Recapping Abit BG7m with polymer
  • Barchetta
    • Oct 2011
    My decade old Abit 478 pin P4 533 MHz FSB board finally ceased to function reliably and killed its ATX power supply. Visual inspection revealed eight 2200uF 6.3V HM(M) HD147 Nichicons bulging/leaking (and two empty spaces) near the processor, and one lonely 1000uF 10V HM(M) HD139 Nichicon bulging (and one empty space) near the ATX power connector. The other smaller caps appear ok.
    After some research (mainly badcaps.net and this forum), I ordered 10 Nichicon 1800uF 6.3V polymer caps and 2 Nichicon 820uF 10V polymer caps from Digi-Key.
    I could not find the ESR and ripple of the originals for comparison (I obviously don't know where to look) so I just settled on 82% of the original capacitance, the same voltage, and ordered enough polymer caps to fill the empty spaces. I decided to use polymer because it seems more interesting than returning the board to original specs.
    The board would have very little value to me even if I fixed it (it's the slowest of the seven computers in the house), so this is more for my own entertainment (and I might learn something - like how inadequate my soldering skills are).
    Will the caps I ordered work? or at least not burn the house down?
    Filling the empty spaces seems like a good thing, I figure the spaces are there due to "cost improvement". Any reasons I shouldn't do this? What are the effects of adding parallel caps?
    Is there anything I can measure with a multimeter or 30MHz oscilloscope (I know - it's like WWII era) to quantify my results (if any)?
    I have a basic plan of what I'd like to do, but I am open to suggestions or warnings of impending doom!
  • c_hegge
    • Sep 2009
    • 5219
    Re: Recapping Abit BG7m with polymer
    Those caps should be fine. I'd fill up the empty spaces as well. I've done that a few times before.
    • Barchetta
      • Oct 2011
      I had been trying to do a clean install of XP before this repair; it passed the point where it was hanging with 33 mins. to go and completed the install. It was rebooting alot so I figured it didn't survive my soldering. Since half of the previous install was with the bad caps I started over.
      XP is now installed with all the updates. I think the security updates could be considered a burn-in test just because of the number of them. I'm still having the same trouble with the dvd rom drive, where it works just fine for the XP installation only. Once XP starts, dvd access gives errors or fully locks the OS.
      I've been running memtest for almost three hours with no errors, and nothing has exploded! Yet.
      • silvergoat
        • Oct 2011
        • 53
        How do you know what type of capacitor to add into the empty spaces?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          They're in parallel so you just add more of what's already there.
          A working TV? How boring!
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            They're in parallel ....
            Not always.
            You have to check.
            Mann-Made Global Warming.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The "eight 2200uF 6.3V HM(M) HD147"
              is actually:
              - eight 2200uF 6.3V HM(M) H0147
              That's 2001, week 47 and part of the defective production run.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I wouldn't bother with polys outside the VRM.
                Doesn't get you much unless you have heat issues.
                With good Polys [ESR under .010], as long as the total uF in Vcore is 5500uF or more and you use 7 or more poly [for combined ESR] - you should be fine.
                That is what it typically used on factory 'poly boards'.
                Some boards do okay with less but you have plenty of caps 'spots' available so don't skimp.
                [8x 820uF would be a great way to go.]
                For the 16v VRM caps 3x 470uF or 4x 330uF works fine.
                Historically with lytics they over-kill the uF in VRM's.
                It's not about the uF, they used those caps to get the ESR lower.
                - Dr Seuss
                • DrewPhillips
                  Capacitor Diarrhea - Nichicon PL Series
                  by DrewPhillips
                  Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                  The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                  03-02-2025, 10:18 PM
                • chth96
                  Should I replace polymer capacitor?
                  by chth96
                  a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                  I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                  Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                  Is this ESR value of polymer capacitor correct?...
                  11-18-2022, 04:22 AM
                • nick3092
                  Mid/late 80's Nichicon Yellow Caps
                  by nick3092
                  I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                  08-28-2022, 03:56 PM
                • chth96
                  Is there datasheet for nichicon LXJ series?
                  by chth96
                  I want to calculate capacitor ESR referring to below guide.
                  https://forum.digikey.com/t/calculat...-from-tan/2633
                  I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                  I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                  Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                  11-20-2022, 08:11 AM
                • chth96
                  Is there any datasheet for nichicon RT(M) series?
                  by chth96
                  A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                  https://www.badcaps.net/forum/troubl...e-been-blew-up
                  and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                  But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                  I have spare console...
                  11-28-2023, 03:36 AM
