Dell 4600 being stupid
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Got this as a freebie - It would either make terrible beeping noises upon startup (turned out to be girinding from the hard drive not a beep from the mobo), then not boot up at all. Or BSOD after trying to load (safe mode did the same thing).
    The hard drive is a HDS722580VLAT20. I put it in their computer about 2-3 years ago, loaded XP on it, and apparently the computer worked fine more many months. Then they moved it to a different house and it apparently hasn't worked since - probably physical shock causing failure...
    So, whatever I dust out the PC, replace the PSU with a recapped FSP/SPI just in case the PSU is causing problems (a little rusty and dusty but no bad caps but I still replaced it), put in a Maxtor IDE 100GB drive. Pop in my Server 2003 drive, do an NTFS quick format, and get a bunch of file copy errors. I skip failed files (despite) dire warnings that setup might fail if I did it...
    Anyway, needless to say, I got a BSOD after it restarted to run setup. So I remove the drive, set is from Cable Select to Master, now I'm doing a non-quick-format and hoping it works. However, I'm concerned there might be another problem with the PC since it's being stubborn installing the OS...
    EDIT: still file copy errors. What can I try? I'm going to try to put the Shitachi back in...
    All caps look OK.
    Edit2: Shitachi drive isn't making too many weird noises, and is doing a non-quick-format right now.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Dell 4600 being stupid
    Memtest
    Mann-Made Global Warming.
    - Dr Seuss
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Now that's a good idea - didn't think of that!
      If this won't install I'll try that...
      Could the DVD drive be faulty?
      The CD drive under it won't read at all... weird...
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        bad caps? the 4600 was notorious for bad psu caps (they made a top xx list for the worst computers ever made over the issue).
        hope you can fix it, as my mom has a 4600, and with a better/fixed psu, they are great boxes... lots of usb, good audio, SATA, agp 8x, and 4x ddr (for a dell, that is nice, better than 2). they are also both prescott and HT compatible (I put a 2.8 ghz 533 prescott in my mom's, runs nice).
        sigpic
        (Insert witty quote here)
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Well, I'm running memtest86 bootable CD as we speak (type?)
          PSU was checked for bad caps. None, however, due to rust and dust, I put in a re-capped tested-good SPI(FSP) 250-watter...
          It failed even with the formatted 80GB Shitachi.
          I doubt both HDDs are bad in the same sector(s?)
          The first file to fail copying to the HDD was authm.somethingorother both HDDs...
          bad CD/drive?
          The 4600 have pretty good CPU support, and yes I like a 4 memory slots (unusual on these Dells)
          I've got a 4600 as Server #2 in my closet running Windows Server 2003 - a bit on the slow side by reliable as fuck...
          EDIT!: Memtest looks fine. I cleaned my Server 2003 CD and am trying again...
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Yup.
            A bum CD or drive would be my next guess.
            Might just be a case where 'that' drive doesn't like 'that' CD too.
            - Dr Seuss
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              My Windows Server 2003 disc might be bad. Lubuntu installed w/o a hitch.
              • c_hegge
                • Sep 2009
                • 5219
                Could also be that the drive is unusually sensitive to scratches. I've seen that a lot of times. Try installing windows with another DVD drive.
                EDIT: You supplied a Deathstar?
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    its hitachi, not IBM... I am quite happy with my 40gb one...
                    (edit- I saw his other thread, his may be a different story.,.. mine was a 2005 model, is a 2003).
                    sigpic
