RAID 0 vs RAID 5
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    RAID 0 vs RAID 5
    Consider this a side thread to my other thread
    By next week ( whenever the drives and cables some in) I'll be moving from a single 320gb drive to 3 74gb WD raptors.
    I actually have 4 drives coming, however, the case only has 3 HDD bays and both the 320gb drive and the 4th raptor have new machines to go into.
    Controlling the drives is a 3ware 9500 w/o BBU.
    I am decent on my file backups...
    I have 4 raid choices... and here's how they stack up:
    RAID 0: No redundancy... but neither did a solo drive. Fastest choice. Gives me the most storage possible
    RAID 1: Slowish. limits me to 74gb of space. Double redundancy... but since this is my main rig and not my file server (which DOES have RAID 1), I don't see the need
    RAID 5: Initially Sounded good. Has fast reads but slow writes. Also subject to the write hole since i have no BBU (and such is more $$$ than it is worth).
    JBOD: Kinda disregards the point of having a dedicated HW raid controller... if I were to do this, I'd just use the two twin-port silicon image controllers on the board. Better redundancy than RIAD 0 w/o the speed boost.
    Hotspares: I've heard bad things about these... and for the same reasons as RAID 1, I don't see the point for this build.
    Given those choices, I ruled out RAID 1 and JBOD pretty quick. I was leaning towards RAID 5 but RAID 0 sounds like a safer bet.
    So... given what my situation is, which shall I choose? 0 or 5?
    9
    RAID 0
    0%
    1
    RAID 5
    0%
    3
    Other (even though they were ruled out by me)
    0%
    4
    No comment
    0%
    1
    sigpic
    (Insert witty quote here)
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: RAID 0 vs RAID 5
    It depends on what you're going to use it for.
    How big are the new drives?
    Raid-5 is good for smaller drives, but if over 1TB, you're asking for trouble, I was lucky running 6 1TB in raid 5 for 3 years, before 6 months ago I moved to ZFS.
    why not just jbod, and get ZFS. It comes on bsd distros, zfs on linux, zfs fuse, opensolaris, openindiana.
    You can do raidz or z2, and have guarantee data integrity with zfs, if that's important to you. Only downside is you need a lot of ECC ram.
    It really depends on what you're going to do with them.
    • c_hegge
      • Sep 2009
      • 5219
      With 3 drives, RAID essentially tripples your chance of failure, although maybe you'll be OK of those HDDs are reasonably well made and you don't store any data on them that you can't live without. I'm kinda thinking RAID 0 over 5, but I'm not really a big fan of RAID at all (other than 1).
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        It really comes down to your own needs.
        Some call RAID-5 "destructive"
        That is because it does not store data sequentially on the media, it is chopped up in pieces and spread out over how many disks you have.
        SSD's from some manufacturers work in similar fashions, data is compressed etc before stored to flash.
        The downside is when you need to do data recovery it becomes more complex, but as it is there exists good tools for rebuilding broken RAID-5 arrays with missing harddrives (RAID Reconstructor is my personal favorite)
        But for sure, RAID-1 is allot simpler, just throw away the broken drive or controller and your data is still there on the remaining disk with no problem.
        Of course single disk failure in a RAID-5 is no problem aswell, controller failure is another thing. Then you either need software like my recommendation above or a new compatible RAID card...
        I personally run RAID-5 with 3x 1TB drives but in hindsight I would have gone with RAID-1 or RAID-10 instead and a cheaper RAID controller.
        You are on the right path though, the reason I went hardware RAID was due to very bad experience with Intel's onboard ICHxR RAID controllers sold on mainboards with Intel Chipsets
        I think it is pointless to compare RAID-0 with the others, because it is not even "RAID = Redundant Array of Independent Disks" at all, it is a single point of failure thing.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          The drives are 74GB a pop.
          I do have 8gb Of ECC ram in the system... but I'm not gonna ZFS. Why do that when I have a Hardware RAID card already (it has 128mb of ECC SDRAM onboard).
          These are the three drives to my main rig, which runs on Debian (or perhaps a different i686PAE distro). Everything will be on the array, with 3 partitions ("/", "/boot", swap).
          There won't be any mission critical data on the system... anything important gets backed up on my fileserver.
          Still leaning towards RAID 0 because of the speed boost...
          sigpic
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            That's why I went with the software route, like mdadm and zfs. You can still recover it on other machines without being crippled to proprietary hardware or algorithms. I wouldn't do the fake-raid cards though, I've been burned on that, highpoint, and simple cheap controllers from promise and syba, learned my lesson there.
            Because ZFS can catch and fix silent data corruption and unrecoverable errors, checksumming of all disks and ensures that all data is flushed to disk and not sitting in cache along with journaling, not to mention triple parity and snapshot abilities. But still, this relies on quality hardware not being faulty.
            Hardware raid would be oblivious to this, and of course with the raid-5 write-hole you would need a BBU to ensure the array is written out, and you still have to rely on filesystem for error checking and correction, and even though it may appear ok, you could get an Unrecoverable Read Error (URE) on any of those disks or silent data corruption and so on, but the chances of that happening are seldom.
