I need to make a fan controller.
  • shadow
    • Feb 2007
    • 732
    Re: I need to make a fan controller.
    Originally posted by Mad_Professor
    Ok so I'm working in tinycad since veecad needs a netlist to place components.
    Anyways I just realized something, do I need to have digital outputs for each set *1k>tip120>fan* that say PWM on the arduino pin out or can I use one PWM output to control the 5 transistors?
    If I can't then can I use any pin that says digital I/O?
    http://arduino.cc/it/Hacking/PinMapping168
    This left side of the chip and place the chip to the right on the board.
    I was going to use,
    digital I/O PWM pin 3/actual: pin 5 on chip
    digital I/O PWM pin 4/actual: pin 6 on chip
    digital I/O PWM pin 5/actual: pin 11 on chip
    digital I/O PWM pin 6/actual: pin 12 on chip
    I want to use
    Digital I/O pin 7/actual: pin 13 on chip
    But it doesn't say PWM. I don't know if I can use it as PWM connection.
    I was going to put the pot on the right side of the board too and connect it to where it says analog PC0.
    Then below the chip put my DAPA header and run the lines to the right side of the chip.
    Then the left side can be used for tip120, diodes and resistors and headers.
    It has been a while since I checked out this thread. I say the easiest and most flexible way of achieving what you want is to connect each transistor to a PWM output. In theory, one could power all five transistors from one PWM output. However I doubt that the current output from the microcontroller will be able to power five transistors. Therefore you will probably need another transistor to provide the extra power required to energise all five transistors at once from a single microcontroller output.
    I would suggest to use the same PWM outputs as the Arduino. That way it is much easier to program using 'their' language. Not all Digital I/O pins can be configured for PWM use. Only one or two ports on the microcontroller will support PWM output. From memory, there are more PWM pins than what the Arduino's provide on their boards (this would have to be confirmed by checking the datasheet for the ATMega168), however if you use these pins, it will be difficult to make use of the Arduino C like language and their hardware libraries. On top of that, perhaps those extra PWM outputs are required for other purposes such as ICSP programming.
    For the software side of things, I tried a fair few free products and found them all to be quite difficult to use (to design stripboard layouts). I found Lochmaster very good and intuitive for stripboard design. Unfortunately you can not design a schematic in it. Therefore you have to verify your layout against your schematic manually. For your circuit, it should be pretty simple. However it would be a problem for complex circuits, however stripboard is not that effective for complex circuits so it's unlikely to be used for such complex designs.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      #62
      Got the parts today. Its on a breadboard. When I was putting it together I realized I made some errors in my schematics.
      My inductor was on the wrong pin, needed to be on AVCC. My 10k resistor for reset was connected to ground.
      Wrote some code but I don't know what board to compile for.
      Not to be vague but under tools > boards > ??
      Code:
      int fan1= 5;
      int fan1val = 0;
      int pot1 = 0;
      void setup() {}
      void loop() {
      fan1val = analogRead(pot1);
      fan1val = fan1val / 4;
      analogWrite(fan1, fan1val);
      Tomorrow I'm going to get my old p3b-f board and load XP or linux, whatever I feel like using and hack up a parallel cable and make an attempt to load this sketch on to the chip.
      Also can someone double check and verify my breadboard setup, I don't want to fry something but I think it's correct.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4950
        • New Zealand
        #63
        For a basic one like that I think Arduino NG
        -David VanHorn
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          #64
          It looks like I can set the fuses through Arduino.
          I just copied and paste the section from NG w/Atmega168, and changed whatever I need.
          This is a snippet from boards.txt
          Code:
          atmega168.name=MYBOARD w/ ATmega168
          atmega168.upload.protocol=Parallel Programmer
          atmega168.upload.maximum_size=14336
          atmega168.upload.speed=19200
          atmega168.bootloader.low_fuses=0xe2
          atmega168.bootloader.high_fuses=0xdf
          atmega168.bootloader.extended_fuses=0xf9
          atmega168.bootloader.path=atmega
          atmega168.bootloader.file=ATmegaBOOT_168_ng.hex
          atmega168.bootloader.unlock_bits=0x3F
          atmega168.bootloader.lock_bits=0x0F
          atmega168.build.mcu=atmega168
          atmega168.build.f_cpu=16000000L
          atmega168.build.core=arduino
          atmega168.build.variant=standard
          EDIT:
          Remind me to NEVER BUY this again.
          http://search.digikey.com/us/en/prod...0982-ND/698225
          I can't get the fucking metal contacts out so I can hook up my wires to them.
          Worthless piece of shit.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4950
            • New Zealand
            #65
            There should be a piece of metal sticking out from the side of the contact that clicks into place in a hole in the plastic header.
            Just push this down with a pin or stiff wire and then push towards the opening. Or you can probably grab the other end with needle-nose pliers, or stick another piece of wire in through the bottom to push the contact out.
