windows time synchronisation using sntp
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    this is pretty basic but maybe someone doesnt know it.
    so you can synchronise your computer clock to a time server. motherboard clocks can keep poor time so if you want exact time then use an accurate external time server
    you need a time server, well there are many. i am using the ones available from http://www.ntp.org/ which is a nice project. since there are not many for Greece I use the european pool so europe.pool.ntp.org it is best if you use your country one if you can.
    so in win2k or xp, hit the command prompt (change the server in bold to what is right for you)
    net time /setsntp:europe.pool.ntp.org
    if you have xp then the w32time service is already started and will load automatically
    if you have win2k then type
    net start w32time
    or you can do that when you go into control panel/administrative tools/services then right click on properties and then click start. anyway set startup type to automatic.
  • titomno2
    Gaming Laptop Zephyrus S17 TFT not detected every time !
    by titomno2
    Hi guys,
    I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
    So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
    On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
    Then the screen won't work for a long period of time.
    If I wait 1 or 2 hours it work again most of the time.
    When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
    01-19-2025, 08:27 AM
    HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
    This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
    09-06-2024, 11:39 AM
  • flat-earther
    Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
    by flat-earther
    I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
    To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
    I have opened the camera and I think there is enough room to add something inside to accomplish this:
    The camera is powered by a 3.7V nominal single cell lithium ion battery.
    So I need to connect another battery in...
    06-08-2025, 02:00 AM
  • harp
    Comparing FreeNAS, FTP server, SMB server, multimedia server...
    by harp
    I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
    I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
    Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
    What is general difference between this products, and what be most useful...
    01-04-2024, 02:44 PM
  • OscarAV
    HP Pavilion dm4-1065dx long time to get the power led on
    by OscarAV
    I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
    I have made a quick search for my laptop but I have not seen anything similar.
    I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
    09-23-2024, 05:53 PM
