Weird Bios issue: Supermicro X5DAL-TG2
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Question: I've had a Supermicro X5DAL-TG2 for a while but there is a peculiar issue it's been having.
    Every time I kill power to the mainboard, all the Bios settings are restored to defaults. The time doesn't stop or get reset, so I don't think it's the Cmos Battery (I checked it anyway, its good).
    Its a pita for a couple reasons. First, every time it happens it re-scans all 2gb of RAM. This is a very slow process to say the least. In addition, there are some stupid defaults, like hyperthreading being turned off. I also expand the AGP aperture and manually define my IDE opticals (otherwise it takes a long time to POST).
    Is there a known fix for that or should I just get used to reconfiguring my bios a lot
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Weird Bios issue: Supermicro X5DAL-TG2
    I'd first check to see if there's an update on SM's site. If its the latest (and if its my old board it probably is), then replace the CMOS batt....even if it checks good on a VOM, change it anyway. If the problem still persists, I really don't know. Never had a SM do that. Had a Tyan do that to me once, and never did figure that one out. I'm assuming you've already done a full CMOS dump and reset on the board.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      its up to date iirc. It was your old board.
      i think the batt is a good one.
      sigpic
      • Hemingray
        KABOOM!
        • Jul 2010
        • 143
        Only right way to test a battery out is by putting load on it. Give swapping it out a try anyways.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Agreed. Seen that fool more than a few...thats why I said change it anyway. That board is circa 2003 or so, with the original batt....it is 8+ years old...
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I think I swapped it when I first got it. Not sure if I used a new one though.
            But if the batt was bad, why would the bios clock still work without power? The system was offline and not plugged in for a month or so and upon powering it back up, the reported time was still accurate.
            sigpic
            • Kjell
              Samsung Series 9 - BIOS issue
              by Kjell
              After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
              Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
              08-01-2025, 09:15 AM
            • Topcat
              Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
              by Topcat
              Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
              Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
              09-29-2024, 03:55 PM
            • wizard13
              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
              by wizard13
              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
              I have checked the forum and the available documentation but could not find a solution specific to my issue.
              • Brand & Model: Dynabook Satellite Pro C50D-B-100
              • Part Number (P/N): PYU13E-00C00PFR
              • Serial Number (S/N): 22028896H
              • System Configuration (SC): A1PYU13E1127
              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
              • Power Input: DC 19V –
              02-28-2025, 02:43 AM
              by Vesko356
              08-11-2023, 03:27 AM
            • c.daniel
              Lenovo V310-15IKB weird bios problem...
              by c.daniel
              Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
              sn LR09493E
              MB DAOLV6MB6F0 REV. F
              The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
              Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
              Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
              08-22-2025, 05:39 AM
