iMac G5 diagnostic lights?
  • ub6ib969
    • Jul 2010
    • 200
    I Have a few questions about my 17" imac 1.8ghz G5. I was receiving a chime but only diagnostic lights 1 and 3 appeared lit. I am receiving nothing on screen. I was told to use this method to diagnosis mainboard caps. I found the transistor that controls the led of diagnostic light 3, using my multimeter switch to OHM resistance, the ground on the transistor and the positive on the cap, I tested each cap on the board and replaced whatever one diminished the green light. Now the machine doesn't chime but does start up only showing only diagnostic light 1! The PSU is tested and working great with other machines so that is not the problem. Any help would be great!
  • Toasty
    • Jul 2007
    • 4171
    Re: iMac G5 diagnostic lights?
    #2 light never came on?
    https://www.badcaps.net/forum/showthread.php?t=7124
    Post #10
    veritas odium parit
    • ub6ib969
      • Jul 2010
      • 200
      UPDATE:
      Light #2 never came on however The computer now works fine. I replaced 2 1800uf 6.3v caps on the left side were the (5) 1000uf 16v are grouped and now it shows me a screen. I installed Leopard and everything is working great, but light 2 is still not on!?
      -Thanks again Toasty.
      • gabrielA7
        IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
        by gabrielA7
        Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
        I saw that the room LED lights up only when the screen is connected, so quiet.
        We have all the power supplies, even processor, 1.8V
        One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
        I suspect that there may be some leak in the processor.
        Anyway, when I press the power, it...
        10-29-2024, 06:48 AM
      • SluggerB
        Garage light only lights up when you hit it. Make your guess as to the cause!
        by SluggerB
        The flood light over my garage was hanging out of the house due to the previous moron not knowing how to anchor it correctly. So I fixed that today
        I then go to turn the light on tonight, and it doesn't stay on. If I tap it with a piece of wood, the lights come on for a sec them dim. Repeated tapping will cause it to eventually start working, until the switch is flipped, then it's a 50/50 shot it will work again or need to be tapped to start
        So tomm begins the diagnosis. What do you think it is? Vote now!
        A: A loose connection in a wire nut. I tugged...
        10-15-2022, 10:53 PM
        Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
        Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
        various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
        Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
        trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
        what is wrong with your PC in just seconds. It saves you time and money.
        Our new and improved design...
        11-01-2024, 06:29 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-07-2024, 03:40 AM
