rotating screen on linux mint?
    Hi guys i need help please,I've been running Linux Mint till today with no problems but today i miss the rotating screen i did reinstalled linux mint but can't see the rotating screen like i use to in the video control,
    i have Intel Graphics Hd 2000, any help would be apreciated.
    Re: rotating screen on linux mint?
    Look up compiz fusion for your version of linux mint.
      Rotating screen? You mean making the image go upside down? Check the intel drivers, my ATI has it there, also i used to have a laptop with intel x3100, and the option was in the video drivers.
      I can put text here?!
        Thanks Professor, i have this when i type ''compiz fusion'' in the terminal,
        what does this means? Thanks.
          DJduck; i don't think this is Ati!,it's Intel graphics from lenovo, i have the video drivers on a stick, but it says for windows xp ,since i'm running linux mint mate alone,no win xp i don't think i can run any win xp drivers.
          But what i don't understand is that when i first installed same linux as i'm running now i had the monitor control to change left right 180º also had the choice of changing screen colours resolution,as you can see in the pic atachement,resolution,Refresh rate and rotation switches are frozen and when i click detect monitors it just doesn't show anything.
            Do you have it installed on a tablet?
            What Desktop are you using? Mate? Cinnamon?
            I have Cinnamon (I think). In the system tray (lower right) click on the "^" symbol, and select:
            Settings > Applets > Display
            Checking the box will put a display icon in the system tray. From there you can rotate the screen.
            If you are using a touchscreen, it will not rotate that. If you need to do that, I know a work-around for that.
              http://community.linuxmint.com/tutorial/view/1148
              To make it easier on ya installing the packages...
              Code:
               sudo apt-get install compiz-gnome compizconfig-settings-manager fusion-icon compiz-plugins-extra libdecoration0-dev
              Install, enable and have fun!
                Code:
                I apreciate Professor i did the above instruction i was able to get all those installs but still no avail. i type xrandr and i get this in the pic what you think?
                  compiz requires 3D, are intel drivers loaded? check additional drivers or restricted drivers.
                  Also are you sure compiz is enable check the setting it may be running defaults, an option should be there to enable the cube and allow rotating.
                    Hi Professor;how can i load the driver for Intel in the linux,also can you be more specific on the enable cube sorry if I'm not that much savvy,
                      me again i get this on the screen when i try to aply on the monitor preferences, see atach.
                        Run these in term and post back what you get.
                        Code:
                        inxi -Gx
                        Code:
                        lshw -C video
                        Code:
                        lsmod
                        I found another guide a bit older but worth looking at.
                        http://community.linuxmint.com/tutorial/view/506
                        It should be under settings from the system menu called "additional drivers" or "restricted drivers" you can run a search from the menu to find it.
                        Then for compiz, you'll want to look for CCSM *CompizConfig Settings Manager* It too should be under settings or system control panel. This is where you select the options for compiz like rotating cube, wavy windows and so on.
                        I think you can run compizconfig in term for quicker access but I'm not sure.
                        Are you using dual monitors?
                        If not the it sounds like your xorg.conf is fubar.
                        Go to the display settings and reset your resolution then follow by restart.
                        if it doesn't work, post your xorg.conf from /etc/X11/xorg.conf
                          [QUOTE=Mad_Professor;309648]Run these in term and post back what you get.
                          Code:
                          inxi -Gx
                          Code:
                          lshw -C video
                          Code:
                          lsmod
                            [QUOTE=ivtec;309788]
                            Code:
                            inxi -Gx
                            Code:
                            lshw -C video
                            Code:
                            lsmod
                            This one is from Display, System information
                              Hi Professor It´s me again on video i was able to launch Properties,
                              i i can wright configurations on each box can you advise what can i write
                              TYPE
                              NAME
                              COMMAND
                              COMMENT
                                OK Professor, after so much head scratching i found out the problem was not the OPS but the monitor itself changed the connection to other monitor and it recognizes it right away, then i unplugged the monitor that i was using from the power and from the VGA cable turned on the PC and it also recognized it with the rotation scream resolutions and everything is OK. anyway some times a simple thing turns out to be a big thing with no solution in sight,i made so many linux install for nothing,anyway i apreciate your help.
                                  Hi guys it's me again,i have same problem again i type Xrandr and get the same as in the pic that i posted bifore,although the screen did not change and stayed where i wanted it, but can't control nothing as before,i had it but something is changing it,i guess if it changes i have to do what i did before change monitors and go back,it's kind of weird i don't know if it's the monitor or the linux software.
                                  https://www.badcaps.net/forum/attach...1&d=1359776823
                                    In the future, instead of taking a picture of your screen, copy and paste the text to the post. If you want to output the results of a command directly to a text file, do this:
                                    Code:
                                    lshw -C video > lshw-C-video.txt
                                    The file will be in your home folder. The .txt is just so Windows can recognize the file, and open it.
                                      Code:
                                      Thanks TimeRetire; i was able to solve the problem by getting an atx power supply that i had hanging around connected a cable to the 12v output yellow+black and pluged in the 12v monitor with a power strip sw,
                                      what was causing the monitor to loose the monitor control settings was that i've splited the DVD/cd's cable output by chanting the cable and connected it to the monitor,but i guess when the pc turned on it would turn on the mother board first then the dvd/cd,since the monitor has to be on before the mother board, it would loose the monitor controls so it would not detected the monitor even thought the monitor was working write.
