Memory
  • AK0R
    • Mar 2005
    • 204
    Memory
    I have a stick of 128MB (16x64) PC133 SDRAM that came with a motherboard I got off eBay. Before and after recapping the motherboard, it detects at 64MB by itself, or not at all if anything else is present. This behavior was also observed with the stick in another motherboard, so I'm pretty sure the memory is the problem. The stick has blue covers riveted over the chips front and back. I'm not sure who made it; the logo looks like a lower-case N with a third leg in the middle that's not attached to the N; I'm guessing it's supposed to be a lower-case M. I checked out Micron and Mushkin, but it doesn't really look like either of theirs. Has anyone else seen anything like this, or have any other guesses as to the manufacturer? The sticker on it says "Lifetime Warranty", so I'd like to pursue replacement.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Memory
    Post some pics of it, I'l sure its bad. For a stick that small, I don't know if I'd really go through all the aggrivation of shipping and research for the warranty.... Had it been a 1gb stick, thats a different story...... Do post some pics though, maybe we can identify it.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Memory
      micron looks like above.
      are you testing it in recent boards? old boards used to see 1/2 the ram unless it was double sided. i have not seen that mode of failure in my experience but i am not suprised by anything.
      actually i have only seen errors in an oem sdram stick with micron chips, a geil sdram stick with hyundai chips and an elixir ddr stick with elixir chips. i guess i have been lucky.
      perhaps it is an oem stick whereby you would have to identify the brand not the chip manufacturer for successful rma
      post pics anyway to see. chip number would be useful also.
      • AK0R
        • Mar 2005
        • 204
        Re: Memory
        Pictures of this memory stick:
        As you can see, the chips and all components are hidden under the heat shields or whatever they are. So, the only clue I have is that logo.
        The two boards I've tested it in were both BE6-II Version 1.0, one with the most recent BIOS (version 70) and the other with the next older revision (version XU). Both detect it at 64MB. I haven't tried it in anything else (yet).
        • Rainbow
          • Aug 2005
          • 1375
          Re: Memory
          Try something with e.g. i815 or some newer VIA chipset.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Memory
            BX chipset wants double sided rams but i think those are double sided?
            • Rainbow
              • Aug 2005
              • 1375
              Re: Memory
              It's limited by chip density. You can use 8-chip single sided 128MB module but 256MB modules must be double-sided. Some of the newer cheap 128MB modules have only 4 chips and that does not work properly with older chipsets like i440anything.
              • stretch0069
                Screwed Up Super Moderator
                • Oct 2003
                • 2658
                • oooo ess aaaaaaaaa
                Re: Memory
                Well....I tried everything I could. Looked up 420485871 and got nothing. Tried 128PRTWR4B and still nothing. I did get a bit on 128PRTWR4 though. Went to a dead end though. Needed to contact someone if I wanted to order.
                Even did an image search on PC133 to see if I could match a pic. (yes...I am bored) I did run across a nice site full of Penelope Cruz pics. (spent a bit of time there )
                My guess is you'd have to take off the covers to see who made the chips. Who knows. I'm getting into a place where someone else has more experience I'm sure.
                "Its all about the boom....."
                Guns kill people like spoons made Rosie O'Donnell fat.
                We now return you to your regularly scheduled drinking.
                "Fear accompanies the possibility of death.....calm shepherds its certainty"
                Originally posted by Topcat
                AWD is just training wheels for RWD.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  Re: Memory
                  i found zilch also
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    Re: Memory
                    nada here either. thats why I always tell people if they insist on having ram with heat spreaders, make sure they're removable. if they arent, you never really know what you're getting.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      Re: Memory
                      here's more sticks
                      http://cgi.ebay.com/SDRAM-256-PC-100...QQcmdZViewItem
                      http://cgi.ebay.com/NEW-PC133-SDRAM-...QQcmdZViewItem
                      • Newbie2
                        • Sep 2005
                        • 885
                        Re: Memory
                        If those heat spreaders aren't removable, that's not good. By the lack of name brand on the heat spreaders, I'm guessing it's a generic piece of RAM but removal of the heat spreader should bring up some facts.
