
                                        • 885
                                        Since you're in the UK, this would probably do. QTEC is bad quality, I'm guessing your problem is the PSU.
                                        550W
                                        http://www.misco.co.uk/productinform...0ATX%20PSU.htm
                                        650W
                                        My gaming PC:
                                        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                                        ASUS M4A77TD AMD 770 AM3 Motherboard
                                        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                                        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                                        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                                        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                                        ASUS Xonar DG 5.1 Channel PCI sound card
                                        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                                        Antec Three Hundred Mid-Tower Case
                                        Microsoft Windows 10 Pro 64-bit
                                        Microsoft Windows 7 Ultimate SP1 64-bit
                                        • h0m3w0rk
                                          Random Shutdowns/Startup Failure with Corsair SFX 450
                                          by h0m3w0rk
                                          I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                                          For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                                          02-09-2025, 03:19 AM
                                        • turborex
                                          HP Envy 15 AS-105 random shutdown. (Core I7-th gen 2017)
                                          by turborex
                                          Hello folks.
                                          I bought this machine brand new. It ran fine for nearly 6 years. Lately, it has been plagued with random shut downs without warning and I have nearly pulled my remaining hair out trying to troubleshoot the issue.
                                          I have no electronics knowledge though if anyone can guide in the right direction this would be awesome.
                                          Description:
                                          ----System will randomly turn off. There is no specific timing. Sometimes it can run normally for a couple of days without the issue but once it starts; it becomes more frequent, and then it sort...
                                          09-19-2023, 12:51 AM
                                        • kacangpolo
                                          Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
                                          by kacangpolo
                                          I have problem with my laptop, with code board X415EA 2.0,
                                          laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
                                          I did :
                                          1. Flash Bios
                                          2. RTC_RST 3.3V
                                          3. LID_SW 3.3V
                                          4. WLAN_WAKE# 3.3V
                                          08-26-2025, 04:42 AM
                                        • cappernicus
                                          Satellite r945-p440 - Hard crash coming out of sleep
                                          by cappernicus
                                          Toshiba Satellite r945-p440
                                          Motherboard: FAM2SY2 A3256A
                                          I do not have a schematic or board file
                                          I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
                                          04-16-2025, 05:31 PM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
