Where to put the white wire?
  • Technoguy3
    • Oct 2012
    • 30
    So my power strip with switches for each outlet just randomly shut off for no apparent reason, so I opened it up and found this:
    The neutral wire came loose! I'm not really an expert on circuits (I just replace capacitors because it's obvious), so where should I solder the white wire back on???
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Where to put the white wire?
    follow the black wire! should be close to where it is soldered on the board!
    • Technoguy3
      • Oct 2012
      • 30
      I couldn't find any extra holes on the board. lol
      • mariushm
        • May 2011
        • 3799
        It gets soldered straight on the metal blade
        See picture :
        • Technoguy3
          • Oct 2012
          • 30
          It doesn't reach that far. Also, isn't soldering it directly to the hot wire creating a short?
          • Hemingray
            KABOOM!
            • Jul 2010
            • 143
            The one you pointed out looks like it has the black wire going to it...
            Also, where did you find such a strip??
            • mariushm
              • May 2011
              • 3799
              Oh sorry, that's the solder spot for the black wire. I assumed the round hole in the strip was for the cable, but it's actually for the switch.
              So the black wire is soldered directly to the metal band, the green (earth) wire is also connected directly. Either way, it's a lousy strip, kinda unsafe in my eyes.
              So the white wire has to go through the switch on that small PCB.
              I see both white and black wires going from one side of the switch to the metal blades, and it seems like the black wire from the cable is connected on the other side of the switch.
              So logically and simetrically, the white wire should be soldered on the other side of the white wire on the small pcb with the switch.
              I don't see the switch from all angles, just two which don't show if there's a hole behind those MOVs or to their right.
              • WoodButcher
                • May 2012
                • 37
                Look careful at the solder on the loose white wire, it can help you determine where it belongs. If it has broken solder look for it's mate. I'll bet you'll find what looks like a dent or knife mark on the side of it not to far from the end. That switch or circut breaker most likely has a "stab" a hole on it's side that has a brass blade on the inside angled inward to catch and make contact similar to what you find on many switches and outlets in your home. They should be outlawed.
                  Will that White (Neutral) wire reach the Neutral buss bar where the other white wire is attached to? The Black (Line/Hot) from the power cord should feed the input side of that black Thermal circuit breaker, the output side of the breaker will go to the Line/Hot buss bar, the ground (Green) will go to the Ground buss bar.
                  The 3 green devices on the circuit board are MOV's for surge protection, one will be connected between Line and Neutral, second will be between Line and Ground, third one will be between Neutral and ground.
                  I can also see the green ground wire insulation is busted. If I were you I would get a new an d better built one, that Neutral should not come off that easy, they suppose to wrap the wire on the terminal and solder. Cheaply made and dangerous for the owner.
                  • Technoguy3
                    • Oct 2012
                    • 30
                    You are right; this is a cheap bastard. Going to just throw it in the trash and get a new one since I don't want to short anything out by continuing to use this. lol Thanks guys!
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I'd at least save it for the switches and power cord if it were me. I'd probably fix it though... I've seen far worse.
                      sigpic
                      (Insert witty quote here)
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Good decision
                        I had one where the switch broke. The switch stayed half-on, and it started arcing and melting . I took the switch out, bypassed it so the outlets were permanently on.
                        Muh-soggy-knee
                        • Norrecito
                          iPod nano G3 - alternative soldering point for the white battery wire
                          by Norrecito
                          A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
                          The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
                          This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
                          09-07-2024, 03:54 AM
                          MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 07:46 AM
                          MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          09-06-2024, 07:29 AM
                          MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 07:25 AM
                          MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
