New dead rig
  • stevo1210
    • Oct 2006
    • 4156
    New dead rig
    I just bought an Acer Aspire M1800 desktop computer for dirt cheap today in order to upgrade my main PC in my sig. I haven't done any computer work for ages now, so I'm pretty rusty...
    It's got a Core 2 Duo T7400 CPU, 4GB RAM, nvidia G210 graphics and a 640GB hard drive.
    Anyway, it turns on, but I get no display at all. I haven't tinkered much with it yet because I'm off to work soon... basically I removed all the RAM and I get a long beep... so I guess that means the board still works?
    I tried using on board graphics to no help at all... should I get a different external nvidia card?
    The power supply is a good unit made by Delta electronics. When I got the system, I could tell it had never been opened up or tampered with because the security/warranty seals were still intact!
    Even the protector clear plastics are still on the case!
    What should I do guys...?
  • brethin
    • Dec 2008
    • 1907
    Re: New dead rig
    Core 2 Duo T7400 is a laptop CPU, and will not work in a desktop. Maybe thats a typo and you ment E7400. Take out the G210 video card and try the onboard video.
    • stevo1210
      • Oct 2006
      • 4156
      Re: New dead rig
      don't worry guys, got it started again by just removing and re-inserting the CMOS battery.
      • stevo1210
        • Oct 2006
        • 4156
        Re: New dead rig
        Oops, i meant the E7400.
        • stevo1210
          • Oct 2006
          • 4156
          Re: New dead rig
          Since it's all up and running now, I'm wondering about the graphics card... the one in there now is an nvidia G210 512MB... the one in my sig below is also an nvidia, but a 512MB 8400GS... which one is better?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Re: New dead rig
            They are the same. nV decided to do this big confusing naming change after the 9 series. It is equivalent to a 9400... which is the same as a 8400 but more power efficient.
            A working TV? How boring!
            • Scenic
              o.O
              • Sep 2007
              • 2642
              Re: New dead rig
              ^BS
              the 8800 series were relabelled as 9800's. the 9400 is a new chip. plus it has nothing to do with the G210.
              the GeForce G210 is an low-end OEM-only card based on the 40nm GT218 core.
              the 8400GS is either based on the old and faulty 80nm G84/G86 core (old cards) or the newer 65nm G98GS core (newer cards). the last production run actually used the 40nm GT218 core just like the Geforce G210.
              the geforce (G)210 is a bit faster and a bit cooler running, but nothing that would cause any "wow-effect"..
              check your 8400GS with GPU-Z as for what core it's using. if it's the old G84/G86 core, i'd use the G210 before the 8400 craps out (which it will do... it's a matter of when, not if..)
              if i were you, i'd rip that Core 2 Duo E7400 and the G210 out and put it in your main box.
              the CPU has a shitload more oomph & runs cooler, and the GPU will probably last longer than the 8400 (if it's based on the G84/G86)
              the 640GB HDD is probably also much newer (read: faster) than your current ancient Seagate 7200.7
              i've got 2 Barracuda 7200.7 120GB SATA HDDs here.. they're pretty hot-running (35°C w. 120mm fan @ 5V) and slow (average 65MB/s) compared to the newer 500GB WD Caviar Blue's i've got (which run below 30°C in the same computer and get 87MB/s average)
              Use HDTune (i'll send you a link via PM, as this thread is not in the VIP lounge *ahem*) to check the HDDs (how fast they are in comparison)
              edit: you might also wanna rip the 4GB RAM out (if it isn't DDR3)
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Re: New dead rig
                And what was i saying?
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  Re: New dead rig
                  8400 and 9400 have nothing to do with each other (apart from being low-end cards obviously)
                  your post implied that 8400 = 9400 .. just relabelled. which is BS..
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Re: New dead rig
                    Um. just wondering, but why do you suggest I put all this stuff into my "main box"? I think the Acer should be okay right? Though I will agree there are some design flaws with the case... so much so it didn't even come with an exhaust fan so I had to buy one for it today. O.o
                    ... and the RAM is DDR2.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      Re: New dead rig
                      well in theory you could just do it the other way around and make the acer your main PC..
                      but most of the Acer PCs i've seen so far had crappy OEM only boards with crippled BIOSes and low-end chipsets, relatively weak PSUs and junk (soda-can-like) cases..
                      don't know about this one.. and i'm too lazy to look up detailed specs and pics right now
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        Re: New dead rig
                        I said that G210 = 9400. And the 9400 is equivalent to the 8400. So G210 = 8400 for all intents and purposes.
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          Re: New dead rig
                          Drop that E7400 in your main rig. I have an E7500 in mine and I am very satisfied with it. I see no need to upgrade mine any time soon. It may be a last-gen processor but it still feels lightning fast to me.
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: New dead rig
                            The board is an MSI I think? (Had an MS-xxxx model number on it), and the chipset is an nvidia something, the BIOS is simple though and the PSU is a Delta. I would change the CPU and stuff into the Asus rig, but clearly I can't be bothered LOL.
                            I'll use it in the Acer for now and see how it goes.
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              Re: New dead rig
                              meh... even though i kinda hate Asus, the P5K-E/WiFi-AP is without doubt the better board (P35 Chipset with ICH9R Southbridge)..
                              nvidia chipset and MSI OEM motherboard (which most likely isn't listed on the MSI page for support, much like the Medion-MSI boards) make me shiver.. *brr*
                              • stevo1210
                                • Oct 2006
                                • 4156
                                Re: New dead rig
                                Scenic, I fucking hate it to be honest. I used it today and I wasn't happy at all!
                                Sure the case is nice and beautiful, but it's design is so shit that I want to vomit on it! It bloody cut me and I couldn't even get the other side open without smashing the damn thing against the floor!
                                Seriously guys, I need some advice on getting a new case, and a better motherboard! I'd prefer full size ATX though.
                                • stevo1210
                                  • Oct 2006
                                  • 4156
                                  Re: New dead rig
                                  anyway, i decided to keep the acer as is and just chuck it into the bedroom to watch tv and access the net. i do have an issue though... how come it's picky with graphics cards? i put an x600pro in there and it worked fine, but when i put an x600xt (identical card as well), it would be quirky and restart give me artifacts?
                                  it even hates the G210 that it comes with... sometimes it would bsod etc. but after i reseated that and ran burn in tests it's fine again?
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2642
                                    Re: New dead rig
                                    take a brush and clean the PCIe slot
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Re: New dead rig
                                      I suspect PSU. Especially if it acts up when you put a card that uses more power.
                                      And graphic card issues, when it's an outright bad card, usually don't cause a BSOD, you usually instead get a POST failure or a corrupted desktop screen. Also, usually a corrupted BIOS screen!
                                      But, with the RAM being loose or a bad RAM slot, a BSOD complaining about some type of corruption is a typical sign.
                                      ASRock B550 PG Velocita
                                      Ryzen 9 "Vermeer" 5900X
                                      Arc A770 16 GB
                                      eVGA Supernova G3 750W
                                      Alienware AW3423DWF OLED
                                      • stevo1210
                                        • Oct 2006
                                        • 4156
                                        Re: New dead rig
                                        Ever since I cleaned out the graphics card port with a rocket blower for my dSLR, it's been fine... but then again I did reseat the RAM as well.
                                          BLUECHIP BUSINESSline T7400 3700X Specification for Upgrade or Repair
                                          This specification for the BLUECHIP BUSINESSline T7400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the BUSINESSline T7400 boardview and BUSINESSline T7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 02:20 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
