Lead-free solder and tin whiskers: Older than you think
  • Shocker
    Banned
    • Dec 2011
    • 635
    Here's the deal.
    I don't trust new hard drives, nor do I have much of a need for them personally. As a result I end up with old hard drives, which are usually more robust and last much longer.
    Unfortunately, even the old hard drives aren't without their problems. This one is a case in point. It's an ST380011A, made in 2004. I looked at the connector attachment points, and what did I see but tin whiskers. I compared it with an ST360021A (leaded solder) and ST3250820A (lead-free) and the solder certainly looks like that on the latter.
    The real kicker is that by no means were they forced to use lead-free solder in 2004. I have power supplies from 2005, even early 2006 which don't have that crap.
    The drive was functioning okay the last time I used it, but I doubt it's a good idea to keep using it like this.
    And this time the goes to Seagate instead of RoHS, as I already explained.
    EDIT: And for the record, there's nothing else wrong with the drive. If the solder becomes the first point of failure, well that sucks.
  • Shocker
    Banned
    • Dec 2011
    • 635
    Re: Lead-free solder and tin whiskers: Older than you think
    Anyone???
    Something as simple as solder being the first point of failure in something as complex (and precise) as a hard drive is just sad.
    They call it Restricton of Hazardous Substances. I call it Restriction of Helpful Substances. If people didn't keep upgrading and throwing out their devices then I don't see much harm coming from lead in solder. Also, they pronounce it "rose", but I mispronounce it on purpose .
    I despise RoHS. As I stated, the problem is not that lead is/was used in solder, but that consumers are hopelessly wasteful.
    • Shocker
      Banned
      • Dec 2011
      • 635
      Also have to add this: The drive in question is my only (if out-of-date) backup of my data files. On top of that I also run as an Administrator constantly, and don't have any antivirus utility at all.
      • c_hegge
        • Sep 2009
        • 5219
        Admittedly, computers are gonna end up in landfill regardless of whether they fail or not, because new software won't run on them, so I kind of understand the sense of RoHS in computers, but in other devices which don't need software upgrades, then yes, I hate RoHS.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4970
          • New Zealand
          Well that's just silly.
          As I saw somewhere once.. "If your data doesn't exist in at least three different locations, it doesn't exist"
          -David VanHorn
          • Wester547
            • Nov 2011
            • 1268
            • USA.
            Anyone???
            Do you mean the IDE pins on the connector? If that's the case then it's possible the 7200.7 drives were the "transition" series and the beginning of lead-free solder in Seagate drives considering they went to it completely with the 7200.8 series. I wouldn't be worried about it, though - I doubt those "whiskers" get hot enough to cause solder fractures or short circuits in this case.
            Usually I don't like programs in the background but I do find it prudent to keep an anti-virus app around. Avira is one I'd recommend; it's not consuming of much RAM at all, in my experience (if you have 512MB or more in XP).
            • Shocker
              Banned
              • Dec 2011
              • 635
              And having to upgrade the PC to run new software (except things like gaming and CAD) is itself the result of a conspiracy.
              I have no motherfucking idea how we've come to this. As hardware gets faster, software gets bloated enough that the result is slower. A vicious, expensive, toxic circle. I actually hope we get to the point where technology can no longer be pushed any further sooner rather than later.
              Seriously, being able to literally see tin whiskers without a microscope or even a magnifier tells me all I need to know about RoHS. It's about reducing the damage trash causes, not reducing the volume of trash (which it actually increases). The latter is the real solution to the environmental damage. RoHS is just a pathetic attempt to make people think everything will be okay. It won't...not by a long shot.
              Waste is waste, even if it doesn't cause health damage. It's still expensive, takes up space, and causes serious inconvenience. All of us totally miss the days when quality and reliability were taken seriously.
              EDIT: Also, just to clarify, it's the board solder I'm talking about. The pins themselves are gold plated (except the power input).
              EDIT 2: The problem whiskers create is short circuits.
              • smason
                • 1652
                Words to live by!
                • smason
                  • 1652
                  Would love to see some good pics.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    If none of it is BGA, sounds like a straightforward fix using some braid and leaded solder.
                    sigpic
                    (Insert witty quote here)
                    • Shocker
                      Banned
                      • Dec 2011
                      • 635
                      You're right, there's no BGA (luckily) so fixing it won't be rocket science. But I'm going to practice on some junk boards (ironically some of them being from the same model HDDs) first. Better to fix it later than to break it forever.
                      Also, the problems with the ST chips could be why you had bad luck with yours. Remember what I said about them going suicide in use.
                      I know it's silly to not have a backup, BTW. That's why I put the smilies on the end.
                      Of course we'll never know what those RoHS politicians were smoking.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Solder fumes?
                        sigpic
                        • Shocker
                          Banned
                          • Dec 2011
                          • 635
                          Outstanding explanation!!!!!
                          • c_hegge
                            • Sep 2009
                            • 5219
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4970
                              • New Zealand
                              Or the paranoid could say RoHS is a scam by the industry to make less reliable products and thus require you to pay more money in repairing or replacing them.
                              -David VanHorn
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Probably was them 'green' freaks!
                                Muh-soggy-knee
                                • PeteS in CA
                                  • Aug 2005
                                  • 3581
                                  • USA, Unsure of Planet
                                  Nope, Envirocrats. Here's the scary part about RoHS. Theoretically, some industries are exempt, e.g. military and medical electronics (what does that say about RoHS-compliant equipment?!). In real world (hated by bureaucrats) the vast majority of components are subject to RoHS, and component manufacturers are not going to maintain separate lines (separate facilities?) using unique materials and processes for a very small fraction of the components marketplace. So even exempt products are being forced by regulation-induced shortages to use tin-whisker-susceptible RoHS-compliant components and materials.
                                  This is why I've long expressed the wish that the Envirocrats responsible for RoHS will find their lives dependent on RoHS-compliant medical electronics.
                                  PeteS in CA
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Here is an interesting page I found about this issue.
                                    Muh-soggy-knee
                                    • Shocker
                                      Banned
                                      • Dec 2011
                                      • 635
                                      Yep, I couldn't feel better if the idiots behind RoHS died in pain. In fact I need more words than exist in the dictionary to describe RoHS. Appalling, terrible, disastrous, short-sighted, atrocious, horrifying, negligent, retarded, stupid, unacceptable...
                                      Anyway, the thing being RoHS is the worst disaster that ever happened in the electronics industry. And I'll never get over it. Not until they see this thread and find out how bad their decisions were.
                                      I could go on all day and night about how shitty RoHS is, but time isn't unlimited so I have to focus on more important things than ranting.
                                      • larrymoencurly
                                        • Oct 2004
                                        • 960
                                        Does anybody have information about how much lead actually gets into the body from different sources? Because I can't imagine electronics having been much of a contributor because old TVs and computers get buried in dry landfills that manage to keep even cheeseburgers fresh looking for years.
                                        • corrize
                                          Best way to solder LVDS connector for beginner (and qfn) ?
                                          by corrize
                                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                          See the test :
                                          https://youtu.be/bNAzC-EvqHs?t=1767
                                          With hot air from bellow the board, that's...
                                          03-09-2023, 02:57 AM
                                        • myth77
                                          UV solder mask - high temp resistent, recomendation?
                                          by myth77
                                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                          Is there any solder mask...
                                          03-28-2022, 04:04 AM
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • sircastor
                                          Solder not reflowing - what am I doing wrong?
                                          by sircastor
                                          I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                                          For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                                          03-03-2024, 02:44 AM
