highest p3 clock speed?
Re: highest p3 clock speed?
It looks fake to me, but there were PIII boards with DDR memory and PCI locks. Fastest my dual-PIII board does is 166FSB (1.74GHz) but it doesn't get any further than the BIOS with that.
I've been long planning to patch a PCI lock into my board, guess we shall wait and see. I have a 3/4 divider so there will be no problem with the SDRAM at 166MHz. Come to think of it, i wonder whether it can do a different divider too, but i'm not sure if SDRAM can work truly asynchronous. I guess i'll bust out a board that i won't cry for if it breaks, patch a clock generator into it and see what happens.Last edited by Th3_uN1Qu3; 10-15-2010, 12:33 PM.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
http://valid.canardpc.com/show_oc.php?id=411593
Achieved with Liquid Nitrogen cooling...
.Mann-Made Global Warming.
- Dr Seuss
I guess I could try fitting one of those pin-modded Tualatins and see what happensComment
He's using Kingmax PC150 RAM.
- I have a few sticks of that stuff. I ran it in my Athlon Slot A back in the day.
- Good stuff!
There was also PC166 RAM but it's even more rare.
I don't think there was ever an official spec for PC150 and PC166 but they did get manufactured by a few companies anticipating that might be the next step in SDRAM.
Then DDR came out and they got dropped.
- Dr Seuss
I used to have some Crucial PC150 256MB modules... and i gave them away.Never got the LN2 bug however, i like to make stuff that can work 24/7. There's nothing more annoying when using a computer than it crashing in the middle of something you hadn't saved in hours.
I had the 300MHz Pentium I (actually it's still in one piece, but i haven't used it in a few years), i will have the 1.7GHz dual Tualatins too. But it'll take a bit of time.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I haven't screwed around with overclocking since maybe Pentium 1 or 2.
I went with the PC150 to run solid/stable at 133 and CL2.
In 1999 Kingmax PC150 was cheaper than Crucial PC133 7ns so that's what I got.
The individual RAM chips are 6ns and can supposedly do CL2 at 150MHz.
Never tried OC with them but they worked great at 133/CL2.
Despite what various ads claim.
To get 133 really stable at CL2 [without fussing around] you need at least 7ns chips.
Modules with 7.5ns chips get mixed results and are best used at 133/CL3 or 100/CL2 if you don't want to tinker.
Crucial PC133 with 7ns chips are rock solid at CL2.
That's my #1 preference in PC133 RAM.
Mine was 6ns but advertised as PC150 at CL2.
But: the PCxxx ads generally meant xxxMHz at CL3.
As so:
PC150 6.5ns - 150MHz/CL3 or 133Mhz/CL2.
PC166 6.0ns - 166MHz/CL3 or 150Mhz/CL2.
PC183 5.5ns - 183MHz/CL3 or 166Mhz/CL2.
[OCZ made PC183. Dunno if anyone else did.]
But - As there was no official standard all kinds of BS claims were made.
Just saw an ad for PC166 and the chips are 7.5ns. - CALLING BULLSHIT!!
.Last edited by PCBONEZ; 10-15-2010, 03:37 PM.Mann-Made Global Warming.
- Dr Seuss
had some -55 sdram reported to do cl2 at 166 but never got the chance to play with them.i remember them being microbga chips on very low profile dimms.kinda lost interest and a friend wanted them in a trade so they went.
wanted to stuff em in my gigabyte dually tually and see if i could push it further.i had already polymodded it.another board sombody else had to have and paid well for it.Comment
You may see my contemporary configuration below = yes, that is the actual clock of mine Coppermines minus 1MHz to the FSB = the caps arent what the used to be now. also chcek the thread of my research
https://www.badcaps.net/forum/showth...bit+vp6&page=3Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.Comment
173MHz FSB???? Dang. You should seriously get a pair of 1.4G PIII-S. And one o' those PCI SATA cards, they are awesome.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
the VP6 supports these CPUs only with appropriate adaptors and supports only one CPU in it, thus using the current CPUs. It actually can be higher than 173 with the top quality rubys in VRMs and near MEM subsystem.Last edited by Shodan486; 10-19-2010, 05:14 PM.Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.Comment
My CUV4X-DLS doesn't support Tualatins either... but that did not stop me from using them. No adapters no nothing, the CPUs had been previously modded as to work with MS6905 Master slotkets, and the same mods worked just fine for this board.
So far i'm at 1.55GHz (147 FSB), the power supply needs some work before i go further. No draw on 12v plus lots of draw on 5v makes an unhappy Xilence. I've been using a second PSU in parallel which is feeding the extra 5/3.3v connector (forgot how it's called), but it's a clunky approach. The real thing will involve a buck converter supplementing the 5v rail with power from the ATX 12v connector which is sitting idle anyway.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Definitely right with that 12v rail support. Will help, sure about that. I'm using the FSP Epsilon 700W, has 30a on both 5v and 3,3v rail as far as i remember - voltage on 5v drops to 4,75v exactly under the heaviest conditions, not a bit lower, and the 3,3v is pretty much OK, but VP6 can raise it to 3,6v, now using 3,4v and automatic AGP driving strength - crucial to certain cards.
Anyways could you post some pics or links to that gadget of yours - meaning the converter.Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.Comment
Well there exist actual converters that allow running a FC-PGA2 CPU into a FC-PGA socket, but it actually only involves insulating a few pins and using a resistor to bridge another two. The harder part is the resistor, as you have to solder it directly to the CPU. I'll link to the original article as soon as i find it.
Your system uses less power than mine. When i was on my old GA-6BXDS that was limited to FSB 100 (1GHz) 5v was at 4.75v. When i got the new board, 5v went to 4.5v. So low that it crashed the SATA HDD, right after i'd gotten thru all the trouble to make the almost 4-year old TinyXP install run on the new motherboard. And my Xilence PSU has 32A on the 5v rail. This is also something to keep in mind - same thing with not enough power could happen to you as well.
3.3v is ok because it does use the same transformer output of the 5v rail but it is independently regulated. So the more 3.3v you use, the more 5v goes down.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
- Dr Seuss
+3,3 V:90 A
+5 V:68 A
+12 V rail 1:32 A
+12 V rail 2:32 A
My VP6 will enjoy this much of juice, I can feel it - maybe will get 175MHz stable, but I'm starting to be very suspicious about the caps being worn out slowly.Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.Comment
This is very interesting, but my P3 boards are dually tually's with ServerWorks chipsets so I don't think I can raise them over 133 to begin with. I need to go back and service them with a HD alignment and XP SP3 to see how they do... and an aftermarket PCI video card because I just cannot stand the RageXL sadness.Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700Comment
by shelby5041hi
ive got a modern digital clock radio approx 15yrs old
my question is how long can a clock radio or a simple radio last ss farcas operating hours?
since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
it uses very little power just a few watts i would imagine that may have something... -
by klugecHello (sorry for my bad English),
I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
Mods shows me the following error:
Code:MODS start: Thu Feb 1 19:16:00 2024 Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
by UserXPDear all,
I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
My question is, do you know of this brand of capacitors and how bad are...-
by BabbarMy fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
AD7276, AD7277, AD7278, AD7274, AD7273
The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...-
Channel: Common Parts Library - Datasheets
10-07-2024, 05:32 AM -
- Loading...
