Hard disk problem
+ More Options
Posts
  • enigmatic
    • May 2006
    • 41
    Hard disk problem
    i have two harddisks and i have a problem where the disk is just making a clicking noise, one drive i know may be damaged mechanically but the other i think is OK
    what could the problem be?
    i've taken the hood off one and watched it go and the arm just moves back and forth constantly clicking
    sorry its not much of a description
    in the bios it picks up the drive correctly
    so whats the dealio yo?!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Hard disk problem
    IBM's by chance?? I've gone through quite a few 'clicker' IBM's....
    Throw it away and replace it if its not still under warranty, its toast.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Then you can now throw that disk in the trash
      It will be impossible to repair it, dust will have entered it and it is dead for good
      A data recovery firm might be able to bring some data back but that is 2000$ and up
      Not to bash or anything but exactly why did you open it? You need a grade A clean room to open a harddrive, and let alone actually do anything with it is pretty much impossible, except move the platters to a special machine to sector by sector copy it but like I said that is 2000$ and up...
      • Galvanized
        • Mar 2006
        • 468
        It's kinda hard to find, but Hitachi has mp3 files of dieing HDDs in the diagnostics section of thier site.
        Dead HDDs are good for several things. To take apart and play with. To use for mock-up work when building HDD cages. Last: If you have several of the same brand&type, with the EXACT same number on the logic chip and one dies because the chip got fried by a 5V spike, a good chip can be moved to the dead drive to remove files. The odds of doing this are slim but it has been done with Maxtor Drives. The bad PSU would have to be replaced.
        Never drop a drive or it will be killed...I know
        • enigmatic
          • May 2006
          • 41
          well i took it apart as its an old drive i just wanted to play around with, just wondered why it was dead, didnt know that by taking it apart you had to be in a clean room
          but it was fun checking it out
          what about the pcb thats attached to the disk, would taking that off also kill the disc?
          • tiresias
            • Feb 2006
            • 489
            Hi Enigmatic,
            I wouldn't worry about it - sounds like the drive was dead to begin with.
            I have quite a bit of experience in opening hard disk drives ... and I've never seen a drive "die" immediately after opening it - it will usually run, often for hours or even days, while accumulating bad sectors at an impressive rate. It is interesting to see, though, and those platters make amazing mirrors!
            That's the disk's interface and power supply for the motors... You can remove it without doing any damage, although often those tiny Torx screws can be treacherous...
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              drinks coasters
              there's some keyrings in there also. see if ya can find them
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                HDD platters also make great mirror trinkets!!!
                That's a platter from a 4.3gb SCSI seagate cheetah........
                Team : 49813
                Join in!!
                Team Stats
                • enigmatic
                  • May 2006
                  • 41
                  yeh it was a bad drive, just playing around with it
                  and yes one of the other drives was an ibm! now that i hadnt touched its just developed a "death rattle" and forever clicks althought it works very slowly
                  and i just ordered another ibm too
                  time to cancel the order!
                  • tiresias
                    • Feb 2006
                    • 489
                    If you're looking for an acceptably fast and modern, but also very reliable drive - take a look at the WD Caviar RE series. I've bought nothing but those over the last 18 months or so, and I've been very pleased with them so far.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      excuse to show goldie's interior again...where does he come up with this stuff? bwahhahaahaha
                      i am now ordering only seagate but ask me again in a year.....WD no thanx
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        Fujitsu SCSI320 15K RPM drives OWN all others!!
                        /thread!!
                        Team : 49813
                        Join in!!
                        Team Stats
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          oh god...big text...i am blind again
                          fujitsu...i believe you but unobtainium here......seagate or maxtor scsi only
                          • Spacedye69
                            • Nov 2005
                            • 698
                            • US
                            Rich people and their SCSI320! pft...
                            • tiresias
                              • Feb 2006
                              • 489
                              So, Seagate, WD or Fujitsu... it's like Canon or Nikon, Bosch or Makita all over again.
                              I must admit though, the chief does make a point with that font. When Topcat speaks, everybody listens!
                              • gonzo0815
                                • Feb 2006
                                • 1600
                                oh ugh SCSI......expensive stuff, whish to have a array controler with a shit of ram and some above mentioned disks but........ i am afraid that would be a little pricy
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  i have a few 15k fujitsu 146gb mixed in with mostly seagates in my array.fujitsus are a bit quieter.
                                  still sounds like a jet engine and a roomfull of typewriters!
                                  • stretch0069
                                    Screwed Up Super Moderator
                                    • Oct 2003
                                    • 2658
                                    • oooo ess aaaaaaaaa
                                    huh????
                                    a hard drive plater hanging from the mirror in your car................
                                    .........i just don't know what to think.....
                                    "Its all about the boom....."
                                    Guns kill people like spoons made Rosie O'Donnell fat.
                                    We now return you to your regularly scheduled drinking.
                                    "Fear accompanies the possibility of death.....calm shepherds its certainty"
                                    Originally posted by Topcat
                                    AWD is just training wheels for RWD.
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16956
                                      Where are you finding Fujitsu 15k 146GB drives?? I've got a bunch of the 73giggers, and I love 'em! I'd like to get my mits on some 146 giggers
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        these came from a guy at the flea market that got them at a police auction.
                                        they were in hpq trays.
                                        i used the drives in my array and sold the empty trays for twice what i paid for the drives.
                                        funny how that works.
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • Eleways
                                          Apple Macbook A1707 Hard disk
                                          by Eleways
                                          Hi
                                          I've an Apple macbook A1707 with Hdd defect.
                                          This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
                                          My question is:
                                          Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
                                          Can i replace with a different one (es 500 gb instead of 250 gb)
                                          This Macbook has T1 security check.
                                          Thanks and best regards
                                          Luca
                                          02-18-2022, 04:23 AM
                                        • DynaxSC
                                          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                          by DynaxSC
                                          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                          The behaviour is also really very strange, i.e.:
                                          • The disk shows always up in BIOS - so it is recognized, so far so good
                                          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                          02-23-2025, 01:33 PM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
