VP6 final board revision
  • uforic
    • Feb 2004
    Hi Topcat,
    I like to enquire what is the last board revision of VP6, and how many inbetween from the first to the final revision. Can you also advice me which is the best revision to get.
    I am looking at a few at my local 2nd hand store. I intend to recap the board like you have advice, I might even sent it to you to repair. But I am in asia. What do you suggest, thank you very much.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    The only version of the VP6 was 1.0... There were no factory revisions on this board, I guess this is one Abit got right for once (except the bad caps)...
    Just just shout if ya have any questions!
    TC
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • uforic
      • Feb 2004
      VP6 in China
      Thank you for the info.
      I have never done a recap before, kinda worried but also excited that I have used for my 2nd p3-866 and those extra pc150 rams that I slavage from my CUV4 mobo.
      I can sent your the VP6 and money order you the return shipping charges as well, how much do u charge in total for replacement caps, work and so forth?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        if those other vp6 boards at the secondhand store are real cheap i would grab them.
        nice to have a spare and they are good trade bait.at least to me.
        bet tc too.
        and i have never seen any rev other than 1.0 either.
        i have seen several hundred of these boards for recapping here.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          does anyone know the total production for the vp6?
          for instance one i am recapping this morning has a serial of tic004366
          or is the serial the one on the left with more numbers?
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16955
            I have no idea what that figure is. It would be interesting to know, it seems there's a never-ending flow of them with bad caps. All the serials on any VP6 I ever worked on was 'VP6-Txxxxxxx'....
            Team : 49813
            Join in!!
            Team Stats
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • sfernandes
              Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
              by sfernandes
              Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
              What I have done to try to isolate the issue so far:
              The system powers on and stays on with...
              01-23-2023, 06:03 PM
            • jimbodriver
              Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
              by jimbodriver
              I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
              Initial results:
              Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
              03-20-2022, 02:30 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
