ACPI Controller
+ More Options
Posts
  • kiddznet
    • Jul 2010
    • 176
    ACPI Controller
    I have here an AOpen s661fxm 7s that will not boot past the device manager display and stops at ACPI Controller
    This is before Floppy and CDROM so i've no chance to reflash it as far as i can see
    I can get into the biospage but can see no way of disabling ACPI
    Any ideas?
    What next?
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • digge
    • Apr 2006
    • 296
    Re: ACPI Controller
    In some bioses there is something called "reset DMI data" or something similar, cant remember exactly from the top of my head, that have worked once for me.
    Other then that try pulling any extensioncard or similar hardware you can, have had strange lockups with usb devices during boot in the past, in that case it was my webcam. Works fine if you connect it after bootup.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Re: ACPI Controller
      memtest+ it, clear cmos
      • kiddznet
        • Jul 2010
        • 176
        Re: ACPI Controller
        Thank you,
        Board is bare sitting on a phone book
        How woud I run Memtest when I cant start the board?
        Boot doesnt go past second screen device managers
        Cannot load floppy
        • Wizard
          • Mar 2008
          • 2296
          Re: ACPI Controller
          Like others says, go into set up bios settings and reset as instructed.
          cheers, wizard
          • kiddznet
            • Jul 2010
            • 176
            Re: ACPI Controller
            Thank you
            Nothing works
            Replace bios chp?
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              Re: ACPI Controller
              yeah good point
              take all pci cards out, put a single good known stick in, maybe switch out video card?
              • kiddznet
                • Jul 2010
                • 176
                Re: ACPI Controller
                Thank you
                I got 1 stick of ram in it keyboard and thats it
                PSU known to be good
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Re: ACPI Controller
                  I used to love getting a board like that for free or cheap (back when they were worth something)
                  Provided BIOS chip is socketed, removing it and reloading its firmware contents with an EPROM programmer should fix it
                  Replacing the BIOS chip will probably achieve the same result
                  better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                  • kiddznet
                    • Jul 2010
                    • 176
                    Re: ACPI Controller
                    Thank you
                    PLCC 32 soldered in tricky but do-able
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Re: ACPI Controller
                      Downloaded manual IS pretty light on detail
                      I posted previously because fault reminded me of a problem that Award BIOSes had in Socket7 days, where they'd stall after the Verifying DMI message
                      I tried various snake-oil suggestions from the Net to fix those, but the only thing that worked for me was external reprogramming of the chip
                      However, before you attack with the soldering iron ...
                      Probably can disable ACPI by going into Power Management Setup, and setting Power Management (or similar) to Disable
                      Another snake-oil suggestion I recall was Disable everything related to processor Cache (Load Setup Defaults first)
                      If all else fails, disabling everything default Enabled may be worth a go
                      How do you remove a soldered PLCC chip without damaging the board ? - I've salvaged a few chips from dead boards, using a paint stripper type hot air gun, but the board isn't a pretty sight afterwards
                      • kiddznet
                        • Jul 2010
                        • 176
                        Re: ACPI Controller
                        This has worked for me
                        A scalpel can be used to cut the legs of the EEPROM, I use an oil stone to flatten the cutting edge of the blade at the tip . Its possible to angle the blade so that the cutting edge falls directly on to the top of the next pin as it cuts the preceding pin.
                        Care must be taken to ensure that you are not hitting the board surface during the process. The flattened tip helps avoid track damage in the event of a mishap, but direct contact between blade and board surface should be avoided.
                        The reason for cutting away the old PLCC chip is that the remnants of the pins can easily be removed from the board one by one, without overheating the tracks using a small 15 or 20 watt soldering iron. If you don't have the right tools and you try to de solder the chip without cutting the legs then track damage is very likely to occur.
                        The remnants of the pins will stick to the iron as you move across them. Do not try to pull them off with tweezers or pliers as you will lift the footprint pads from the board.
