Tweaking WINXP 32
  • kiddznet
    • Jul 2010
    • 176
    Tweaking WINXP 32
    Whats your favourite software/reference web site for ironing out kinks and tweaks in WINXP?
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • digge
    • Apr 2006
    • 296
    Re: Tweaking WINXP 32
    There are so many tweaks you can do, and many of them is a matter of preference. If you have something special that you want to achieve just ask.
    On my part i use a Microsoft tool called TweakUI, that is to tweak some animation settings and delays on the menus and stuff, thats about all the tweaking i do. I used to use the network hack also, the one that changes so windows doesnt have to send packages in lots of two. There is a script for that called leatrix latency fix (only makes latency better on some games, not all)
    • orbiter
      • Mar 2011
      • 37
      I use Black Vipers tweaks for all windows configs.. Here's a link to XP with SP3
      http://www.blackviper.com/2008/05/19...onfigurations/
      Don't Bin It - Repair It.
        master hoarder
        • May 2008
        • 12170
        I do most tweaks myself without software. First thing that I always do is turn off most Visual Effects. Then I turn off Indexing Service and Desktop Cleanup Wizard, followed by setting the pagefile to a more reasonable amount (i.e. not 1.5 times the amount of RAM). That's about it really, aside from a few other small things.
        If the computer I'm tweaking is for myself, I also turn off Windows Update (also disable it in Services in Computer Management) along with System Restore (once the computer is all set-up, of course). Then I change the UI to classic theme (already have a .theme file to that), and further cut down/disable other services through Computer Management and with CCleaner.
        The results: I end up with a computer that boots much faster and uses much less RAM. Most of my computers that don't have an antivirus run on 100 MB of RAM or less.
        • Pyr0Beast
          • Feb 2009
          • 406
          nLite works as well. Prebuild an install yourself. I used to have a fresh system set up in under 30 minutes that way.
          • severach
            • Aug 2007
            • 1055
            The best single app for tweaking XP is XP Antispy. It turns a lot of crap off that shouldn't be there.
            Over the years I've worked up a set of BAT files that launch and fix everything I want including a REG file for XP Antispy so I don't need to select items individually. On a mid range computer the entire setup takes about 20 minutes after the install and drivers are complete.
            sig files are for morons
            • retiredcaps
              • Apr 2010
              • 9271
              I pretty much have the same tweaks as momaka, but I do use Immunet Cloud AV. It only takes up about 30MB so when my system boots, it uses about 126MB. I have also tried Panda Cloud AV and Panda uses about 90MB. I also run malwarebytes manually twice a week as an added measure.
              I will also run msconfig after some updates to make sure programs don't reinsert all the startup crap like java check, google chrome updater check, etc.
              This is key as I buy some used P4 systems ($20 or less) and they only come with 256MB or 512MB for everyday basic surfing.
              --- begin sig file ---
              --- end sig file ---
              • kiddznet
                • Jul 2010
                • 176
                Thanks all. Good stuff there. am now using antispy very user friendly. Have been using an nlite file for a while now.
                  master hoarder
                  • May 2008
                  • 12170
                  Same here, except I use CCleaner since it's faster.
                  From what I remember, though, Java uses two processes - javaw.exe and jqs.exe (Java Quick Starter). Javaw.exe can be removed from CCleaner (and from msconfig, I presume), but for jqs.exe, it is best to Stop and Disable this service from Computer Management>Services and Apps.>Services.
                  Google Update is even more complicated. It is automatically enabled when Google software is installed or updated. To kill Google Update, you need to do the following:
                  1) Disable GoogleUpdateService.exe and/or GoogleUpdate.exe from Services in Computer Management.
                  2) Go in Control Panel>Scheduled Tasks and double click on each Google task, then make sure the checkbox "Allow this service to run at scheduled time" (or something like that) is unchecked.
                  Additionally, if you have Google Toolbar (like I do), you need to disable GoogleToolbarNotifier.exe. I forgot exactly how to do that, but if you need to know I can check.
                  That aside, I also use CCleaner daily before I shut down to clean up temp internet files and other crap.
                  256MB? Ouch. I would recommend at least 384 MB. 512 MB if there's anti-virus.
                  • ChaosLegionnaire
                    I finally got one too! a new monitor! and my first ips panel to boot!
                    by ChaosLegionnaire
                    after bigtroll managing to score a new video card in this thread, i thought i'd get a new monitor too, since my current one has a bubbly and blurry screen that i posted in this thread.
                    i tried numerous local websites to get one but many required a mobile number to sign up which i dont own. i also had issues finding the right monitor that met my requirements. it was a nightmare finding one, spending weeks looking through g00gle.
                    finally, i decided to try lazada, the singapore version of jack's aliexpress. it only required an email address for signup, but whenever i...
                    10-12-2021, 02:07 AM
                  • harp
                    simple win network with optimization issue
                    by harp
                    simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                    06-23-2025, 11:01 AM
                  • Cory Meyers
                    🤯 Acer Predator Helios 300 pH315-54
                    by Cory Meyers
                    Hi there all, 1st post here. I wasn't aware there were guys out there doing this for people! (how, well I haven't a clue lol but 😎👍 badass!), So when I found y'all, I was happy, but not too happy quite yet - although my issue seems to be less severe than many I've seen here who have been happily helped, so there's that.
                    I'm a software dev of over 20 years and just recently have gotten into the hardware side of things plus other electronics like Rpi and Arduino. Started off a vid game hacker yada yada, same story. Lol.
                    Now, the BIG OL' issue ruining me little life:...
                    10-28-2024, 05:11 PM
                  • harp
                    command to run Fn + [left arrow]
                    by harp
                    I look to find some simple solution to execute Fn+left arrow once at winxp startup... It might be some simple specific command aplication, or batch script, or some C code (I have C compiler, but thats it)... can anyone help with idea or solution? On internet can find some sofisticated programs that can do such things and much more, but I not interested to load it to system for that.... ... ... If you interested in what is purpose... I have some bug or so on my laptop, and on every shutdown reset backlight to maximum, just flash one moment before go off... on next boot backlights is stuck to...
                    07-13-2025, 03:39 PM
                  • harp
                    help with graphics driver for eMachine G725
                    by harp
                    I am trying to find graphics driver for old laptop eMachine G725, for winxp 32bit... from data on internet, https://gadgetaz.com/Laptop/eMachines_G725--1942 it will have Intel GMA 4500MHD graphics, so I downloaded a few of them but nothing work, error say: this computer does not meet the minimum requirements for installing the software. So, please somebody help me to find bare minimum graphics driver to see non deformed screen anymore...
                    07-02-2025, 01:26 AM
