Video card not initializing but computer still boots up!!?
+ More Options
Posts
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    As the title says, when I boot up my computer everything is humming a long but the monitor is on standby mode. However throughout this whole process I actually hear the Windows 7 intro sound, which tells me the computer is ready.
    Now when I disconnect the monitor's DB-9 cable from the GTS-250 video card and plug it in instead to the built in VGA, I'll see the Windows desktop. And then I decide to completely turn off the computer and while turned off connect the DB-9 cable back to the GTS-250 and surprise...surprise.....everyhting is working again. It's like the only way around this is to turn off the computer and turn it on agian.
    So any idea on what's causing this?
    1) Video card dieing?
    2) Video card not getting enough power?
    3) Mobo-related issue?
    4) PSU not handing out enough juice?
    TIA for any ideas.
    P.S. Specs got overhualed:
    MY RIG:Intel C2D E8500|G31M-S2C|512MB Inno3d Nvidia GTS-250 with one 6-pin power connector|4GB DDR2-800|Seagate 500GB SATA|W.D. 250GB SATA|LG DVD-RW IDE|17" CTX LCD (1280x1024)|Silver Stone ST-400|Antec 300|Windows 7 Ultimate (64-bit)
    Second P.S.: It's been a while since I last visited here.
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Video card not initializing but computer still boots up!!?
    db9? thats a serial cable connector (also used on the original color monitors in the dos days). you mean 15 pin VGA?
    clean the contacts on the slot and card. if you can try another card in the slot (borrow one if you need to).
    if the card has a power conenctor, check the pins for corrosion
    what model mobo and PSU are you using?
    is your BIOS up to date? it might help to update that.
    sigpic
    (Insert witty quote here)
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      So you say the onboard graphics kicks in first. Go into the BIOS, find the VGA Boot From (or similar) option, and set it to PCI-E. That should do it.
      A working TV? How boring!
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Agreed.
        • TBoneit
          • Jun 2010
          • 70
          It sounds to me as if the onboard is set to be first and then in windows the video card is set as the main monitor.
          • grss1982
            • Mar 2007
            • 225
            • Philippines
            Thanks for the tips everyone. Looks like it was indeed a BIOS setting. God grief, I'm getting old.
