Vista or Vistrash?
  • cookieCAM
    ICDEZ_CAM
    • Feb 2011
    • 26
    #61
    Re: Vista or Vistrash?
    I Use:
    Hp Mini: Xp Home
    Compaq Prolaint ML(?515-310?): Xp Pro
    (1)Dell Inspron 8200: Win 7 Ult.
    (2)Dell Inspron 8200: Xp Pro
    Alienwear Desktop: Vista Ult.
    Dell Mini 10: 7 Starter
    Dell Mame: Xp Pro.
    + More!!!!
    Thanks, cookieCAM (Cam)--Updated:March 2011
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Originally posted by Uranium-235
      haha senic, I love your avatar, though I don't know why you have it though, abit is pretty much dead, as is epox
      unfortunately... for both
      reason why i've got that avatar is the board i used for my Core 2 Quad a while back. Abit IP35P.
      pretty much perfect layout (except the floppy connector location), no BS functions and it OCed very well..
      i just can't part with it.. allthough i have no use for it at the moment..
      http://www.abit.com.tw/page/en/mothe...ARCHTEXT=IP35P
      caps on mine are all Nichicon, Sanyo and Nippon Chemicon.. (they learned their lesson after the crapcap disaster..)
      Other boards i've got are the good ol' Abit BX6 and the IC7 (Socket 478, i875 Chipset). i also have some random EPoX boards, most notably the EPoX 4PCA3i R2 (Socket 478 ; i875) .. came with crapcaps (GSC & Teapo) and was dead as a rock. recapped it and it still works fine to this day..
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Originally posted by NxB
        Wait 10 minutes to delete 50MB of files.
        Watch it error at the end on 1 file and undo the whole operation.
        That sounds like the Microsoft installer for Windows Live, IIRC, it would wait until almost the end then error out and roll back the changes.
        The cause was a registry entry that somehow had a messed up ACL.
        And I would get an access denied error when trying to access the registry entry.
        It mysteriously had the ACL set to deny write access and read access to the registry entry.
        And it was an important registry entry.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • RJARRRPCGP
          • Jul 2004
          • 6304
          micro$oft actually now had unlimited activations for any OEM key if you're using an OEM disk.
          Sorry, that's not correct. Microsoft's activation server punished me for reformatting, reinstalling and requesting an activation one day. It told me that I exceeded the max activations for the product key!
          (Back in 2007)
          Arc A770 16 GB
          • c_hegge
            • Sep 2009
            • 5219
            If that happens, you can ring them up and they will activate it for you.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              (Back in 2007)
              They reset that every so often. It did that to me with a copy of X64 a couple years ago (had it on 4 systems at the same time). Soon after i tried it again, it activated no problem. C_hagge is correct though, if it does that to you, just call them....they'll light up your install.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • c_hegge
                • Sep 2009
                • 5219
                Originally posted by Topcat
                C_hagge is correct though...
                Hmmm. I've never heard of him before
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  #68
                  what i'm taking about is OEM (HP, Dell, Toshoba) keys I have activated 10 times so far with no problems. Mind you incase micro$oft decided to start adding key limitations I keep track of the number of activations so far. But I have a dell Pro key from the gx280 I have activated at least 8 times this year
                  I know its legally gray, but no one cares
                  • TheLaw
                    • Jan 2011
                    • 477
                    #69
                    vista sucked, I don't like 7 any better. Still using XP and have no plans to change.
                    Nahh...I was in your boat, but once I got W7, I realized how old XP was. You shouldn't try running 7 on an ancient machine, but for new computers, don't even think about XP.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      #70
                      Winblows7 vistrash it's all microshit!
                      Follow the white rabbit.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Holy thread revival Batman!
                        sigpic
                        (Insert witty quote here)
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          W7 is just fine.
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • dumpystig
                            • Jul 2011
                            • 485
                            I run Win 7 Ultimate 64bit on a desktop and a Workstation, and 32bit on 2 laptops - overall I think it is a great OS, I have very few complaints/niggles. I found Vista to be a pain in the arse. Much like IE9 64bit.
                            System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                            • Ami Sapphire
                              Extreme Lurker
                              • Sep 2010
                              • 180
                              lol my mom still runs vista on her laptop
                              But seriously, she adapted to Vista from XP pretty quickly when she had her first Vista-based laptop. On another note, I never had problems running Vista on any PC I had installed, even on my old Dell Dimension 8200. It was surprisingly fast. (It was a test install at the time.)
