Attack of the RoHS
  • mockingbird
    • Dec 2008
    • 5484
    Attack of the RoHS
    http://www.appleinsider.com/articles...d_display.html
    ...Serenity Caldwell of Macworld has also reported issues with the MacBook Air display, noting that the Air's display has turned a variety of colors: gray, tan, gray-black, and blue. Caldwell consulted an Apple Genius, who suspected "the Air's logic board might possibly be at fault."
    Why the heck are manufacturers still using RoHS compliant solder (lead-free) for their boards?
    Look at this:
    Here a company finally deviates from the reference design and they decide to still use the lead-free solder. Why?
    How many more years of high failure rates of Radeon 3xxx 4xxx and 5xxx will it take for people to wake up and demand better? Also RoHS is supposed to be a European standard, why is it being forced on Americans?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Attack of the RoHS
    It's the almighty dollar. They'd have to have more equipment to do some boards with lead-free and others with lead solder. They save money doing them all the same.
    A man convinced against his will is of the same opinion still.
      • 31003
      because it's also a chinese standard,
      and Europe + china = most of the world market.
      maybe if they used better lead-free solder with a higher copper content and reduced the running temp of the chips they'd have less problems - but they wont risk increasing production costs by a penny or 2.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        because they don't wanna look like anti green assholes.
        i see the point... pick up board- touch solder, lick fingers- repeat for many years. also a trash to groundwater contamination problem.
        i also see that lead solder either overmelts or undermelts... there is no good solution right now.
        i just had an idea- i remember that the NI cRIO kits sent to FRC teals like i am on had a couple breakout boards that were coated in clear plastic. for durability reasons... the FRC robots go through hell... i wonder if you coated cards like that, leaving the surfaces of heatsinked and hot chips uncovered, also leaving the contacts uncovered... it could seal in the lead...
        sigpic
        (Insert witty quote here)
        • pentium
          • Mar 2006
          • 2778
          Two weeks after release AND they had to release a dodgy update on the release day?
          Wow, that's really bad.
          Find Nedry!
          Check the Vending machines!!
          <----Computer says I need more beer.
          • Rulycat
            • Apr 2010
            • 724
            • United Kingdom
            Wondering if you cool this better, to reduce the heating/cooling cycles, whether that would help.
            • smason
              • 1652
              I used to hold a length of solder in my mouth when I needed both hands.
              • mockingbird
                • Dec 2008
                • 5484
                nVidia has not learned from its past. The new GTX 580:
                • Rulycat
                  • Apr 2010
                  • 724
                  • United Kingdom
                  Do you expect them to not follow RoHS compliancy and therefore lose all sales in Europe?
                  • mockingbird
                    • Dec 2008
                    • 5484
                    What happened to the days where America was the exclusive recipient of prime technology and Europe had to wait for our tablescraps. They were eternally grateful to have American-invented sophisticated technology available for distribution in their channels.
                    Now we have to conform to their retarded standards at our loss... What has America come to.
                    • Wizard
                      • Mar 2008
                      • 2296
                      These RoHS have very good reasons to do so. Research on this please.
                      Hint: it does not have to do with just electronics. Emissions of stuff during the manufacturing and disposal after end of life and failed parts is the biggest reasons. Ditto to lead, and mercury and other man-made elements.
                      example:
                      Going back to metal containers for drinks is acceptable, rustable, totally recyclable...plastics not since this is where infinite resource is, from oil.
                      Use food-safe internal coating not from oil for corrosive drinks.
                      Eventually there will be a way to do this by electrical to melt steel and generate more O2 to purify steels and other metals.
                      Ever heard of using ceramics? Can be molded and fired in complex shapes, cloth, covered, etc rubber insulation wirings, there are ways to do this without needing to use oil. Pitch is another. Remember we have gone long way since poorly made materials from 30's thru 60's.
                      Glass as well.
                      Many makers are going back to glass for bases and metal backs, and very little paint and little plastics except epoxy for circuit boards. Samsung is doing this, I have also noticed LG as well.
                      There are the ways, just have to demand this from makers.
                      Cheers, Wizard
                      • mockingbird
                        • Dec 2008
                        • 5484
                        I understand the need to reduce lead, I just don't understand the need to do it in very sensitive BGA applications where the amount of lead is minute. The only reason to do this would be if the manufacturer would want to increase its sales by predetermining a lifespan for its product a little more than its warranty. It's genius and I feel the wool is being pulled over peoples eyes.
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          yeah heres the thing: i sort of understand where youre coming from, but i think that its not because of lead-free that most stuff is made like shit and wont last past warranty.
                          • Wizard
                            • Mar 2008
                            • 2296
                            Cooling is the key.
                            OEM heatsinks for video card is poor except the high end versions.
                            And I have not seen any failing past warranty periods. For ones that does not last, I usually see these that had poor cooling design.
                            Cheers, Wizard
                            • mockingbird
                              • Dec 2008
                              • 5484
                              I've seen rampant reports of video card failures that are subjected to sharp hot/cold cycles, but are cooled quite well. These cards, such as the Radeon 3xxx, 4xxx and 5xxx series have temperature-based fan control. They have monstrously dense copper heatsink blocks and very powerful turbine fans. They do not fail because of poor cooling, only because the GPU temperature can suddenly fluctuate between 80 degrees celsius to 40.
                              It's not just when you're playing games. Imagine this. You go on Youtube and watch a 1080P video, the fan starts to spin because Flash is now hardware accelerated. You switch between the video and an Excel spreadsheet. You can see where this fluctuation of temperature is bound to cause a problem.
                              • Rulycat
                                • Apr 2010
                                • 724
                                • United Kingdom
                                The Radeon 3870 BIOS was very lazy and would pretty much keep the fan at 10% speed until it hit about 90C. Stupid thing.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  Interesting. Can this be changed? I have a 2900XT which I intend to use in the future.
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    Try evga precision. Its a good littel program!
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      I remember there was a way to hack the bios and change the default settings and then reflash. I will have to check that out. I did it for nVidia cards, but I don't know about ATI.
                                        • 31003
                                        why not just hard-power the fans?
                                        that's what i do on xboxes.
                                        • corrize
                                          Best way to solder LVDS connector for beginner (and qfn) ?
                                          by corrize
                                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                          See the test :
                                          https://youtu.be/bNAzC-EvqHs?t=1767
                                          With hot air from bellow the board, that's...
                                          03-09-2023, 02:57 AM
                                        • myth77
                                          UV solder mask - high temp resistent, recomendation?
                                          by myth77
                                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                          Is there any solder mask...
                                          03-28-2022, 04:04 AM
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
                                        • slugpoa
                                          Bios Chromebook Positivo - N2312 ROHS - Q01-63875-V2.0 Request
                                          by slugpoa
                                          Bom dia, preciso de ajuda com a Bios bloqueada
                                          Fabricante: Positivo
                                          Modelo: N2312 ROHS ,
                                          S/n: 4AG850Q6D
                                          Modelo PLACA: Q01-63875-V2.0
                                          Agradeço desde já .
                                          Today, 04:10 PM
                                          Good morning, I need help with the blocked Bios
                                          Manufacturer: Positivo
                                          Model: N2312 ROHS,
                                          S/n: 4AG850Q6D
                                          BOARD Model: Q01-63875-V2.0
                                          Thank you in advance.​
                                          in English please.....
                                          11-25-2024, 08:10 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
