Hard drive PCB for data recovery
+ More Options
Posts
  • uberplasma
    • Oct 2011
    • 85
    Hi everyone
    I have a seagate ST9250410AS with a bad controller, according to seagate support and the diagnostics they gave to run and the error codes generated the platters are fine as is the data, just a bad PCB, they can recover the data for $ 1200, which i don't have. So i found a PCB with same firmware except it is from a 5400 rpm hard drive, where as mine is a 7200. Are they compatable, for at least long enough to pull my data?
    Cheers
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Hard drive PCB for data recovery
    probably not.
    sigpic
    (Insert witty quote here)
    • uberplasma
      • Oct 2011
      • 85
      thx
      thought so
      cheers
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Hi, well you can try but don't get your hopes up.
        You must have a PCB matching as well as possible, even firmware
        (Don't use a PCB not made for your drive, especially one made for a different motor, they use different current and maybe even voltages!)
        Here is a data recovery request I sent after trying to swap PCB with one bought on eBay myself a few years ago
        MANUFACTURER: HTS421280H9AT00
        CAPACITY: 80
        PROBLEM DESCRIPTION:
        The drive is identified on startup by the BIOS as HTC4"1"8 H)AD0
        Once inside Windows the size of the drive is recognized (80GB) and the partitions
        But they can not be read, I tried to recover data using RunTimeSoftware GetDataBack NTFS
        It was able to read the metadata and list all files, but they where all corrupt when I tried reading them after recovery
        PREVIOUS ATTEMPTS:
        A donor PCB was bought, exactly matching MLC number (DA1303)
        And also matching the first two rows of numbers on the PCB sticker (0A26790, DA1187B)
        On first test drive was not found at all, so I desoldered the eeprom from the original PCB and put it on the new one
        The drive was now identified as before; HTC4"1"8 H)AD0 and filesystem was unreadable from Windows as before
        Next I swapped over the flash memory IC aswell, but there was no change
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I doubt the 5400RPM and 7200RPM are compatible, because they motors are different.
          • retiredcaps
            • Apr 2010
            • 9271
            I suggest you look on ebay and try to get an exact match. One ebay auction says
            "This model PCB board has a memory chip which holding the unique Hard Drive configuration info. We need to copy this memory chip info to the new board."
            --- begin sig file ---
            --- end sig file ---
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i can look in my pile.
              i save drives just for this kind of work.
              you will need to swap the eeprom from the old board on these.
              • uberplasma
                • Oct 2011
                • 85
                Hi
                so unless i lay out the $ 15k for the recovery hardware(sold a few kilometers away) or $ 1200 for seagate to do it the data is probably lost.
                I did find a matching hard drive speed , model, part # and firmware, only difference is serial number, should i even bother buying it. Even a slight chance at recovering the data(childrens pics) is better than nothing. seagate sent me a replacement drive, so i can't be desoldering eeproms unless I am very careful and do it so they don't detect it.
                thx
                • retiredcaps
                  • Apr 2010
                  • 9271
                  I found Scott Moulton's videos especially part 1 - 7 on hard drive recovery to be valuable. I haven't watched his other stuff yet, but they all look interesting.
                  http://www.youtube.com/user/SuperFly.../videos?view=0
                  He also explains the serial number part at
                  • smason
                    • 1652
                    http://www.youtube.com/watch?v=Kx-D1...824295&index=1
                    At about 6 minutes in, Scott talks about boards and firmware and dates.
                    He says if the board manufacture date is different from the drive by as little as 2 weeks, you could be in trouble.
                    • capsasdf
                      • new jerry
                      Some older drives have the same basic information on two PCB boards of the same model, provided that both drives were made at about the same time, before more unique adaptives were programmed into the next line of drives. If one of the PCBs fails, there is some chance of making a recovery by simply swapping the boards of the two drives. However, hard drives have contained "customized" firmware on at least an occasional basis since they've become a consumer product, so the chances of a straight "board swap" working are low. So in most cases you also need to move the old PCB's BIOS to the replacement one.
                      Check this article: http://www.hddzone.com/fix_hard_drive_pcb_board.html
                      • Uniballer
                        • Jul 2013
                        • 334
                        I had an old Antec power supply fail in a computer at my workplace. It took out everything directly connected to the power supply (hard disk, DVD drive, motherboard, case fan), but the CPU and RAM were OK. I bought a Seasonic power supply, similar motherboard, hard disk, etc to get the system running again.
                        I wasn't sure if there was anything valuable on the hard disk. I pulled the PCB from the drive (Seagate ST3500413AS) and there were a bunch of scorched components and traces near the power connector. I couldn't figure out how I was going to even identify them, let alone replace them. So I found a PCB on ebay (Seagate 100535704 rev C) on ebay ($20 best offer, free shipping). I first tried the new board as is and it spun up the drive but it wasn't recognized by the BIOS. I transferred the EEPROM (25FU406B - 8 pin SOIC - upper left corner in the image) from the old board to the new one and the disk now works just fine. I guess I kinda wasted my time though because there were no files of any value on the drive that hadn't already been backed up.
                        Now here is the question: Would you trust the repaired hard drive in an active role? Or is it now damaged goods? How would you test it to qualify it? Thanks for your opinions.
                        • Uniballer
                          • Jul 2013
                          • 334
                          I erased and scanned the disk with MHDD V4.6 and didn't find any problems. All of the SMART tests pass. I installed a UNIX operating system on it and beat the hell out of the disk for a while. No problems that I can see. I guess I'll beat the hell out of it for another week and call it good if it is OK. I just wish there was a stand-alone disk exerciser the way MEMTEST86+ is for RAM.
                          • abajor
                            Attempting Data Recovery WD20EARS series HDD Reads as 0 byte drive.
                            by abajor
                            I was wondering if there is a knowledge base on troubleshooting HDD failures and when it might be viable to try certain repair/recovery techniques.
                            I recently got a WD20EARS 2TB Drive from a customer in hopes of retrieving data. The drive reads as zero size, I can't hear any head activity but it does appear the platter is spinning I can feel some gyroscopic action picking up the drive.
                            As a shot it the dark I bought a donor board and swapped the rom chip. Same issue zero byte drive.
                            I'm assuming that the armature is no longer functional internally so no data can...
                            05-18-2024, 08:35 PM
                          • reformatt
                            Intel iMacs, 3rd party SSD failures and Fusion setups
                            by reformatt
                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                            12-18-2024, 10:34 PM
                          • kingiii
                            Possbility of data recovery, is it true?
                            by kingiii
                            Hello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not...
                            07-02-2025, 02:29 PM
                          • karto95
                            Repairing a Seagate hard drive with damaged logic board
                            by karto95
                            I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                            I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                            If anyone has any suggestions or experience with this...
                            03-21-2023, 04:05 AM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
