DIY Capacitor Discharge Tool
  • rilski
    • Jul 2010
    • 15
    Would anyone know a proper capacitor discharge tool for motherboards made from resistors? I've searched Google but there's alot of them. I'd just like to know a PROPER ohm/resistor for the tool.
    Thanks!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: DIY Capacitor Discharge Tool
    shorting them with a screwdriver never fails.......but honestly, I've never seen a motherboard cap hold a charge enough to actually require being discharged...nor is there enough voltage present for it to ever be a safety issue...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Agree.
      Don't need one for mobos.
      The caps all have discharge paths.
      Even if they didn't 12v won't do much more than get your attention.
      (Inside the power supplies is a different story..)
      If you just HAVE to have one anyway here's a way to make one.
      Mann-Made Global Warming.
      - Dr Seuss
      • b700029
        Banned
        • Sep 2010
        • 640
        To reassemble your device, follow these instructions in reverse order.
        I followed the instructions in reverse order and all I got was a resistor and some wire. Getting those leads reattached to the resistor was difficult...
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          How do you solder backwards and get the solder back to being wire?
          Do you use ice to unshrink the tubing?
          [I didn't notice that...]
          - Dr Seuss
          • ComputerGeek
            • Oct 2011
            • 262
            I just lol'ed who came up with those directions.
            I have heard of using a standard 60w or a 100w light bulb before, not sure if the voltage is too high what would happen.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Flux Capacitor?
              sigpic
              (Insert witty quote here)
              • rilski
                • Jul 2010
                • 15
                @all
                Thanks for the replies!
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • redwire
                  Making a capacitor discharge tool
                  by redwire
                  I'm making a new capacitor discharge tool. Asking for suggestions for sizing the discharge resistor.
                  Mr. Carlson's Lab High Voltage Capacitor Discharge Tool 1 is using 4 of 1kΩ 50W aluminum (mount to heatsink) resistors in series for 4kΩ 200W, so it's big, which is fine.
                  His Patreon but I don't have a paid subscription for the project details but it looks straightforward. The plastic box with aluminum plate can't get rid of any amount of that heat though.
                  Wirewound resistors can be overloaded by a factor of 5 for 5sec. and a factor of 10 for brief times. I've never tried say...
                  06-18-2023, 07:09 PM
                • rex98
                  HP DMI Tool
                  by rex98
                  HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                  DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                  The DMI Tool given here are for personal use only.
                  DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                  You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                  from it, and that you please credit the author...
                  07-02-2025, 05:51 AM
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • shagster
                  Capacitor Discharge Rate Testing!
                  by shagster
                  Hi, I have 2 identical capacitors from an old scope I'm trying to get running.
                  Both caps measure ok in ESR and Capacitance values imo.
                  Data sheet says tolerance spec is -10 +50%. And these are way under that.
                  Both of there original values are marked as (430uf 200vdc).
                  After ~40 years, they now measure 485uf and 465uf. Well under the +50% tol.
                  Anyway I charged them up to 24 volts dc and discharged them slowly down to 10 volts using a Digital Multi Meter. Funny thing was one of them just took over 4 minutes to discharge down to 10 volts. And the...
                  08-24-2023, 02:55 PM