            Anyways...
            Eh if it's not going to be a storage server, go for raid 0. Do the raid 0 on the controller if you're going to use it as the root partition. You can do the same on raid-5 and get redundancy, but it will write moderately and read fast, it's good for systems that needs to be up 24/7, still suffers the write-hole.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              My thoughts exactly. This array will be the only hdd's in the sytem and thus, it will have root.
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                RAID1 or JBoD until you get the BBU. The 3ware controller is useless without it, take it from me...I've had a lot of experience with RAID's. If you have write caching enabled and it crashes or you lose power, kiss data goodbye. Its safe without the BBU if write caching is disabled, but what's the point, it seriously hinders performance. With the BBU and good drives, and its not mission-critical data, raid0 all the way! it will be smokin' fast!
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • smason
                  • 1652
                  With RAID 0, lose any drive, lose everything, so RAID 5 would be my choice given the current options.
                  I literally just got back to my desk from replacing a failed drive in a RAID 10 iSCSI SAN. I love being able to replace a failed drive with no-one ever knowing there was a problem.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    I thought the bbu was only for RAID 5.
                    Last I checked the 9500s bbu was ebaying for $80ish.
                    sigpic
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      No, it stores any data that was in the controller cache in the event of a crash or power loss, and at the next POST it writes this data back to the place it needs to be.....hence preventing dataloss. Worth every penny, if you've ever had dataloss or corruption, you'll understand!! It comes into play anytime you have write caching enabled. If its disabled, the BBU is of no use. The RAID config is of no importance when it comes to write caching.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Well then screw me with an iron pipe... I get to pick between a jack and a bbu.
                        If I had known this I wouldn't have have bought the drives... too late now. If they had only made the bbu standard equipment...
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Never mind... Problem solved:
                          http://www.ebay.com/itm/321049006379
                          Snared one for $30 shipped... w/o cables (as per my offer that was accepted).
                          Same card, only the 12 port version.
                          In the worst case, if the BBU happens to be roasted, I can get aftermarket bare batteries for $10...
                          Besides, the HDD LED connector on my 4 port was in sad shape... I had hacked it (see the thread linked in the first post) but it never wanted to stay connected...
                          Win?
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            Good score, just hope the batt is good. There's a web based config and maintenance utility under windows which will fully test and charge the battery for you. Not sure how this is supported under linux.....but regardless, good deal!!
                            Team : 49813
                            Join in!!
                            Team Stats
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              And if it isn't, well, I can get chinese replacements for $10 a pop... I know, china batts suck, but good luck finding an OEM one that isn't as worn.
                              sigpic
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                I have never like RAID5. wish your case could do 4 drives then you could put the 4 Raptors in RAID10 I love 10.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  yeah if it can do raid 10, i'd say go that route, though it requires more drives
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    He has 4, which is enough.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      But the case can only hold 3. my PSU also only has 3 SATA connectors; the only modular cables included were a Molex strand, a Molex/berg (floppy) strand, and a SATA strand. Actually, its a perfect fit for the case and drive layout.
                                      Technically I could start using 5.25" adapters in the lower 2 optical bays... but due to cooling issues (not much clearance with the HOT ram nearby), it ain't happening... I hate those adapters.
                                      sigpic
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        I have two software 4-disk "self booting" RAID5s and luckily I haven't had too many corrupted data yet. I usually run the whole server machine on a UPS to help against the write hole (which though is an issue I'm not terribly worried about as parity is written last). Performance is nowhere near theoretical peak but is acceptable. I run 4-disk because when I set it up, I was kind of appalled at the "waste" disk space the redundancy needed but it's not an issue anymore. I run the RAID mostly for uptime in case a disk buys the farm I can still access the machine from the net. I haven't had too many disk failures lately, but when a disk did go down, my machine stayed up...
                                        One of my raid5's is in a 4-in-3 hotswap bay. Knowing which disk is which during a hotswap is scary, have to basically hammer the disks with activity and the bay with the dead LED contains the dead disk...
                                          Acer Nitro AN515-55-74GB Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro AN515-55-74GB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AN515-55-74GB boardview and AN515-55-74GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 08:40 PM
                                          Acer Aspire A515-52G-74GB Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A515-52G-74GB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-52G-74GB boardview and A515-52G-74GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 04:40 PM
                                        • eccerr0r
                                          It's 2025: do you know where your 5¼" floppy drives are?
                                          by eccerr0r
                                          Oh wow.
                                          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                          Weird. Seems the PC drive is having trouble clamping...
                                          07-07-2025, 12:49 AM
                                          HP Z240 Tower Workstation i7-6700 Specification for Upgrade or Repair
                                          This specification for the HP Z240 Tower Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation boardview and Z240 Tower Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:44 PM
                                          FUJITSU ESPRIMO P956/E94+ ESPRIMO P i7-6700 Specification for Upgrade or Repair
                                          This specification for the FUJITSU ESPRIMO P956/E94+ can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO P956/E94+ boardview and ESPRIMO P956/E94+ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