                              I moved on from Vista, however, I still use it in some test installs.
                              Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
                              I have two v2s and one v1.
                              I am still looking at these boards nearly every day.
                              What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5037
                                • New Zealand
                                #75
                                ^This
                                -David VanHorn
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  I'll take Windows 7 (or even Vista) over XP any day, even if it's a tad bit slower...
                                  • dumpystig
                                    • Jul 2011
                                    • 485
                                    I preferred XP to Vista, still do. In fact I've recently been contemplating a Win7/XP dual boot on either my workstation or desktop.
                                    • Shocker
                                      Banned
                                      • Dec 2011
                                      • 635
                                      #78
                                      Originally posted by shovenose
                                      there is nothing wrong with vista. it was a decent operating system!
                                      On top of the excessive resource consumption and the annoying UAC:
                                      • The "ask me what to do" action for the power button was removed.
                                      • WinHelp was removed (be it for better or worse; better for MS, worse for us).
                                      • Multiple problems mentioned here. (You can use compatibility mode to install older software that won't recognise Vista.)
                                      • Plus many others.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        • Plus many others.
                                        way to revive a 2 month thread.
                                        (posted from a vista pc)
                                        sigpic
                                        • Newbie2
                                          • Sep 2005
                                          • 885
                                          Windows Vista? I almost forgot that it even existed after Windows 7 came out.
                                          Back when Vista was the latest thing I jumped right on the bandwagon from XP, because I'm the person who wants the latest thing. Before 7 came out I actually liked Vista and how it looked compared to XP, but after getting 7 I'm not looking back.
                                          I put Windows 7 on newer computers, and XP on older computers. Windows 7 doesn't need better hardware than Vista, plus it's newer and much improved. That said, there's no point for Vista anymore, IMO.
                                          My gaming PC:
                                          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                                          ASUS M4A77TD AMD 770 AM3 Motherboard
                                          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                                          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                                          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                                          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                                          ASUS Xonar DG 5.1 Channel PCI sound card
                                          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                                          Antec Three Hundred Mid-Tower Case
                                          Microsoft Windows 10 Pro 64-bit
                                          Microsoft Windows 7 Ultimate SP1 64-bit
                                          • double_DD
                                            Why does my ISP router hate my "homemade" power supply??
                                            by double_DD
                                            It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                            So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                            For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                            07-12-2025, 03:09 AM
                                            LENOVO ThinkStation ThinkStation D20 (415521G), DE ThinkStation D E5506 Specification for Upgrade or Repair
                                            This specification for the LENOVO ThinkStation ThinkStation D20 (415521G), DE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415521G), DE boardview and ThinkStation ThinkStation D20 (415521G), DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 03:36 PM
                                            LENOVO ThinkStation ThinkStation D20 (415518G), UK ThinkStation D E5520 Specification for Upgrade or Repair
                                            This specification for the LENOVO ThinkStation ThinkStation D20 (415518G), UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415518G), UK boardview and ThinkStation ThinkStation D20 (415518G), UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          • ciferluis
                                            old HP PRESARIO CQ60-202EL with Vista O.S.
                                            by ciferluis
                                            HI guis ! I've and old HP PRESARIO CQ60-202EL with Vista O.S. I tried to update it to WIN 7 ultimate but when i try to install, it show to me this message: "Windows cannot be installed on a battery-powered computer. If battery power runs out during installation, some data may be lost. To continue the installation, connect the power supply." Infact, battery level 67% signs that is running without beeing charging. But the power supply led is white and cable gives 17,34 ouput DC Voltage. When i try to enter BIOS with F10 key, F10 key not works ! Only F9 key works (change hdd, dvd or usb...
                                            04-12-2021, 03:37 AM
                                            HP Compaq dc7800p Intel Core2 Duo Processor E6750 1G/160G DVD+/-RW WVST Bus Small Form Factor PC E6750 Specification for Upgrade or Repair
                                            This specification for the HP Compaq dc7800p Intel Core2 Duo Processor E6750 1G/160G DVD+/-RW WVST Bus Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7800p Intel Core2 Duo Processor E6750 1G/160G DVD+/-RW WVST Bus Small Form Factor PC boardview and Compaq dc7800p Intel Core2 Duo Processor E6750 1G/160G DVD+/-RW WVST Bus Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be...
                                            09-12-2024, 03:30 PM
