Bust Lappy Keyboard
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Bust Lappy Keyboard
    OK its a Dell C640. I was removing the keyboard to reinstall the CMOS battery. I popped the key with the windows logo on it off the keyboard. All four little tangs are still intact. Just how do I put it back on the keyboard? Its just another dumb moment for me!
    Mark Twain
    John Paul Jones
    Rod Serling
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Bust Lappy Keyboard
    i have fixed that before. it require careful work wit the fingers though. hard to explain in words.
    sigpic
    (Insert witty quote here)
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      My finger are dumb as dirt so I will toss it in a bag in the box as per your request. Thanks RD.
      Mark Twain
      John Paul Jones
      Rod Serling
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        They generally just pop back on, unless you've pulled everything off the board, in which case it's harder to do. I've got a whole box of them at work, so if I screw up the little metal tabs on the board itself, I generally just chuck the keyboard and throw a new one on.
        Ludicrous gibs!
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          i have had varying stages of success. if the little lever things are intact, you have to stick one in, then lay the key down and press the other one in. the delete key on my hp laptop i no longer have came off, and i never figured out how to put it bck on. but the esc key on the same laptop was a cinch to put back on...
          then again ibm didnt even put windows keys on their laptops for a period of time-so theoretically you dont need it
          • seanc
            • Nov 2008
            • 1319
            Unless like me, you rely on keyboard shortcuts. No Windows key, or it's in the wrong place, no sale.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              yeah i know i use the windows key. thats why i dont use that laptop anymore (besdies the broken screen hinges)
              • Wizard
                • Mar 2008
                • 2296
                Don't fret. I had popped off the keycaps on many notebooks.
                Make sure the rubber dome is still there and look carefully at the key cap you will see 4 claws in pairs and carefully place this on the little nubs and press firmly down. You should hear clicks.
                Cheers, Wizard
