Elcon ?
  • CON
    • Mar 2006
    • 13
    Elcon ?
    What the heck is elcon ? Did a search on the forum but didn't turn up any results!
    Anyone know are they good ? or bad ? or so-so ?
    My Turtle Beach Santa Cruz soundcard is littered with these, with a few exceptions of G-Luxon and Lelon - both of which turned up in the "list of bad caps" thread
  • Chris1992
    • Apr 2005
    • 561
    Re: Elcon ?
    audio applications are low stress, I wouldnt worry.
    The great capacitor showdown!
    • CON
      • Mar 2006
      • 13
      Re: Elcon ?
      actually its not about stress or ratings. Its about ESR and inductance. In the audio signal path Low ESR, Low inductance capacitors are recommended.
      So no I not at all worried about their bulging or blowing up, I am mostly interested in knowing about Elcon's quality in terms of esr & inductance.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Elcon ?
        elcon's site is not working http://www.elcon.com.tw/ who knows what became of them.
        my audiophile 192 has g-luxon so it appears common to see crap on sound cards
        https://www.badcaps.net/forum/showthread.php?t=708
        • bgavin
          • Jan 2007
          • 1355
          Re: Elcon ?
          I'm resurrecting this old thread to see if anybody has more current info on ELCON caps.
          I'm finding ELCON EEZ caps on some video cards.
          These a solid-poly lookalikes, but actually are vent top electrolytics.
          I wonder if this is a cheap ploy to sucker buyers with "polys".
          The caps in question in 1000uF/6.3v 8mm types.
          Cards are nVidia 8500GT, and work perfectly.
          Cap temps are very cool as long as the card is correctly cooled.
          I use fanless cards with big sinks, and an external cooler such as the Rocket V
          This card is bound for a BTX chassis, so I screwed an 80mm Panaflo to the heat sink.
          • ImpossibleRepairs
            Turtle Beach Velocity one flight universal control system
            by ImpossibleRepairs
            Hi Good peoples;
            Been working on a turtle beach Velocity one flight controller; The slide pot for the throttle (black) isn't calibrating properly, it will register the axis with some wriggle until pressure is released;
            Does anyone know the specifics for these Potentiometers?? I have attached photos;
            Board number is LBX-19500,
            C-V1.1 202011
            please and thanks as always...
            05-07-2024, 02:19 AM
          • reessi
            Huawei D14 - DAH98AMBAD0 Rev.D - Laptop not Charging - Missing 137K on IADPT - Inductance Selection - BQ25713 Charging IC
            by reessi
            Hello:
            On the above laptop which wasn't charging I found only a tiny drop of water damage exactly on a few components by the BQ25713 Charging chip.. Bizarre how only that one 3mm square for it but it did..
            I looked up the BQ25713 datasheet and replaced the 10K pull up resistor on the CHRG_OK line and now it charges!
            But on the IADPT line which seams to be a resistor (137K) to tell the chip which Inductor is in use it is corroded also.. (Inductance Detection Through IADPT Pin - from datasheet).
            So my question is what are the implications of leaving...
            03-06-2024, 07:33 AM
          • Paba
            Turtle beach 600 dongle
            by Paba
            Hi there.
            Got dongle with water damage. All corrosion cleaned and broken traces repaired. But I have 3 missing components marked as "PB" it looks like diode but don't know how to find a proper replacement. Please help and thanks in advance...
            03-18-2024, 02:19 AM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
          • philtvman
            Turtle Beach 420X Blown Ferrite Bead
            by philtvman
            Working on this pair of headphones that will not stay powered on.
            A ferrite bead inside looks like it's fried and will need to be replaced (who knows if that's all that's bad). My question is, is there any safe assumption for a replacement? I don't think there are schematics for the board anywhere online unfortunately, so I have no idea the exact specs of it.
            Any advice would be much appreciated....
            01-22-2020, 12:31 PM
