a giiiiiiiift
    Re: a giiiiiiiift
    ok. i'm starting to see whats going on here. they must of messed with the ich in the last bios. driverpacks was putting iastor3 (intel AHCI) from the driverpacks. After a ton of research I found out this is a GL960 chipset, and therefore has a ich8m southbridge. Last time I tried to nlite drivers into a windows install it did nothing. did not put them in textmode. never made an $oem$ folder too. Intel stopped supporting ICH8 (but not 7 or 9) so I found an old iastor to use. Hopefully this other iso of xp pro will take it
      Re: a giiiiiiiift
      theere we go. I don't know why the bios update stopped the iastor3 driver from working post install but the method above with nlite worked, so far
        Re: a giiiiiiiift
        Yup, Intel stopped supporting ICH8M but oddly continues to support ICH7R...
        There's a special updated driver floating around for ICH8M, I have to look on my laptop for it...
        "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
        -Leonid Brezhnev (On the Yom Kippur War)
          Re: a giiiiiiiift
          Originally posted by Uranium-235 View Post
          get a 'error loading opearting system' when trying to boot off the HDD
          The boot code usually gives that message only on real early hardware, on 386s and the like, because of using a hard disk drive that's bigger than the BIOS recognizes and probably tries to access data that's beyond a BIOS limit.
          Reminds me of connecting a Quantum ProDrive LPS 170 MB HDD to my Compaq DeskPro 386.
          Trying to boot from that HDD, which had Windows 95 on it, resulted in that message.
          Find out that I needed to use a special boot loader to get around that.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            Re: a giiiiiiiift
            I found it. nlited it into xp just fine. installed great
            anyone have any idea how to get this thing to change brightness with the fn+F6/F7 keys? it actually worked with no display drivers installed but with the intel express 965 drivers installed it does nothing.
            also the fn+up and fn+down keys do not change volume, it actually did on the previous install. hmm. I tried other pieces of Toshiba software for this laptop from thier site and the ones that actually installed, had nothing to do with it
              Re: a giiiiiiiift
              I think you need the toshiba value added package for the hotkeys to work properly.
                Re: a giiiiiiiift
                yeah I tried that with no luck. it refuses to install on winxp. Might have to win7 this after all.
                what do you guys think of 6-cell generic ebay batteries (default for the L45 is 4 cell)
                this is a temptation:
                http://www.ebay.com/itm/6-Cell-5200m...item4d016006ce
                I also see some 6 cell 4400 mah, where the one above is higher
                I could get an original 6 cell toshiba 4000 mah for $50, ick or
                http://www.ebay.com/itm/New-10-8V-Re...item41658dc73a
                5200 mah
                still worried about getting anything from china
                anyone got 2x2ddr2-800 sodimms they're willing to sell me?
                  Re: a giiiiiiiift
                  I just got win7 installed. Still not sure. little slow. does vevo 720p 100% both cores. I have a 2gb ddr2 stick i'm gonna add to give me 3
                  disabled areo, and a number of services, still so-so
                  ^^what do you guys think of those batteries I mentioned above. One thing I like about win7 is it knows this battery is bad lol said I should replace it asap
                    Re: a giiiiiiiift
                    I don't have a problem with generic batteries. My Thinkpad T60 (which I'm posting from now) is currently running off one. They do seem to fade a bit quicker than genuine ones, though.
                      Re: a giiiiiiiift
                      UGH. I'm having a different problem on this one. The FN+brightness keys work just fine, but the lid acpi trigger will not work. It worked in XP after I installed the ATK 0100 driver, now the lid trigger just will not put it in sleep mode
                        Re: a giiiiiiiift
                        ohh this is funny. it will wake up from a lid open, but not sleep from a close. cute.
                          Re: a giiiiiiiift
                          Sounds like a software bug!
                          Muh-soggy-knee
                            Re: a giiiiiiiift
                            Bad setting. If you have it set otherwise, that's standard behavior.
                            sigpic
                            (Insert witty quote here)
                              Re: a giiiiiiiift
                              nono, in 7 its set to 'go to sleep' for the lid close action. does NOTHING
                                Re: a giiiiiiiift
                                Glitch!
                                Muh-soggy-knee
                                  Re: a giiiiiiiift
                                  sounds like a bug in the ATK 0100 driver
                                    Re: a giiiiiiiift
                                    Sounds like a bug in the quantum fusion hydrolysation core. You'll need to re-energise the tritium plexus transponder to achieve the correct flux capacitance.
                                      Re: a giiiiiiiift
                                      well it seems that microcode is also supported under the 1.60 bios too. i'm going to try to downgrade and see if that fixes any problems
                                        Re: a giiiiiiiift
                                        ahhhhh. its working now.
                                        How?
                                        well I installed XP and it was the same thing this time. No sleep. Then I realized when I first installed XP I installed an ATK 0100 from ASUS. I put 7 back on, found the atk 0100 for the G50 series asus laptop, and boom. It even installed an OSD when I mute, change brightness, or do any other function. But since this is a toshiba, the 'brightness' would only go up half way on the brightness marker. I took the osd programs out of startup. Then it used an older OSD (the one from XP). I actually had to find the program files/asus folder and rename the osd.exe so it would not load. Brightness, sound,mute work just fine with the FN keys now, as does the lid sleep trigger
                                        Asus could of been a dick about it and checked hardware and give me a big finger on this software but no such thing happened. thank you asus
                                          Re: a giiiiiiiift
                                          One thing about this top is its listed under toshiba as having a max of 2gb of ram, well I have a 1gb and 2gb stick in it and it works fine. but it is having some trouble with the 2gb stick in alot A, windows won't boot, memtest fails to even try to start.
                                          with the 2gb stick in slot b and 1gb in slot A, it works great, memtest runs fine. what do you guys think?
