Strange pause while booting
  • lti
    • May 2011
    • 2547
    I have two Toshiba laptops with a pause during the boot process. One is running Windows 7 Home Premium 64-bit, and the other is running XP Professional 32-bit. Both computers load most startup items along with Windows, but the antivirus software and some startup items do not load. Windows appears to have fully booted at this point and there is no CPU or hard drive activity at all. After about two minutes, the antivirus software and the remaining startup items load. The computer running XP has done this from the factory, and the other computer did not have this problem until Windows was reinstalled while it was being repaired by Toshiba's own repair center. I am running the same programs and antivirus software that I was using before this computer was repaired, and I can not reinstall Windows on this computer due to Microsoft's stupid activation limit on Windows and Office. What causes this?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Strange pause while booting
    I had something similar to this awhile back. But it turned out it was waiting for the network to link up. Updated the driver, problem went away.
    I also had another computer that had something similar to what you had but I can't remember what the cause of it was.
    • smason
      • 1652
      The event log (system log probably) will almost always tell you what's going on.
      We did an upgrade of our corporate patch management software last week, and all of the desktops started taking an extra 45 seconds to boot. Notebooks were fine.
      Event log showed one of the services hanging on startup. Changed them to autostart (delayed) and problem solved.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        There's no stupid activation limit to worry about with the OEM copy that came with the laptop, AFAIK.
        It should be activated already after reinstalling, even with HDD wiped!
        Major laptop OEMs are known to have special product keys and hardware ids to pre-activate Windows and it's done without going online.
        That's only true with retail "OEM" copies.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • lti
          • May 2011
          • 2547
          The copy of Office that came with this computer could only be activated twice. I had to call Microsoft to activate Office after Toshiba reinstalled Windows.
          These events are logged every time Windows loads:
          Log Name: Application
          Source: Toshiba App Place
          Date: 6/29/2012 8:53:30 AM
          Event ID: 0
          Task Category: None
          Level: Error
          Keywords: Classic
          User: N/A
          Computer: Lee-PC
          Description:
          The description for Event ID 0 from source Toshiba App Place cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
          If the event originated on another computer, the display information had to be saved with the event.
          The following information was included with the event:
          System.ArgumentOutOfRangeException: Number must be either non-negative and less than or equal to Int32.MaxValue or -1.
          Parameter name: dueTime
          Stack Trace:
          at System.Threading.Timer..ctor(TimerCallback callback, Object state, Int32 dueTime, Int32 period)
          at System.Timers.Timer.set_Enabled(Boolean value)
          at SnappCloud.ActivationReminder.AraClient.PostInit()
          at SnappCloud.ActivationReminder.Program.Main(String[] args)
          the message resource is present but the message is not found in the string/message table
          Source: Microsoft-Windows-WMI
          Date: 6/29/2012 8:54:55 AM
          Event ID: 10
          Task Category: None
          Level: Error
          Keywords: Classic
          User: N/A
          Computer: Lee-PC
          Description:
          Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
          There are also some strange services starting with Windows:
          Service1
          SignInAssistant
          Why does Event Viewer take so long to load in Windows 7?
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Event ID: 10
            Task Category: None
            Level: Error
            Keywords: Classic
            User: N/A
            Computer: Lee-PC
            Description:
            This error message or similar, is a Windows 7 bug and it's a Windows 7 service pack 1 regression.
            Arc A770 16 GB
            • lti
              • May 2011
              • 2547
              I fixed that error.
              In services.msc, there are many services that have a startup type of "Automatic (Delayed Start)." These are the same startup items that load after the boot pause. I can change all of them except Norton Internet Security to Automatic. Why are these delayed, and why am I unable to change the startup type for Norton? I might have the same problem with any antivirus software.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                it's startup bugs and apps i see this with 2k to win-8 and
                i see this on my win-vm's all the time just remove some apps from the startup list and good to go.
                at-least in vm's!
                Follow the white rabbit.
                • lti
                  • May 2011
                  • 2547
                  I can change the startup type on every service except Norton Internet Security. The Startup Type menu bar is grayed out, and the startup type can not even be changed from the command prompt in Safe Mode.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Like with some HPs.
                    Arc A770 16 GB
                    • lti
                      • May 2011
                      • 2547
                      Like with some HPs.
                      Toshiba laptops come with even more crap than HPs, and most of it is required.
                      I want to know what is preventing Norton from starting without the delay. It might affect all antivirus software.
                      • lti
                        • May 2011
                        • 2547
                        I decided to look at the older computer today. I don't see any way of delaying the start of certain startup items. This computer thinks that it has a constant 10Mbps network connection, even though it has no network adapter. It used to have Norton Systemworks 2003 installed on it. The delay still exists after I uninstalled Norton.
                        The newer computer is going nuts again, just like it did when the RAM failed a few months ago.
                        • Aeisens
                          Samsung UE50RU7170 not booting /no picture
                          by Aeisens
                          Dear all,
                          My issue is the following:
                          Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
                          I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
                          Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
                          Question 1: Where should I start to...
                          06-24-2025, 03:07 PM
                        • Daniel Kubica
                          Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
                          by Daniel Kubica
                          I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
                          I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
                          06-14-2025, 09:24 AM
                        • Hondaman
                          Laptop external keyboard?
                          by Hondaman
                          Can I use an external keyboard with a modern (as of this post) laptop from, say, Dell?
                          I am worried about durability because I am a cheap, frugal person. I suspect an external keyboard would extend the life of the laptop. I have always been a desktop person, since my AMD 386DX-40, and I really don't know about laptops (though the current Dell products look like they are fanless, which eliminates a big failure point).
                          (Also I prefer the "clicking" "Unicomp" keyboard, which is still made an hour or two away from me in Lexington KY, using the same equipment...
                          10-30-2023, 12:04 PM
                        • sylvain_92
                          iMac 2009 A1312 2009 not booting - 3rd led not on
                          by sylvain_92
                          I am trying to repair my iMac A1312 late 2009 intel i5.
                          First of all it was booting but no screen on internal lcd but working with external one,
                          I tried:
                          - another screen and led power board (booting no screen - same as before)
                          - another mxm graphic card (not booting missing 3rd led)
                          * screen and mxm gpu tested are 100% working on another A1312 iMac.
                          I putted back the original mxm graphic card and what a surprise, now it's not booting anymore even with the stock parts.
                          The main...
                          12-23-2022, 03:36 PM
                        • BMCappelletti
                          Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                          by BMCappelletti
                          Hi everyone.
                          Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                          Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                          Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                          02-18-2025, 12:22 PM
