Which Power Supply Is Best ????
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Which Power Supply Is Best ????
    Originally posted by mariushm
    Each PCI connector is rated for 25 watts maximum, yet with 5 pci connectors you'd have 125 watts or 25A solely for pci slots. It doesn't make sense to design a power supply for that much wattage on 5v.
    Nope.
    For 5v it's 2 amps/slot = 10wats/slot.
    That's no where near 125watts as you implied and it's not at all unrealistic.
    The PSU's you brought up have 20a on 5v for 100 watts.
    Lets see where it goes on a 5-slot board.
    5 x slots = 50 watts.
    Maybe 10-20 watts for RAM depending on the system type.
    3 x HDD assuming 1 amp/@ = 15 watts
    1 x Burner = 10 watts
    Total = 95 watts on +5v
    Nearly all mobo IC chips are 3.3v these days so that's rarely a 5v load.
    It's also generally accepted to be around 35 watts. [Not sure how accurate that is.]
    Some of Intel's TPS and Design Guides break down motherboard loads rail by rail.
    If you read a few of them you can get a better idea of what goes where in so far as power.
    A rare few also have schematics of mobo power distribution.
    Mann-Made Global Warming.
    - Dr Seuss
    • colormebad
      colormebad
      • 114
      Originally posted by PCBONEZ
      Yeah, I built street rods on the side for about 20 years.
      I don't think I'd put a drag motor in a school bus though.
      Hey' a friend will have 2 drag motors in a school bus at an upcoming race at Memphis Motorsports Park soon..Does a wheelie all the way down the track...LoL Im about 50 mins from Memphis Tenn...
      • mariushm
        • May 2011
        • 3799
        #43
        The PCI connector has two pins which determine the maximum power... I admit it's for 5v+3.3v+ -12v combined, I guess. Considering most PCI cards don't use 3.3v at all, it's not unexpected to have all load on 5v.
        http://en.wikipedia.org/wiki/Convent...nnector_pinout
        At least one of PRSNT1# and PRSNT2# must be grounded by the card. The combination chosen indicates the total power requirements of the card (25 W, 15 W, or 7.5 W).
        Real world example: http://www.hisdigital.com/un/product2-444.shtml
        The 4350 chipset does about 8 watts on 2d and about 18 watts in games, as shown here: http://www.behardware.com/articles/7...ics-cards.html
        That's without adding the 0.5-2w consumption of the pci express to pci bridge chip.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          The problem with that is card builders are -allowed- to use up to 2a on +5v.
          ... And card builders rarely tell you where their cards get power from.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Originally posted by dood
            So, I'm a bit confused. I don't see how what a computer draws from the outlet makes any difference. When you use the Kill-a-watt, you're talking 270w @ line voltage. That's NOT the same as wattage @ lower voltage, if I understand correctly. So, 270w at the wall is not what your PC is drawing on the 12v rail (if we simplify it and constrain everything to one rail). Am I mistaken here?
            Yes you are confused a little.
            In AC - Efficiency Losses = Out DC
            If the PSU is 80% Efficient and 270w at the wall. [In AC]
            20% of 270w = 54w
            So Out DC to the PC would be: 270w - 54w = 216w
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Originally posted by Scenic
              For the system he posted, and because he said he's not a gamer (onboard video), i'd say get a solid 500-600W and it'll handle everything he could possibly upgrade on that system, except a high-end graphics card for gaming.
              I don't know anything about the PSU that came with the kit (link), but if it's honestly rated, it's fine the way it is IMHO. (i.e.: overkill for the current sys, having lots of headroom for upgrades later on)
              I have dual Xeon server boards w/OB video and 2x Gb-LAN that only call for a 500 watt as the minimum.
              - The problem is getting those watts on the correct rails.
              You take one of those and magically change the second CPU into more substantial video and the second LAN into sound and you pretty much have an entry level gaming system.
              There really just aren't that many GP PCs that need more than 500 watts.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Does he drive it to work in the morning?
                - Dr Seuss
                • colormebad
                  colormebad
                  • 114
                  Only when hes running late....
                  • colormebad
                    colormebad
                    • 114
                    Here is a bad enough P-S to crank your lawn mower also...
                    http://www.tigerdirect.com/applicati...1&sku=ULT40070
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      be careful... ultra's products are hit and miss... and by that, i mean at best you'll need a recap and at worst you have a underweight door stop.
                      my xfinity 600w was a good one, and it needed a recap and a slight 5vsb mod... my ultra V 550w was gutted (no OCP protection, poor parts/filtering, thin wire galore).
                      sigpic
                      (Insert witty quote here)
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Apparently its 1600w tag is a little... generous. Consider this note on that page:
                        "Note: This unit is not rated for power supplies in excess of 1 kW."
                        Uhhhh....
                        Ludicrous gibs!
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          At this point I think it's clear OP doesn't care what it is as long as he spends more than the neighbors.
                          Waste of our time.
                          I'm outta here.
                          - Dr Seuss
                          • colormebad
                            colormebad
                            • 114
                            This is christmas ' have a little christmas humor
                            I just like looking at all these & reading up on them...I already installed the little 560 that came with the barebone kit....Merry Christmas ...
                            PS: Wouldnt the Modular units just cause more connection problems...I know i solder alot every day...Where everything is soldered it will be there for a long time when done right' just like a good welder...But with that many plugs' they have to get dirty & you will have alot of plugs to go through to find the problem.....
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Uhhhh....
                              thats an Ultra for you...
                              they will probably be the first to market a 2000W psu.
                              note that i said market, not manufacture.
                              in fact, you could make it a 2000W just by printing a label and slapping it on... according to ultra, that worked for the above PSU!
                              sigpic
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
                              • CMCM
                                Russound CA4 Power Supply Repair
                                by CMCM
                                Hello Everybody,
                                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                The outputs marked 12v and 20v are all measuring only 1v.
                                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                The capacitors physically look clean (no bludgesor leaks) and...
                                07-03-2025, 01:12 PM
