LED laptop screens
  • stevo1210
    • Oct 2006
    • 4156
    LED laptop screens
    Just changed an LED backlit LCD screen on an Asus ultrabook... it's not very often that I do this sort of stuff but anyway... It took me less than 5 minutes for a job that usually takes me 15-30 minutes.
    Just 6 screws that held the bezel in and removed the screen with only a data connector thanks to LED backlight not requiring an inverter.
    No screws to hold the screen in place either, just relies on the plastic bezel out the front to keep it in place... very happy with LED technology and also the screw less LCD screen design, saved me time and effort!
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
  • ipatch
    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
    by ipatch
    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
    08-24-2024, 02:36 PM
