FYI: Cheap CR2032 at Harbor Freight
  • mathog
    • Mar 2010
    • 2655
    I was in sudden need of a CR2032 this weekend and didn't have any on hand. These batteries usually cost 4-6 dollars each at the local stores. Much to my surprise, I found a set of 4 for $1.99 (on sale from $2.99) at Harbor Freight. The manufacturer is "Thunderbolt Magnum", which should probably be read as "whichever nameless Chinese battery manufacturer wins the contract that week".
    http://www.harborfreight.com/4-pack-...ies-68129.html
    I don't know if they are any good or not , I mean, in terms of how long they hold up in long term use, but the one of the four I tested did have the right voltage.
  • mariushm
    • May 2011
    • 3799
    Re: FYI: Cheap CR2032 at Harbor Freight
    Monoprice.com has them for $0.69 each:
    http://www.monoprice.com/products/pr...seq=1&format=2
    Amazon.com has a ton of them as well:
    http://www.amazon.com/s/ref=nb_sb_no...CR2032&x=0&y=0
    pack of 25 for $4.32 or 50 for $7 if you're into relatively noname, about $1.5-$2.5 for 5 if you're into brands (Energizer etc)
    • mathog
      • Mar 2010
      • 2655
      Sure, lots of places to get them cheap on the internet. Not much use though if you need one "right now". Around here the only brick and mortar store around here that sells them at a low price seems to be Harbor Freight.
      • brethin
        • Dec 2008
        • 1907
        One of our local mom and pop drug stores sells them for $0.89 (Sony Brand). Never hurts to shop the smaller local business.
        • Dammon
          Ensign
          • Jun 2010
          • 36
          I usually pick some up at a dollar store. They typically come in packs of 3.
          • mathog
            • Mar 2010
            • 2655
            Actually I did look in one. The only batteries they had were "super heavy duty". No alkalines, no CR or other button types.
            • Old Thrashbarg
              • Jan 2010
              • 20
              I noticed the other day that Ace Hardware also carries some random cheap Shenzhen Flybynight™ brand button cells... at least the local one does, but I'd assume they've all got similar stock. I forget the exact price, but it was somewhere in the range of $2-3 for a pack of six. They also had some assortment packs with quite a few common sizes.
              • caphair
                Harbor Freight car battery chargers any good?
                by caphair
                I was gifted a $50 HF gift card and could use a battery charger. Just not sure if the HF brands are any good.
                Anyone bought/use any they can recommend?
                Out of their selection and reviews was contemplating this one:
                https://www.harborfreight.com/automo...ner-63350.html
                05-08-2021, 06:34 AM
              • H34TO
                ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                by H34TO
                Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                06-17-2025, 07:17 AM
              • evilkitty
                When your mom is complaining about her new cheap lights
                by evilkitty
                My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                07-23-2024, 01:27 PM
              • aaronkatrini
                by aaronkatrini
                - Autorange
                - DC volts up to 30V
                - Accurate Resistance
                - Diode test (Beep mode)
                - Frequency up to 200MHz
                - Capacitanze up to 5000uF
                - as cheap as possible
                05-06-2024, 09:54 AM
              • SolomonMan
                Electric Button Breaker Thermal Overload Protection
                by SolomonMan
                All,
                I have two 120V compressors that I have been working on. Both are getting new Capacitors.
                As I am replacing the capacitors I am looking over the other electrical components.
                One compressor is a Harbor Freight 21 Gallon Vertical . The other is Horizontal Craftsman which is roughly the same size. The one Harbor Freight Capacitor was fried and the other looks like it may have opened. The Craftsman Starting Capacitor was/or has been leaking badly.
                The Harbor Freight Thermal Overload protector was lost over the past 10 years after the unit was originally...
                10-17-2022, 07:52 AM
