The ghetto mod thread
This is a sticky topic.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    #321
    Re: The ghetto mod thread
    Originally posted by stj
    you can buy those switches dirt cheap - you did not need to bodge it!
    Needed my meter and it's my only one.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • Dumah Brazorf
      • Jun 2013
      • 179
      • Italy
      #322
      I made this many years ago.
      This ups is over 10years but it's a good one, not so powerful but enough for my business. It came with a 4,5Ah battery that is cost/energy expensive. The standard nowadays is 7,2 or 9Ah, one or more in series, cost/energy cheaper and easier to find.
      So i cut the metal chassis and fitted a 7,2 one easily. I filed the cuts so they're not sharp and there's not way the battery poles could touch the chassis.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #323
        Originally posted by joshnz
        Faulty power switch fixed lol.
        No longer cat rated.
        Nice!
        Sometimes, though, you just need something to work on the spot at that moment. So going to the store to get a new switch may not be an option - not in the short term anyways. And if you're buying stuff from AliExpress/eBay overseas - forget it. It will take only forever to get your parts.
        So you end up with a ghetto fix like my scissors in the previous page - shitty, but it works. Still have it on my bench and still use it. The hot glue started to give out a little, so I hit it with my heat gun for about 20-30 seconds. It re-melted and is all good again.
        If you get another UPS like that to fix, try hooking up a car battery next time. You will get much much longer run times. Not to mention the fact that you will also have a spare car battery if the one in your car goes weak or needs a jump-start.
          • 31200
          cheaper too.
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Promise TX2000 controller I bought some time ago, damaged
            Seller had ripped surface-mounted capacitor somewhat off the board
            First pic is seller's ad, second my repair, wire bending & soldering to span the missing negative trace
            better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
            • Agent24
              I see dead caps
              • Oct 2007
              • 5037
              • New Zealand
              #326
              Nice work , too professional to be called 'ghetto' in my opinion, though!
              -David VanHorn
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                #327
                yeah, but these fakeRAID cards are ghetto to begin with...
                Follow the white rabbit.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5037
                  • New Zealand
                  #328
                  -David VanHorn
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    +infinity
                    Permanently Retired Systems:
                    Kooky and Kool Systems
                    sigpic
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Perhaps my second entry here will be ghetto enough
                      I acquired a Gigabyte GA-7BESH-RH dual LGA771 motherboard with a single Xeon 5140
                      Xeon 5140 are cheap, so I bought a second to see if it fixes issue of only half memory being recognised, but then wondered how I was going to cool it
                      771 coolers are scarcer than proverbial in Australia, and exchange rate coupled with shipping makes sourcing from USA prohibitive
                      So I decided to use Socket478 HSF(s) held by ubiquitous cable ties
                      I haven't got second Xeon 5140 yet - here's original, only 65W TDP and this cools it well
                      • lti
                        • May 2011
                        • 2557
                        That old HP laptop with the "repaired" fan also had a damaged touchpad cable. Instead of spending $3.90 on a new cable, I soldered it down. This mess actually works.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5037
                          • New Zealand
                          #332
                          Ha! Nice.
                          -David VanHorn
                          • televizora
                            ghettomodmaster
                            • Nov 2016
                            • 957
                            • Bulgaria
                            #333
                            Solder blobs solve(fix) everything!
                            Unfortunately, the traces on this crappy Vestel PCB are falling down, even if you only look at them.
                            To buy new light bulbs for the instrument cluster? NEVER! I have enough LED-s from lighters with flashlight.
                            I was just pissed off, when I found out that half the previous owner was imbecile that torn the traces of the ribbon probably when is was trying to replace the bulbs. The ribbon was damaged beyong repair, but because everything else was functional, I just connected the ribbon, filling the missing pieces with the legs of the resistors and connected the LED-s via 1K resistors. LED-s that work with proper voltages have much longer life than the crappy bulbs made in china and sold everywhere.
                            BOSS, do we really need all the crews we lost already to fix this poorguy's laptop?
                            What we cannot fix with solder blobs, we will fix with brackets.
                            Though, the tip of the screwdriver is very, very strong. I cracked the handle by forcing it, but still not found a way to break the tip.
                            Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                            1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Speaking of speakers, I have a speaker whose tinsel wires broke. I don't think this speaker is economically repairable (as it's only a 5.25" paper) but has anyone tried replacing/splicing tinsel wire?
                                • 31200
                                i know what may work!
                                http://www.ebay.co.uk/itm/261342199875
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #336
                                  Awesome!
                                  You can splice it. Or solder it back together with some copper wire. Or, unless the speakers are moving to full excursion 24/7, you can also fully replace it with regular wire.
                                  Feel adventurous? You can use a ribbon cable too.
                                  ... filling the missing pieces with the legs of the resistors and connected the LED-s via 1K resistors. LED-s that work with proper voltages have much longer life than the crappy bulbs made in china and sold everywhere.
                                  Nice!
                                  Also good to hear you used 1 KOhm resistors. Like you said, LEDs driven with proper voltage (and current) will last a very long time.
                                  On that note, if anyone ever buys cheap LED light strips on 3M tape and they have 150 Ohm resistors, DON'T use them with 12V, like they say they are rated for. At 12V, those 150 Ohm resistors don't provide enough voltage drop, and so the LEDs end up being over-driven. I have seen enough of those LED strips dead to safely say that they shouldn't be connected to anything more than about 9.5 Volts (or at least for the ones with WHITE LEDs).
                                  O.o fancy! Haha
                                  I'm too cheap for those brackets, so I often use steel/copper wire instead.
                                  Well, I had a tough screw driver, but I finally managed to break the tip a few weeks ago. It is a small flat heat screwdriver that I got from my dad a very long time ago when I was a kid. He actually got it with a set of nice steel compass set. Good quality German stuff from back in the day, if I remember. Anyways, even though that screw driver has a thin plastic hollow handle, I've never been able to snap the handle. But after nearly 20 years of use and abuse in my hands, I finally cracked the tip, as I said. Felt really sad for it. Then I took out my dremmel tool, and after a few minutes of work, I re-grinded the tip again. So it looks like new again. Gotta love high quality German steel!
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    #337
                                    Here's something a little different - the toaster died over Christmas (the main switch fell to bits) and I had to replace it with a dissimilar one.
                                    The actuator was all wrong (had to snap it off and replace with a screwed-on piece of hairclip) and I had to make a mounting plate to bolt it onto the chassis as the holes were misaligned, and also it would have meant 240v input wires shorted directly to the chassis.
                                    I had to crimp and solder the heater leads to some spade terminals.
                                    It works!
                                    -David VanHorn
                                    • Stefan Payne
                                      • 1267
                                      Yep
                                      Did something similar with my Hyundai W241D and some SMD caps where I soldered some polymer through hole caps (big ass 470uF/16V ones) instead...
                                      Doesn't look that great but works very well.
                                      Using SMD caps can be a pain sometimes...
                                      Especially if you don't have good Irons...
                                      • televizora
                                        ghettomodmaster
                                        • Nov 2016
                                        • 957
                                        • Bulgaria
                                        #339
                                        Boobie trap.
                                        • petehall347
                                          • Jan 2015
                                          • 4439
                                          • United Kingdom
                                          #340
                                          yes i have many times repaired them ..
                                          replacing with solder wick is best way .