            -David VanHorn
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              #66
              Yeah the metal slides on the side yeah I push those down it did not slide I attack from the top with pliers and damaged one of the contacts. I give up, I'll wired directly to the breadboard.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4950
                • New Zealand
                #67
                Odd, it must be a different type of connector to what I am thinking of then, it might need a special insertion tool or something.
                -David VanHorn
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  #68
                  I managed to get them out, but I had to use an ice pick and lot of pressure to get them out.
                  • Mad_Professor
                    A Mech Warrior
                    • Feb 2011
                    • 1587
                    #69
                    IT WORKS!
                    I'm still having problems with the arduino software but the controller works as planned. Also I just realized I got the wrong voltage regulator, I got one with input 7v-35 instead of 0-35v Oh well I'll just stick it on the 12v anyway.
                    The problem I'm having with arduino software is when I made a board in boards.txt and tried to use the upload button but it spits out an error stating that it could not open port com 1 because com 1 is not a valid port for dapa it needs to be lpt1,2, or 3. But I can't find the setting to specify it.
                    I work around it using the upload via programmer option in the file menu.
                    This is pretty sweet.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4950
                      • New Zealand
                      #70
                      Upload is designed to upload through the serial port and the bootloader. If you don't have these in your circuit you must use upload via programmer. So that's not an error, it's by design.
                      Good to hear it goes!
                      -David VanHorn
                      • Mad_Professor
                        A Mech Warrior
                        • Feb 2011
                        • 1587
                        #71
                        What's the max amperage for 23 awg wire? I plan on running two wires, one for ground, one for 12v to the first tip120 header then daisy chain from there?
                        But not sure if 23 gauge is safe for a 5 fan load? The wire came out of short piece of cat6 cable I had laying around.
                        • mariushm
                          • May 2011
                          • 3799
                          #72
                          See http://www.powerstream.com/Wire_Size.htm
                          It will do 5A easily, 7-8 amps with some heating up. But why daisychain... don't think that's best.
                          • Mad_Professor
                            A Mech Warrior
                            • Feb 2011
                            • 1587
                            #73
                            Because having 10 wires going back to the molex connector is messy.
                            • shadow
                              • Feb 2007
                              • 732
                              IT WORKS!
                              Pretty good that it worked first time.
                              Congratulations.
                              Now onto making a more permanent solution with five fan outputs.
                              In one of my previous posts, it explains how to add another 'board' in board.txt file to use a programmer to upload a program to the controller. However the blog entry may have been a bit old and outdated.
                              I can't seem to find any upload via programmer option. Maybe it is because I don't have a USB connected programmer and my laptop does not have a parallel port.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4950
                                • New Zealand
                                #75
                                Maybe, but do you have the latest version of Arduino IDE as well?
                                -David VanHorn
                                • shadow
                                  • Feb 2007
                                  • 732
                                  That could be it as well.
                                  • Mad_Professor
                                    A Mech Warrior
                                    • Feb 2011
                                    • 1587
                                    #77
                                    It is done! Fresh out of the oven!
                                    I shall call you FRANKENSTEIN!!!
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Good work. Looks nice.
                                      sigpic
                                      (Insert witty quote here)
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4950
                                        • New Zealand
                                        #79
                                        Powering up your circuit on a conductive anti-static bag probably isn't the best idea.
                                        -David VanHorn
                                        • Mad_Professor
                                          A Mech Warrior
                                          • Feb 2011
                                          • 1587
                                          #80
                                          scotch taped the bottom. But that's funny, I've put motherboards and other stuff on anti-static bags, never had a problem.
                                          Didn't know those were conductive.
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • master3112
                                            ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                            by master3112
                                            I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                            When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                            10-29-2024, 09:32 PM
                                          • nmbb
                                            Can not find Model/Value of Thermistor.
                                            by nmbb
                                            Machine: Autoclave.
                                            Brand/Model: SANYO MLS-3780
                                            Manual: (Sorry search option not working on this PDF)
                                            Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                            06-02-2022, 05:55 PM
                                            TL494 PWM Controller Module Booard to control a SMPS switching power supply are they available for this purpose
                                            by sam_sam_sam
                                            I have seen some board on eBay and Aliexpress but I have not seen any for SMPS switching power board modules I would like to build one if I can not find one that is already made
                                            Dose anymore known if there is such a module and where would I find some
                                            While searching this topic on google I found this
                                            https://www.badcaps.net/forum/troubl...anything/page3
                                            I have read through this I have some switching...
                                            09-16-2024, 05:39 AM
                                          • sikocan
                                            Lenovo X1 Carbon 9th Gen Black Screen
                                            by sikocan
                                            I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                                            SN: PF3G1REP
                                            MODEL: 20KW-00J1AU
                                            PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                                            Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                                            06-24-2025, 09:01 PM
