Strange SDRAM DIMM
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Strange SDRAM DIMM
    The notches aren't wrong. - It's unbuffered.
    So you are suggesting it's 'unbuffered-registered' RAM?
    Mann-Made Global Warming.
    - Dr Seuss
    • Old Thrashbarg
      • Jan 2010
      • 20
      Huh... Schrodinger's RAM. Registered = buffered, so it's both buffered and unbuffered at the same time, until you turn it over or look closely at the keying...
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Originally posted by Old Thrashbarg
        Registered = buffered.
        I'm aware of that.
        Yet after I showed the key is for Unbuffered U-235 still thinks it's Registered.
        - Dr Seuss
        • Old Thrashbarg
          • Jan 2010
          • 20
          And that's exactly what I was making a jab at. I figured you were aware of the distinction, but U-235 apparently isn't.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I wasn't sure.
            I never heard of Schrodinger's RAM.
            - Dr Seuss
            • ugamazing
              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
              by ugamazing
              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
              08-31-2022, 07:34 AM
            • flibidy
              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
              by flibidy
              I have here a Magnum IA.100 which belongs to my parents.
              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
              What Ive done........
              01-01-2025, 01:26 PM
            • feherhollo
              WSON8 NEW Bios Chips READ, ERROR, ETC.
              by feherhollo
              I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
              I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
              For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
              11-26-2023, 09:33 AM
              LENOVO V520 i5-7400 Specification for Upgrade or Repair
              This specification for the LENOVO V520 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the V520 boardview and V520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO V520 is accurate, safe,...
              09-12-2024, 01:58 PM
            • Novgorod
              Asus Strix Z270i Gaming dead DIMM troubleshoot
              by Novgorod
              Hi!
              I have an Asus Z270i mini-ITX board with a dead DIMM slot (the one further from the CPU). The board POSTs with only the other DIMM populated but gets stuck with the DRAM error LED when the bad slot is populated. The test RAM and CPU are known working (confirmed in a different board, both memory channels are fine). The board was working for many years in a watercooled system and had a tiny bit of corrosion in different places (which came off without issues) and no visible component or trace damage.
              What are the steps for DIMM (DDR4) socket troubleshooting? Since the...
              07-13-2024, 02:35 PM
