Geforce GTX 460 vs AMD 790x issue
  • Maxxarcade
    • Jul 2006
    • 973
    I read somewhere that there are compatibility issues between modern nVidia GPUs and certain chipsets. I think the 790x is one of them, because I'm having constant crashes since installing this card. It's a nice Gigabyte Ultra Durable series card too.
    I'm pretty bummed that I had to go back to the GT240. Waiting to hear back from Gigabyte on the issue. Anyone else have this problem?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Geforce GTX 460 vs AMD 790x issue
    Did you try updating the 790x drivers?
    • Maxxarcade
      • Jul 2006
      • 973
      There hasn't been new drivers in a long time for this chipset.
      I'm probably going to RMA the card, but I don't know what to get as a replacement. I remember why I quit playing PC games years ago now. Video card hell!
      • mockingbird
        • Dec 2008
        • 5484
        That's not true. Chipset drivers are updated all the time. Here you go:
        Northbridge/Southbridge for Windows XP (Released yesterday)
        If you use Vista or 7, go here. Make sure to click on the optional download tab and then download the "Southbridge Driver" (Which also includes Northbridge drivers).
        If you're using XP, make sure to also get the AMD Processor Driver. For Vista or 7 you do not need this.
        Stay away from ATI videocards though. If you're having problems with this nVidia card, you'd be in for a real treat with ATI's videocard drivers. They are absolutely horrid.
        • Maxxarcade
          • Jul 2006
          • 973
          The 790x is not listed in the supported devices for that driver. Only Radeon devices. In fact, I can't find any drivers for the 790x on AMD's sites. Maybe they just don't list it? Maybe it will still work.
          The current driver on Gigabyte's page for my board is from 2009. Version 8.6.4.1. Pretty darn old.
          Reading through the reviews for various GTX 460 cards has not been encouraging. Lots of people having the same issue. And it looks like I'll lose $80 if I want a refund on the card, due to the game coupon and the restocking fee. I already got an RMA, but I might play with it over the weekend to see if I can get it working.
          Edit: Using Win7 64bit.
          • mockingbird
            • Dec 2008
            • 5484
            You are gravely mistaken!
            790X is most definitely supported with the southbridge driver. You're reading the release notes for the Radeon driver, not the chipset.
            • Maxxarcade
              • Jul 2006
              • 973
              I'll give it a try tonight and see what happens. I'm not keeping my hopes up that it will fix the problem though. But if it does, you'll be able to see my grin for miles
              • mockingbird
                • Dec 2008
                • 5484
                I'm 99% sure it is a driver issue. Don't waste your resources RMAing the card.
                • Maxxarcade
                  • Jul 2006
                  • 973
                  I'll post my results tonight.
                  I called AMD, and they said those drivers aren't for the 790x, and that they don't provide them... WTF. I'm still going to try it.
                  Another option I have, is to get the drivers for a Gigabyte AMD 8xx board, that are a bit newer. Might be better than nothing.
                  I did install the card into my OC'd Pentium E5500 system for further testing, but haven't had time to try it out yet. It doesn't push the card much anyhow compared to the Phenom II. In fact, I only got an additional 8FPS in GTA4 vs. the 9600 GSO that was in there. Need more CPU I guess.
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    Well, no luck getting it to work on the 790x. It will run for a bit, then the monitor loses signal for a minute. If it comes back to the desktop, it says the driver has stopped working and recovered. Sometimes it doesn't come back, and I have to reset the PC.
                    I tried 3 different chipset drivers, and 3 different graphics drivers.
                    So far it seems to be running fine in the E5500 system. Not very encouraging, because I can't afford to replace my motherboard and RAM. Though The money I would lose trying to get a refund on the card would be half the cost of a new motherboard anyhow.
                    If I decide to switch to an Intel board, I'd also need a new CPU comparable to the Phenom II X4 955, which wouldn't be cheap.
                    Not sure what to do at this point :-(
                    • Maxxarcade
                      • Jul 2006
                      • 973
                      The card has been working fine for a couple hours now on the E5500 system. I installed my old Radeon HD 3850 back into my main PC, and everything is working again. Even my Powerdirector 8 stopped crashing on startup.
                      I think I'll just RMA the 460 and get a high-end ATI for my main PC. Newer Geforce cards apparently just do not agree with the 700 series AMD boards! I came across lots of threads in forums with people having similar issues.
                      • hardwareguy
                        • Jun 2006
                        • 405
                        That's odd!
                        The Radeon 6950 is the rough equivalent to the GTX 460. AMD has been doing great things with drivers in the last year or so....for once they actually work! Be sure to download the latest Catalyst driver as the one on the CD is likely quite old.
                        • toastygoodness
                          • Jul 2005
                          • 813
                          Originally posted by hardwareguy
                          That's odd!
                          i don't think so... the 6950 is actually weaker than the 5950 in terms of strength... but it uses a LOT less power. i think that was what AMD was goin for this time, energy-efficiency
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Good luck with the new ATI card. The ATI drivers are a nightmare right now. Go to the AMD forums and you'll see.
                            • Rulycat
                              • Apr 2010
                              • 724
                              • United Kingdom
                              I'm having no issues.
                                Thermal pad thickness for various laptop GPU / Graphics Cards
                                ASUS Dual RTX 2070 OC 8GB
                                ASUS ROG STRIX RTX 3080 OC
                                ASUS ROG STRIX RTX 3090
                                ASUS TUF Gaming RTX 3080 OC Edition
                                ASUS TUF GTX 1660 S-O6G GAMING
                                EVGA RTX 3060 Ti XC GAMING 8GB
                                EVGA RTX 3060 XC GAMING 12GB GDDR6
                                EVGA RTX 3080 FTW3 ULTRA GAMING
                                EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                Gainward RTX 2080 Phoenix GS Specs
                                Gainward RTX 3070 Phoenix 8GB
                                Gainward RTX 3080 Ti Phoenix
                                GIGABYTE AORUS RTX 3080 MASTER 10G
                                02-09-2024, 08:08 AM
                                NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                10-02-2024, 08:52 AM
                                NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                10-02-2024, 07:51 AM
                                NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                10-01-2024, 01:54 PM
                              • LealEletronic
                                Gigabyte GeForce RTX 2070 Gaming OC 8GB - Schematic
                                by LealEletronic
                                Hello guys.
                                I'm looking for the schematics for Gigabyte GeForce RTX 2070 Gaming OC 8GB. I already have the boardview, but I need the schematics. I found them on a Russian site but I'm from Brazil so I can't purchase from there.
                                If some one can help me, please.
                                This schematics is the same as the EVGA 2070, so a really need.
                                04-16-2025, 11:42 AM
