Newegg.com Site Problems
  • ncovert
    • Feb 2011
    • 291
    When I try to visit newegg.com, I get this:
    "Thank you for visiting newegg.com. We are truly sorry for any inconvenience but we are currently experiencing problems on our server. Please try again at a later time.
    If you have any questions, please contact us and our helpful staff will alleviate any concerns you may have. errorcode: 2 "
    What does this mean? I haven't been able to browse the site for nearly 24 hours and I want to look at stuff (I haven't bought from them yet). Once I can get back on, I will give them alot of grief since they gave me so much!!
    Newegg.com on the left, me on the right on the emoticon.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Newegg.com Site Problems
    Works fine for me. Could it be something on your end that's doing it?
    A man convinced against his will is of the same opinion still.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      seems fine to me...
      possible they transferred to a new server but your ISP still cached the old one's IP address?
      • ncovert
        • Feb 2011
        • 291
        I seem to get it after browsing for a couple hours
        • jean luc ferre
          laptop hp g72 b52sf screen problems
          by jean luc ferre
          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
          06-07-2025, 03:27 PM
        • Hondaman
          USB problems?
          by Hondaman
          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
          08-12-2024, 03:26 PM
        • clabr
          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
          by clabr
          Need help to solve some problems with this laptop.
          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
          Before this had happened I observed some other problems:
          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
          12-02-2021, 08:09 AM
        • rumpumpel1
          Lenovo X13-Yoga Gen 1: hibernation problems
          by rumpumpel1
          I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
          11-03-2024, 12:31 AM
        • howardc64
          Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
          by howardc64
          Failure Symptom
          No Display. Just random blocks of grouped vertical red lines.
          Disconnect right 1/2 panel (rear view), left 1/2 displays properly
          Masking T-Con Signal Diagnostic
          Reduced masking to 5 signals on right 1/2 panel and get perfect picture
          Pins are
          1 GND
          2 VGHD
          3 XON
          4 VSSQ
          5 LC2
          6 LC1
          VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
          Pictures and Schematic
          XON, LC2, LC1 are on AUO s302-21 32pin QFN...
          10-14-2024, 01:30 PM
