Cross-Flashing BIOS: Intel915GAV to Asus P5GV-MX
  • bigbeark
    • Jan 2010
    • 661
    I have an Asus P5GV-MX board which is based on the Intel 915GV chipset.
    The Asus board will not recognize SCSI as a boot option, but the Intel 915GAV board I am writing this on, does.
    Has anyone here cross-flashed Asus boards successfully.
    I downloaded the Intel Bios and want to install it on the Asus board.
    Any cautions, suggestions or other info welcome.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Cross-Flashing BIOS: Intel915GAV to Asus P5GV-MX
    It won't work unless the hardware is absolutely identical.
    This incudes details like the model of the clock generator and how the GPIOs are connected on the southbridge.
    It may be easier to enable the option in the BIOS using a tool like MODBIN6 (Award BIOS only), or only change the boot module.
    • brethin
      • Dec 2008
      • 1907
      Not true, you could force flash it if you have the right software but I would not do it with a Intel bios and would make sure you had a backup bios chip to replace the one you are going to most likelly brick. Try flashing it with another ASUS bios that is really close to your board with the features enabled you want.
      Better safe than sorry.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
