GX280 bios custom text
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    so, I got this 280 desktop from goodwill, no os or hard drive. works great, but when it comes up above the dell logo it says "Property of Northrop Grunmann". I reflashed the bios and it still says it. anyone know if there is an advanced hidden menu to change this text? I want to resell it. more of an inconvenience really.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: GX280 bios custom text
    you need the software to reset the asset tag iirc.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      ook thats what its called, found an updated one that was released in 2006 from research, haven't tried it yet though but thaaank you!
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        ahhhh damnit. this thing requires a floppy to boot and run the program
        only floppies I can find I got for free by a local business I did work for. I just looked them, they're 720k
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i bet that if you added it to a .iso for win 98, boot with cdrom support, and in the resulting command line have it run D:\xxx.exe (or whatever .exe it is), you could run it. or does the program you downloaded ask for a floppy disk?
          since isomaster is freeware for linux (and I use linux), I often use that trick to make bios update CD's.
          sigpic
          (Insert witty quote here)
          • Scenic
            o.O
            • Sep 2007
            • 2642
            make a bootable USB stick with that tool on it.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4978
              • New Zealand
              You can try doubling the capacity by drilling the correct hole on the right hand side. 1.44MB floppies have this hole while 720K floppies don't. If they are newer ones they should work, they were actually 1.4MB ones with half capacity disabled.
              Even if not, If you change the BIOS floppy drive option to 720K you should be able to use them. As long as they can hold enough data, of course!
              -David VanHorn
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                the program itself needs a 1.44, windows sees it fine like 720
                heh, looking at the box, they're from 1998
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  You can punch a hole in the side of the floppy so it is recognized as a 1440KB floppy...
                  Google for it, but to do this when working with critical data is just silly (BIOS tools)
                  Get a USB flash drive, format it using the "HP USB Disk Storage Format Tool"
                  Here is an excellent guide with both the program and required Win98 Boot files...
                  http://forum.corsair.com/v3/showthread.php?p=432257
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    Old 720K floppies have a different magnetic coating on them that's opaque if you open the shutter and shine a fairly strong light through it, but 1.44M disks have a coating half as thick that's transparent brown-red.
                    • NxB
                      • Feb 2009
                      • 1595
                      throw the files on a hiren's cd and boot to dos. or throw on a usb stick and boot off the cd. works on 90% of stuff.
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
