Nice Article about cap replacement [IEEE Spectrum]
  • Super Nade
    • Jun 2006
    • 294
    http://www.spectrum.ieee.org/jun05/2651
    Buffed up with US $100 in replacement parts, a $150 disc player can challenge players that cost ten times as much. But forget about your warranty...
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • cods69
    • Oct 2005
    • 92
    Re: Nice Article about cap replacement [IEEE Spectrum]
    This article gives me ideas for other devices as well - not just CD/DVD players.
    ie. PVR's etc.
    • japlytic
      • Oct 2005
      • 2086
      On the power supply circuits (Consumer electronics > Power supply) I have submitted to www.eserviceinfo.com (username: RE-King), I have recommended upgrades, as well as suggested replacements for the electrolytic capacitors in most of them (especially those which use "unknown" or not-so well-known brand units).
      • MD Willington
        • Sep 2004
        • 702
        Read that when it came out... we have all that stuff around work... spectrum etc etc...
        Ya'll think us folk from the country's real funny-like, dontcha?
        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
        • arneson
          • Sep 2005
          • 1267
          He started light and easy, then progressed deeper and more involved at the end.
          Power supply mod had excellent tips, but getting into the opamps and dac got me thinking about buying high end to begin with.
          Jim
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • boosti45
            Macbook pro logic board replacement parts quesion
            by boosti45
            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
            08-21-2024, 05:23 AM
          • r2digital
            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
            by r2digital
            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
            04-18-2024, 03:50 PM