                        Try using CPU-Z, it can idenitify the memory chips under the heat spreader.
                        My RAM was made my PQI. The 16 zeros mean PQI made the RAM.
                        Here is an example:
                        My gaming PC:
                        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                        ASUS M4A77TD AMD 770 AM3 Motherboard
                        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                        ASUS Xonar DG 5.1 Channel PCI sound card
                        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                        Antec Three Hundred Mid-Tower Case
                        Microsoft Windows 10 Pro 64-bit
                        Microsoft Windows 7 Ultimate SP1 64-bit
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          Re: Memory
                          more
                          http://cgi.ebay.com/512MB-PC133-SDRA...ayphotohosting
                          i wouldnt call it generic, it has a logo?
                          • AK0R
                            • Mar 2005
                            • 204
                            Re: Memory
                            Thanks to everyone for their help.
                            Newbie2: I've downloaded CPU-Z, and will try that tonight at home. Thanks for the information. How do you know what code indicates a particular manufacturer? I agree that it shows all zeros for your PQI memory, but does that mean that that's PQI's code, or that it couldn't find a match in its database and therefore reported all zeros? I didn't see anything on the CPUID website that indicated the code associated with each manufacturer.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              Re: Memory
                              its manufactured by celetronix memory group. for who exactly still dunno...
                              http://1006.tchosts.net/home.asp
                              http://www.celetronix.com/
                              i my search i came accross m-systems (not related) which have "Flash Disk Pioneers" under their logo. i remembered an unfortunate spelling in a greek computer magazine had their ad with the mispelling "Flash Dick Pioneers" wherever their logo was. excellent.
                              • Newbie2
                                • Sep 2005
                                • 885
                                Re: Memory
                                CPU-Z reads off the memory module and shows what it found on the memory module. On my PQI memory module, it found 16 zeros and put that as the manufacturer. I have used it on my dad's laptop and it showed up "Corsair" meaning that his laptop was using Corsair memory.
                                And great find willawake. Mispellings in magazines can be funny!
                                My gaming PC:
                                • arneson
                                  • Sep 2005
                                  • 1267
                                  Re: Memory
                                  I saw that as an inverted E and came up blank.
                                  Jim
                                  • AK0R
                                    • Mar 2005
                                    • 204
                                    Re: Memory
                                    Thanks for finding this, will. I carefully eased the heat shield away from the board (just a bit), and there's only 4 chips on each side of the board. So, it's the low chip density type, which probably explains why these 440BX boards detect it at half rated capacity.
                                    • Rainbow
                                      • Aug 2005
                                      • 1375
                                      Re: Memory
                                      I think that the heatsink is there just to cover the crap inside...
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        Re: Memory
                                        might not be crap
                                        High fidelity Audio amplifiers for MITEK,USA , D2Audio,USA.
                                        Memory Solutions for Micron, USA, (looks like also Dell, Apple)
                                        Digital Set-Top Boxes for EchoStar , Entone-USA and TechnoTrend AG, Germany, High Density Notebook Adapter and Desktop Power Supply for Apple Computer, DELL, USA
                                        Celetronix Manufacturing locations: Mumbai, Chennai, Pondicherry, Kandy, Sri Lanka.
                                          LENOVO IdeaCentre Y900 IdeaCentre Y i7-6700K Specification for Upgrade or Repair
                                          This specification for the LENOVO IdeaCentre Y900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the IdeaCentre Y900 boardview and IdeaCentre Y900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          LENOVO IdeaCentre Y900 RE-34ISZ IdeaCentre Y i7-6700K Specification for Upgrade or Repair
                                          This specification for the LENOVO IdeaCentre Y900 RE-34ISZ can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the IdeaCentre Y900 RE-34ISZ boardview and IdeaCentre Y900 RE-34ISZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          DELL Latitude 5591 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5591 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5591 boardview and 5591 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5591...
                                          09-06-2024, 09:09 AM