                        http://bios-repair.co.uk/bios/diysb.htm
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          Re: ACPI Controller
                          Another thought
                          Sounds like a corruption of CMOS
                          If it was mine, I'd remove the CMOS battery and leave it out overnight to be absolutely sure CMOS was cleared
                          (Wait for someone to chime in saying overnight not necessary, but same reason why Irish wear two condoms)
                          However someone's already suggested clear CMOS, and you've said Done
                          Also, it's not necessarily ACPI that's the problem
                          The firmware programmer could either issue the message when ACPI initialisation is starting, or when it's complete
                          If the former, then ACPI is the problem - but if the latter, it could be the next item to be initialised
                          • kiddznet
                            • Jul 2010
                            • 176
                            Re: ACPI Controller
                            Thank you
                            tried overnight batteries removal and cmos dump
                            Same problem
                            I cant believe there is no solution on Google!
                            • Chriso
                              • Jul 2010
                              • 30
                              Re: ACPI Controller
                              I think you want to get into the Bios and set the hard drive mode to native IDE or not use AHCI.
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                Re: ACPI Controller
                                Its not AHCI, its ACPI. But on the subject. Does this board have a seperate ATA controller chip? sometimes the bios's in those can corrupt and prevent booting
                                • pfrcom
                                  Oldbie
                                  • Jun 2006
                                  • 1230
                                  Re: ACPI Controller
                                  I found a factor in retaining my sanity while playing with questionable computer bits, was to know when to scrap it and walk away
                                  In the past, I acquired a Gigabyte nForce2 board with a soldered BIOS chip, assured not working because of a bad BIOS flash, and cut the PLCC chip out with a hobby knife
                                  Took me ages - not as simple as those instructions make it sound, when you've got to be uber careful not to slip and cut the board
                                  Then cleaned up the PLCC solder pads, finally programmed a replacement chip and held it in place for a test
                                  You've guessed it - not a peep
                                  Nowadays I wouldn't touch a board with a soldered chip, especially one based on a SiS chipset, unless I knew it would boot
                                  Seeing yours does that, it's a value judgement whether you potentially throw good money after bad, assuming you have to buy the replacement chip
                                  • Chriso
                                    • Jul 2010
                                    • 30
                                    Re: ACPI Controller
                                    Google tells me it is AHCI that is causing the problem and setting native IDE is a cure.
                                    • kiddznet
                                      • Jul 2010
                                      • 176
                                      Re: ACPI Controller
                                      pfrcom I hear ya. This is a hobby for me wastes plenty of time for small outay!
                                      here i have ground off a PLCC32 chip with a Dremel.About five minutes careful but no sweat work
                                      Next flick off stubs with a small iron and clean up
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Re: ACPI Controller
                                        if you wish to avoid killing chips, you should look into a product called chipquik.
                                        see this video:
                                        http://www.youtube.com/watch?v=FTQqjggeklo
                                        sigpic
                                        (Insert witty quote here)
                                        • piernov
                                          Compaq SR1000 MSI MS-6577 ACPI fix
                                          by piernov
                                          Compaq Presario SR1000 / SR1116FR, MSI MS-6577 (Xenon) Gamila/Giovani/Neon series
                                          ACPI fix!
                                          Yes, you read that right, the bug that HP/Compaq never fixed is finally no more, 16 years later. You probably don't care but here it is anyway.
                                          Bug
                                          Basically the bug is as follow: you want to use Linux on this machine, but it doesn't power off when you shut it down, you cannot put it to sleep, nouveau driver for NVidia GPUs doesn't load, etc…
                                          At boot, you may be greeted by the following message:
                                          Code:
                                            [ 0.000000] ACPI Error: A valid RSDP was
                                          11-30-2021, 02:34 PM
                                        • master3112
                                          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                          by master3112
                                          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                          10-29-2024, 09:32 PM
                                        • ronnygracias
                                          Help with freemotion incline trainer with controller comm error
                                          by ronnygracias
                                          The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                                          11-04-2024, 01:32 PM
                                          Tankless hot water heater controller board not powering up when power is applied
                                          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                                          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                                          However I would like to know if I could figure what happened to this controller board if possible
                                          Tomorrow I will take some better pictures of both side of both boards
                                          The...
                                          12-09-2022, 09:14 PM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
