Core 2 Duo E6600 Overclocking?
  • ncovert
    • Feb 2011
    • 291
    Has anyone overclocked this chip? I have it in my main rig and was wondering how far I could push it with 2Gb (2x1) of Samsung PC2-5300 and an MSI G41M-P33 motherboard. PSU is classic Acbel 550W. Thermaltake AlCu rifle bearing 92mm cooler. Any suggestions on how far I could OC?
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Core 2 Duo E6600 Overclocking?
    Personaly I use in my main box a Q6600.
    But just the model of your MB does not sound as great platform for acrobatics.
    My advice .. keep it at default.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      wont know till you try.
      look up cpuz for a good idea of what to expect.some of us have validated our overclocks there.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        based on ur mobo and ram info. u shud be able to overclock it to around 3ghz using 333fsb and 9 multiplier. vcore needed shud be around 1.35V.
        however, as ur mobo only has 3 phase power, u shud not try any extreme oc past 3ghz lest ur board catches fire like the asrock fm2 mini-itx which is currently causing an outrage around the community.
        if u can find a better board with at least 6 phase power, overclocking ddr2-800 or 1066 ram and a 120mm or 140mm heatpipe tower cpu cooler, u shud be able to clock it to around 3.6ghz to 3.8ghz. but always be careful. cpus start to give off tons of heat as u approach the 4ghz barrier.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          My E4500 didn't need more than 1.2V for 333x9.0. (2997 Mhz)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • ncovert
            • Feb 2011
            • 291
            Right now, it is running stable at 2.7 ghz (300fsb x multiplier 9).
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              If the board allows it, do it. But don't push it too far, if you want to then get some cooling on the cpu vrm.
              I can put text here?!
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                I got my C2D 6750 to 3.2, 3.3 if I really try, but I have to keep a blower on the northbridge heatsink (nforce 750i) or it would burn up, cause I maxed out the voltage on it. But right now, it maxes out at about 49C
                ok I actually have two high speed fans on it
