Dell blade 1855 server
  • gilly1984
    • 751
    Just bought one on ebay thinking i could use it as a stand alone server, bit of research shows that you need the rack for it.
    Is there a way to use it without the rack? With a normal pc psu?
    Or should i tell the guy i dont want it?
    It was £0.99p ($1.60ish)
    It has 2 56gb hdd but doesnt say what cpu (cpus) it has.
    Also states it is tested and working.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
  • JuniperSprouts
    Solder Soldier
    • Aug 2010
    • 119
    Re: Dell blade 1855 server
    I have never heard of anyone successfully converting a blade to a standalone server. I have researched the idea myself.
    The (Netburst-based) CPUs, & mobo are worth scrap gold/metal.
    The HDDs are probably actually 36GB drives (I've never heard of 56GB drives). They are worth 5.00 each.
    The heatsinks (really wide, long, & short) & enclosure could be good for (SFF) project parts.
    I hope that helps your decision.
    • gilly1984
      • 751
      That has helped me, I will tell him to re-list
      Thanks JS
      • omega
        Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
        by omega
        Hello all,
        as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
        Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
        02-09-2024, 03:34 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Nebukadnerzar_V
        Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
        by Nebukadnerzar_V
        Hi guys!
        I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
        It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
        I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
        Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
        Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
        I have attached the Dump of my machine.
        S/N: SRW2K4J
        Reg Model: DCTR...
        09-27-2024, 02:43 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • hazem3636
        need Bios Bin file Dell server 220
        by hazem3636
        hi everyone
        i need dump file for dell server r220
        i have download Flash BIOS executable file but i dont know how to conver it to Bin file
        i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
        if anyone has this method please need his supporting .
        all the best
        EXE file is attched and Original Bin file from the Bios Chip is attached also
        and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
        11-05-2022, 06:20 AM
